June 15, 2024, 23:46:53 pm
Kona@2528
Technical stuff
what threads do i need to use??
Topic: what threads do i need to use?? (Read 488 times)
May 19, 2024, 23:25:22 pm »
hi guys , i need your help , i would put an oil temperature sender in my racetrim oil sump
but i don't know the threads , should I use as metric or NPT? for the guy who worked at auto haus do you remember ,
i can not remove the bolt as there some oil in the sump and case
thanks for you help
it's a little bit hurry
Re: what threads do i need to use??
May 20, 2024, 08:14:30 am »
Hi Fabs, it will be npt, most temp senders are 1/8th npt but usually the sump has different size like 1/4npt so you need an adaptor to fit it
May 20, 2024, 12:27:36 pm »
thx richie ..appreciate your help
May 20, 2024, 14:31:25 pm »
Quote from: richie on May 20, 2024, 08:14:30 am
this one?
1/4'' NPT male to 1/8'' NPT female
or here in belgium the sender can be in metric? so i will take 1/4npt female to M10 male if avaible
Last Edit: May 21, 2024, 18:59:54 pm by speedwell
May 20, 2024, 18:22:49 pm »
Yep that should work, can you measure outside of plug that's in sump right now? to confirm it is what i expect it to be
May 21, 2024, 18:56:20 pm »
Quote from: richie on May 20, 2024, 18:22:49 pm
here you go Richie, I took the measurement above the thread (16,9mm) and between the thread (15,6mm)
Last Edit: May 21, 2024, 18:58:23 pm by speedwell
May 21, 2024, 19:01:22 pm »
ritchie it seems that the vdo temp senders is M10 x 1
May 21, 2024, 19:47:32 pm »
Quote from: speedwell on May 21, 2024, 19:01:22 pm
I haven't used one of those in sump, when i used vdo it was the dual temp and pressure sender in stock pressure location
May 21, 2024, 19:48:27 pm »
Quote from: speedwell on May 21, 2024, 18:56:20 pm
I need to double check that in morning to be sure
May 21, 2024, 20:04:47 pm »
Here's my sender
