October 14, 2026, 16:22:22 pm
Stealth Throttle Bodys - Weber IDF - 50mm with superflo manifolds
Topic: Stealth Throttle Bodys - Weber IDF - 50mm with superflo manifolds (Read 4740 times)
Stev
May 07, 2024, 20:13:12 pm »
Hey guys,
I'm selling my selfmade Throttle body stealth kit. The Webers are bored to 50mm diameter. as the body is too thin over the the 50mm, it is bored to 47mm. 47mm is nearly the same area as 50mm with shaft. You can drive every Bosch EV14 fuel injectors you want. The bodys worked really well and made 258ps out of my 2811 TF1 engine with MS 230 heads. The Flow is more then 245cfm @ 25. The synchronizing screws are working, the rest of the Carburetor is not there anymore.
International buyers are welcome. What you see in the pix is what you get.
1200€ + shipping
Last Edit: May 07, 2024, 20:38:12 pm by Stev
Looking for a flanged crankshaft, all type 4 main bearings and a flywheel for KEP clutch. Stroke 84 till 88. The bigger the better ;-)
Stev
Re: Stealth Throttle Bodys - Weber IDF - 50mm
May 07, 2024, 20:15:09 pm »
[ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
Stev
May 07, 2024, 20:16:05 pm »
Stev
May 07, 2024, 20:20:38 pm »
Just an example how it looks with Fuel injectors. Fuel injectors are not included.
Stev
Re: Stealth Throttle Bodys - Weber IDF - 50mm with superflo manifolds
June 02, 2024, 17:13:57 pm »
New Price 999€ - price is negiotable!
Stev
Re: Stealth Throttle Bodys - Weber IDF - 50mm with superflo manifolds- new price
July 18, 2024, 20:07:08 pm »
699€ obo!
