September 25, 2026, 02:59:47 am
| | |-+  IDF Air Cleaners
Author Topic: IDF Air Cleaners  (Read 42647 times)
andrewlandon67
« on: November 03, 2023, 04:04:00 am »
Anyone have any opinions on the best non-billet air cleaners for IDFs? Don't need a breather hole and am willing to spend some cash, the cheap chrome ones I have are already starting to wear down, though are miles better than the Empi billet ones I had on the car for years that stripped out studs and were generally just a massive hassle.
14.877 @ 88.85 mph
He who waves at 911 drivers
Dougy Dee
« Reply #1 on: November 03, 2023, 13:47:21 pm »
Ive been spoiled by the CB Peformance ones.  Can be had in several configurations.
Karlos99
« Reply #2 on: November 04, 2023, 22:23:36 pm »
K&N, have them on the DRLA’s on my bug motor.
« Reply #3 on: November 05, 2023, 19:03:09 pm »
Vintage Speed and Flat Four make some nice looking ones. They have an early Porsche style to them. Not sure how efficient they are though.
« Reply #4 on: November 05, 2023, 22:13:45 pm »
Vintage Speed filters are beautifully made and accept K&N filter elements. I had a pair when I was running carbs.
karmi
« Reply #5 on: November 06, 2023, 02:09:41 am »
I use Ram Air Filters
https://www.amazon.de/Ramair-Vergaser-Luftfilter-Grundplatte-Weber-Anschrauben/dp/B08LDTXXPK
https://ramair-filters.co.uk/filters/carburettor-filters/carburettor-foam-air-filter-with-baseplate-to-fit-weber-40-idf-40mm-internal-height/
« Last Edit: November 06, 2023, 02:15:53 am by karmi » Logged
andrewlandon67
« Reply #6 on: November 06, 2023, 17:43:45 pm »
I've definitely looked at both of those, they're a bit pricy but they both look great and seem better built than what I've run in the past. As far as efficiency goes, I have K&N elements so I'm more concerned about just how well they're made and fitment.
14.877 @ 88.85 mph
« Reply #7 on: November 06, 2023, 18:24:04 pm »
In which case, you won't do better than the VS ones - fit and finish on mine was exemplary.
andrewlandon67
« Reply #8 on: November 06, 2023, 20:58:30 pm »
That's good to know! My only concern with those is that some of the pictures show an upper brace between the uprights that goes right over the velocity stacks, did you have any issues with that?
14.877 @ 88.85 mph
« Reply #9 on: November 06, 2023, 23:52:40 pm »
The photo they use is deceiving as the filter element is shown lifted free from the base plate. The brace you mention is actually flush against the top cover, not floating in mid-air over the velocity stacks.
andrewlandon67
« Reply #10 on: November 07, 2023, 00:15:39 am »
Awesome, thanks for the info! It might not be immediately but I'll definitely be ordering a pair of those as soon as I can!
14.877 @ 88.85 mph
Rome
« Reply #11 on: October 05, 2024, 20:53:43 pm »
OP, if you still have your original chrome air cleaner lids and want to experiment a bit, you could prep them and spray with hammer-finish paint. I had a set of used swap-meet cheap Dell'Orto lids and bases several years ago which were also past their prime. I wet-sanded the surface with 220 grit, then applied light blue hammer-finish paint. Several other colors are available such as gold, copper, silver. Here are my shots from theSamba-
Then wrapped the filter elements' outer surface with screen door aluminum mesh to give them a retro look-
« Last Edit: October 05, 2024, 20:55:25 pm by Rome » Logged
andrewlandon67
« Reply #12 on: October 07, 2024, 16:29:22 pm »
Oh man, that looks great! I really like the mesh outer screen look on IDFs, there's just something racy about it. I might have to do something similar to mine, I still have the cheap chrome ones from EMPI and running my K&N elements in them, but adding a grommet to the center hole has improved their lifespan immeasurably.
14.877 @ 88.85 mph
