September 21, 2024, 04:41:40 am
351058 Posts in 28638 Topics by 6845 Members
Latest Member: DonA
| |-+  Technical stuff
| | |-+  What engine oil ?
Author Topic: What engine oil ?  (Read 1687 times)
Baz54
« on: May 12, 2024, 14:56:51 pm »
Hi, i have a 1776 engine in my car and over the years every time I change the oil I do a bit of research on the usual sites.
When I  had it over 10 years ago I always used mineral oil but then the opinion was semi synthetic a good few years later people were saying it’s  a mix of both so pointless, a few years later its fully synthetic . Looking around lately I’ve seen a good VW part supply stating  synthetic oil must not be used on air cooled engines! I’m just wondering what’s the most popular type of oil everyone uses?
Thank you , Paul
PPRMicke
« Reply #1 on: May 12, 2024, 18:27:09 pm »
Thank you , Paul
There is always discussion about oil
We only use good quality mineral oil
Then it is made in the US. For the US, the oil has higher levels of what is good for an air-cooled EU has a different environmental requirement, so there are less of the heavy metals that are good for lifters and cams
If you buy US oil, look at the packaging so it is not the volume, the amount in liters. Then it is manufactured in the EU
You have to look at wear and tear in the engine
Above all on the cam and lifter, also how the bearings look
When we open a 1600 challenge engine that has high revs and lots of boost (8500rpm boost 2.8 bar) the bearings look like new after 3 years
/// Micke
Baz54
« Reply #2 on: May 16, 2024, 13:31:45 pm »
Hi Micke, Thank you .  For an engine to be worked that hard and have minimal bearing wear is amazing !
I’m going to go back to where I started and not change from mineral.
Cheers,Paul
mikko k
« Reply #3 on: May 16, 2024, 18:12:08 pm »
Valvoline Racing VR1 20W/50 is good oil for aircooled vw engine.
Thats what I have been using 40+ years. It’s mineral oil. No problems ever.
« Reply #4 on: May 17, 2024, 09:01:09 am »
Exactly what I'm using in my Porsche 914 hillclimb car. High zinc content is great for lifters and cams.
Baz54
« Reply #5 on: May 19, 2024, 23:13:39 pm »
That’s awesome I’ll get hold of some and thank you for the oil spec as well .
pupjoint
« Reply #6 on: August 05, 2024, 18:50:11 pm »
Motul 300V
Millers NFT
Penrite Racing 5
not sure if you can get these in your country
Karlos99
« Reply #7 on: August 19, 2024, 19:41:00 pm »
I use Lucas Hotrod 10w40 in my 2276 nitrous motor
