October 09, 2026, 12:17:10 pm
352315 Posts in 28958 Topics by 6926 Members
Latest Member: Chakalives
| | |-+  63 Ragtop Dad and Lad project.
Pages: 1 2 3 [4] Print
Author Topic: 63 Ragtop Dad and Lad project.  (Read 220628 times)
BossHogg76
« Reply #90 on: May 05, 2025, 17:43:19 pm »
Progress has slowed recently as we wait for big chunks of the project to arrive. In the meantime we have fitted the oil cooler and the remote oil filter head bracket has been printed off and test fitted. A few adjustments were made to the design and it's off being machined. Not pictured was changing the gear shift bushing, a job that seemed to take forever but is thankfully out of the way.
Next week i'll look to strip the front brakes off, in preparation for the new kit. I also need run power to all the gauges for the sensing circuits and i might have some very lovely running boards to fit.
« Last Edit: May 06, 2025, 10:57:58 am by BossHogg76 » Logged
BossHogg76
« Reply #91 on: May 11, 2025, 19:18:51 pm »
Another little updated, this week i dropped a few things off to Richie for the engine, and picked up some rather lovely carbon fibre running boards. So as the sun beat down on a lovely Sunday morning i dragged my hungover self to the workshop (drinking with mates from my Airforce, never gets easier) with Daniel and we set about fitting them. Richie has got the weave looking great running at a 45 degree angle pointing to the front. Next on the list was a bit of preparation for the new brake kit, this went a lots faster than anticipated and in half an hour, under the careful supervision of the lad i had the front drums off. That's it for today but things are moving in the right direction.
« Reply #92 on: May 12, 2025, 07:37:24 am »
Cool  Cool
BossHogg76
« Reply #93 on: May 18, 2025, 17:43:43 pm »
thanks Richie
Sometimes you have to go backwards to go forwards, this weekend was one of those occasions. The lovely guys at CSP have made up a set of disc brakes for me, in the required Chevy pattern, special thanks for them for doing this, and particularly Gunter for all his help. Friday 16th May, i finished work and headed to the workshop, the plan was to dummy fit the hubs to the pre-stripped front end slip on the wheels lower to ground, bask in the gloriousness of a job well done and then fit the rest of the kit. Unfortunately things didn't go according to plan. The hubs fitted perfectly, the wheels fitted the hubs perfectly, unfortunately when i lowered the car down it was clear that the wheels were too beaucoup for the arches. We're talking by about an 1inch per side, but it's something we need to address.
So after a quick chat with Jay it looked like the beam is original width so a 2" narrowing should do the job. That meant an oppurtunity for some learning so Daniel and i removed the beam and stripped it ready for Jay and Mike to work their magic.
FredH17
« Reply #94 on: May 24, 2025, 19:02:30 pm »
Whoooo Rob, it’s been to long since i checked in here…..but what a progress you and the kid made!
All these carbon parts look like a million dollars buddy. Especially with the white paint. Just lovely!
Keep it up!!
BossHogg76
« Reply #95 on: June 22, 2025, 20:36:58 pm »
Keep it up!!
Many thanks Fred we are slowly getting there. Now there haven't been any updates as i've been out in California for the DKP 60th and HotVWS Cal Look edition 50th anniversary, which was a full on week. However it was soon back home, back to work and this week fired with enthusiasm got back to work on the project. My son was a bit busy this weekend, which gave me a straight run at things. If you follow me on instagram you will have seen that beam was not usable. When we stripped off the powder coating the adjusters had been welded in very poorly ruining the beam. So it was off for a wallet hurting purchase after some rapid research i went from a mid priced Cb Performance one to a Cagero one, complete with 8 roller bearing and losts of Swiss loveliness. That arrived the weekend before i went away and despite my sons and mines efforts we ran out of power getting it located.
On my return with Jay we soon and the top bolts in and I was quickly bolting it in as he shorted the leaves and track rods. Which meant i could get the front end buttoned up, and the new wheels on. the geometry needs to be set and some torquing needs to be done, but it's 90% done. Jay will hopefully be fitting the rears brake kit and wheels in the next couple of weeks.
So what does that leave?
1) Oil System to finish plumbing in.
2) Gauges to complete wiring
3) Fuel System to plumb in, including sealing the fuel tank and fitting that,
4) MSD to fit and wire in. (Carbon panel has been bought for that.
5) New wheels studs fitted as the current ones are too short.
6) Engine fit and fire it up.
7) Interior carbon panel to make for rear seat space.
Cool A couple of other cosmetic things i want to do
Finally here are the pics
BossHogg76
« Reply #96 on: July 04, 2025, 08:57:14 am »
Progress is slowly going forward with more items being ticked off the list. A new breather box from CSP has been fitted with Daniel doing a great job using the Rivnut tool and bolting it in. He also fitted the Berg traction bar mounts, looking at the drop links i've had to make some changes to the design of the oil filter head mount. so a new version is being machined at the moment. The rear brakes should be going on next week (11th June) and i should have the majority of the wiring and plumbing done next weekend. I've got a little weekend project for the front lights coming up for Daniel, hopefully that will go well. So fingers crossed by next weekend i should have bug in a position for the engine when it is ready Oh and we put the passenger seat in a couple of weeks ago.
« Last Edit: July 04, 2025, 08:59:31 am by BossHogg76 » Logged
BossHogg76
« Reply #97 on: July 16, 2025, 20:46:52 pm »
Ok so this will be a double update as there's a few pictures.
First off small job were done like fitting the engine bay seals oddly enough no pics of that, and no help from the lad  Cheesy, but it's a step in the right direction.
Next on the list was purely cosmetic, with this car i am constantly aware of it's heritage and not wanting to return it to being replica of the one. With a limited budget this has been a task, the next thing on my list was the headlights, absolutely beautiful with machine turned inserts. But again a nod to what it was made to be, so I thought how could i give a nod to it's heritage and move the game on. Carbon fibre inserts obviously...but how to do it, making moulds would be hard and getting a consistent curve fairly diffiicult and i certainly didn't want to use a cheap sticker. In the end i found flexible carbon fibre, with a 3m backing, that would do to the job i thought. Next. i wasn't going to butcher the original lights, and i ended up buying a set in California and having them sent over. Then it is was onto the mods, stripped down painted matt black and a card board template made up. I soon had them back together and then it was what to do with the lenses, i wanted flat to mimic the original design, but wanted a more menacing look. I ended up making a set of clear and a set of smoked lenses, the smoked ones won. The pics below show the progress:
BossHogg76
« Reply #98 on: July 16, 2025, 21:01:19 pm »
Next up was rear wheels, now i had already fitted the front beam and CSP brake kit, but the rears needed a torque multiplier and more time than i currently have, so Jay came in to do the work. In a day the rears were on with a cry of,..Rob you need studs, so it was a 24 hour date as i dug some out my garage and ran them up to the workshop. I got a message later that afternoon, come and have a look, my might have an issue with tyre width using the MH. So i dived into the car and rocketed through Northumberland to have a look.  With no engine Jay filled the back seat area with tractor weights to get the back down to ride height.
I'll let the pics do the talking, and you can also see the lights fitted.
You can see that the MH Dots are just a little to beaucoup for the rear arches, so we fitted the Michelin XWX from my 67 and for 2025 they will do until we decide something more drastic to fit the MH Dots
So next on the list is wire in the MSD, (thanks Jo and Richie for getting this sent through) wire up the rest of the gauges, clean seal and fit the fuel tank finish off the oil lines.
FredH17
« Reply #99 on: August 03, 2025, 19:04:32 pm »
Rob,
This car is just epic!
I love all the black/carbon stuff on the white paint. You guys are making very good progress.
You’re coming over to Airmighty next Month?
I would love to see this killer callook i.r.l.
Greetz
Fred
BossHogg76
« Reply #100 on: August 05, 2025, 10:23:53 am »
Hi Fred
thanks for the kind words, yes the goal is still to get to Airmighty, and we're hammering along to get everything sorted in time.
If needed it will be there on a trailer.
best
Rob
BossHogg76
« Reply #101 on: September 28, 2025, 19:22:22 pm »
So I need to catch this thread up, did we make our goal, if you follow me on social media you will know the answer to this, if you don't then buckle up as a lot of work got done in the last few weeks.
I left the thread with a pile of work left to do, the car didn't have an engine and was only at ride height as we'd filled the back seat area with tractor weights. Richie let me know that a lack of cases on the market meant that the engine meant for this project wasn't going to be available in time. Now i do own another cal looker and all eyes settled on the 67 with it's ultra reliable 2276cc also built by Richie, the decision was made to make the show the 67 was going to have to give up it's engine in the short term. So we fired into that job and soon had the 67s engine in the Ragtop. Around this point i buggered off on two weeks holiday with a list of jobs a mile long and a list of parts to buy equally long.
So the rear end even with the engine in was in the air so we made the decision to fit a set of adjustable spring plates from Cagero, so they were ordered so they would be waiting when i got home. The plan for Airmighty was my 78yo parents were going to join us and take in the VW vibes, however my mum got run over by a mobility scooter breaking her hip and ankle. That and the subsequent hip replacement to paid to them joining us. Due to this i needed to be help as much as i can at home, but my exhaust from A1 and carbon wiring cover were in Northern Scotland, a 10 hour round trip for me. Thankfully Russell arranged for them to be delivered to my house while i was away. Which meant when i got back i could get fired straight into it. and that's what i did resulting in the car firing into life on monday 1st september...3 weeks to go before the show.
« Last Edit: September 28, 2025, 19:45:29 pm by BossHogg76 » Logged
BossHogg76
« Reply #102 on: October 04, 2025, 18:10:14 pm »
So the engine is running what could go wrong... a lot. First was the usual reliable Mocal oil cooler popping right in the middle of the matrix. This was less than ideal especially as there were none available for a few days. So the 67 donated its one to the cause.
The next thing that went wrong was on tuesday 2nd sept i fired it up to balance the carbs and set the idle, it started running lumpy as hell, when i turned it off i heard the unmistakable sound of running fuel, thinking i had a fuel line like i checked those, they were all good. I eventually tracked it down to both carbs just emptying themselves like a hose pipe down intake. By this point i was running out of patience. I call to my mate Jay a quick trip to pick up the trailer and i was taking the car to his, and i'm so glad i did. Both carbs were removed stripped. The seals in both had perished the shut off valve in the left hand one had given up and needed replacing, thankfully by the weekend they were both rebuilt and the engine was running better than it had done in the 67, and sounded rude through the A1 Exhaust.
We picked it up just in time to attend my mate Mals Burger and Bugs night in Newcastle. The in itself was eventful as i'd forgotten the pinch bolt for the rear gear coupling resulting in the bolt sliding half out and stopping me getting any more than 1st and 2nd, I managed to bodge that and get to venue.
Unfortunately by the time i got home the rear suspension i had re-indexed when i fitted the cagero spring plates, had slowly started to sink as the bushes wore in. Now i like the DKK one spline down look, but... i prefer a more drag stance nose down ass up, rear wheels vertical and no negative camber. I went to bed thinking it'll be fine, just leave it as it is.. after all there wasn't much time to go until we left for the show. In fact i spent all of the sunday (7th Sept) opening the garage door and trying to convince myself it would be fine. At 7:30 sunday night i walked into the garage cracked a beer and your guessed it.
At just before midnight i finished and went to bed hoping i'd got it right,
« Last Edit: October 04, 2025, 18:12:31 pm by BossHogg76 » Logged
BossHogg76
« Reply #103 on: October 05, 2025, 11:34:10 am »
As it happened i did get the ride height correct and was able to concentrate on getting all the final bits done. A carbon wiring cover completed the under bonnet area, and i found a suitable number plate surround from the collection, and Daniel and i where reaady for Airmighty..we hoped.
There was the usual last minute running around, i also managed to not tighten the new oil filler cap up properly resulting in oil all over the engine bay and down the right rear wing Angry
But in the end as Donald and Logan arrived followed by Gavin from Trailer Queens, we were ready to go,
Though even that wasn't with out drama as the previous oil slick had meant i had to remove the right rear light housing to clear up the oil. Some how this simple task resulted in me inducing an earth fault, this resulted in two blown fuses and no gauges in the 10 mile drive to the ferry. Thankfully as Russell and Co unloaded their Cal lookers at the port i was able to sort it out.
« Last Edit: October 05, 2025, 11:45:54 am by BossHogg76 » Logged
tpb_karl
« Reply #104 on: October 14, 2025, 06:12:21 am »
The gift that keeps on giving! (Issues at least)
Great to see that you made it to the event, despite all the issues. Car looked stunning IRL.
The Wondervolks
1963 - The Ragtop Express
Instagram: @slinkysspeedshack
Youtube: https://www.youtube.com/@Slinkysspeedshack
BossHogg76
« Reply #105 on: April 18, 2026, 16:54:45 pm »
Well after a massive wait i really should bring this thread back up to date. If for no other reason to document what we got up to for Daniel. So we arrived in Imuijden and i managed to be the last one off the ferry, but there was no hurry as we headed towards the first stop of the day to meet with the more guys. This included Heydon Mizon, the DFL guys and many more, whilst there i managed to panic myself into thinking i had a fuel tank leak. it turned out to be an old oil leak in the parking space. But my mucking about disturbed a connection in the fuse box which cut the fuel pump. Heydon came to the rescue calmed me down and some well placed electrical tape sorted the issue out. Heydon in his stunning black 67 and i hot footed it to catch up with everyone and we got to Kieft en Klock and I managed to chill out and enjoy the scene. We then headed off in convoy to the last stop of the day, the Fletcher Hotel in Wageningsche. This was the meeting point for the start of the caravan to Airmighty the next day, and it was great to see the car park fill up meet old friends and make new ones.
