December 27, 2024, 04:10:55 am
351309 Posts in 28674 Topics by 6859 Members
Latest Member: CarstenK
| | |-+  The Ragtop Express
Pages: 1 [2] Print
Author Topic: The Ragtop Express  (Read 3713 times)
tpb_karl
« Reply #30 on: December 01, 2024, 18:56:42 pm »
Sp,me great progress there  Smiley
nice progress, I think the fitment on the rear fenders and running board is fine
Thanks guys!
I'll have to look around at some shows next year, on what the "norm" of fender-to-running board fitment is like Grin I haven't owned a bug for seven years. Back then i was very new to aircooled VWs. Which is why i'm not 100% sure on some details.
A couple of short visits to the garage this weekend. Had a big convex area by the horn grill on the driver's side front fender that I couldn't get rid of. Luckily I had backup fender and i don't understand why I didn't take this one from the start... This one fit perfectly and i just had to move the turn signal hole.
Then I started on the rear fenders. On the left, the gravel guard was still there, so after removing it, the to-do list grew once again..
I considered cutting out the whole piece that was rusty and making another attempt on the English wheel. But as I've said before, these are only supposed to get the car passed an inspection, so I've started patching up instead..
The fender is not finished. Work continues next weekend.
Ciao!
« Last Edit: December 01, 2024, 19:01:56 pm by tpb_karl » Logged
Twin Peak Boxers
1963 - The Ragtop Express
Instagram: @tpb_karl
Youtube: https://youtube.com/@tpb_karl?si=4N7Yv03mb3n9x9dM
"Make VWs hot again"
MrIcka
« Reply #31 on: December 02, 2024, 09:38:44 am »
Nice work, man
tpb_karl
« Reply #32 on: December 08, 2024, 17:51:04 pm »
Nice work, man
Thanks!  Cheesy
Back on it!
The white rear fender had a fairly long dent that got straightened out. I also welded and drilled new holes for my taillights.
Then it was time for the last fender. It was bent and had split apart at the hole for the bumper mount. But otherwise quite solid!
It found its way home eventually.
With the fenders ready, it's time to adress the rust on the body.
Horn mount and not a hole in sight (Or so I thought)
Tax receipt and first owner's name and residence. Gunvor in Lidköping
The spare wheel well is pretty rotted out and the same can be said about the little aluminium badge..
I tried blasting it off but it was a little far to gone. Are these available as newly manufactured?
On closer inspection at the horn, I discovered that the side was very thin... So i had to make a small repair.
The problem I had with the replacement panel from IGP was the hole where you take out the shift rod. On the original, the edges were folded in and on this one there was just a hole cut out. After some measuring, CADing and 3D printing, I had a giant dimple die. The 3D print did not survive.. But I got to the hole looking decent!
After some sanding and welding primer, the front was ready to receive the new wheel well. Grinding and paint..... Tt looks quite decent though. It's not 100% finished as i'm out of sanding belts and Roloc discs for my air tools..
And as a nice addition to the shelf, The same local club member that gave me the green fender has made a another donation. This time chrome T-bars. They should add at least a couple of hp.
« Last Edit: December 08, 2024, 17:53:17 pm by tpb_karl » Logged
Twin Peak Boxers
« Reply #33 on: December 08, 2024, 18:35:56 pm »
Some real nice work going on here Cool
BossHogg76
« Reply #34 on: December 09, 2024, 09:29:56 am »
The other half of the sunday update crew  Grin
Lovely work Karl.
tpb_karl
« Reply #35 on: December 09, 2024, 10:39:17 am »
Thank you!  Smiley
Lovely work Karl.
Its a great way to reflect on the weekends accomplishments! Cheesy Im glad im not the only one updating Grin
Twin Peak Boxers
tpb_karl
« Reply #36 on: December 15, 2024, 20:03:25 pm »
Sunday again, time for an update!
I’ve cleaned up the welds and thrown some primer in the spare wheel well.
Friday, I went to the garage and sorted the hole in the floor behind the drivers seat.
This repair was done "quick and dirty". I know this is not the right way to do it.. The idea is for it to pass the MOT. Later, when the car is fully disassembled and under rebuild, the body will be lifted from the pan, and both floor halves will be replaced with new ones.
Then it was time to tackle the inner wheel arches. The right side was first, and I decided to try making the sheet metal myself instead of buying an aftermarket panel.
Of course, you start with CAD (Cardboard Aided Design).
After some bead rolling, flanging, and bending over my knee, it started taking shape.
The heater channel also needed repair (of course).
The gap at the bottom of the A-pillar was welded shut, and I made my own press tool to shape the area around the nut for the fender mount. Strangely, I didn’t take any pictures of this, but I’ve filmed the whole process.
Using some 6mm metal from the scrap bin, I made a nut that resembles the original ones, which, as I understand it, were pressed into the fender edge. This one ewas welded on the back side.
Then it got welded onto the car. The fit wasn’t 100%, but I think I can adjust it later.
Next time, it’ll be the left side.
Take care!
« Last Edit: December 15, 2024, 20:06:23 pm by tpb_karl » Logged
Twin Peak Boxers
« Reply #37 on: December 15, 2024, 21:41:07 pm »
Very nice repair to the front inner wing - might have to copy that on one of my cars
BossHogg76
« Reply #38 on: December 16, 2024, 20:16:01 pm »
Great progress, love the weekly updates
Steve67
« Reply #39 on: December 17, 2024, 10:16:52 am »
great job on the body repairs.
I would consider drilling a drainage hole on the bottom of the A pillar.
I think blocked drainage in this area is the cause for most rust issues there
tpb_karl
« Reply #40 on: December 17, 2024, 17:17:51 pm »
Thanks for the positive feedback! Thats a great tip Steve! I'll have to look into that!
Twin Peak Boxers
tpb_karl
« Reply #41 on: December 22, 2024, 17:01:31 pm »
Here we go again!
I did some 3D scanning and CAD work for a friend and got paid in oil filters and Argon mix. Thanks for that!
Then I repaired the inner fender on the driver's side. The procedure is the same as on the passenger side, so here’s a bunch of pictures for you.
Thanks Steve for the tip to make drainage holes at the bottom of the A-pillar to prevent this part of the car from rusting again. After doing some research, it turns out that cars from ’61 already have a drainage hole that channels water out over the siderunners. The opening is right at the seam where the A-pillar’s panels overlap.
I had an idea to make a new hole at the front since I plan to give the car a bit of a nose down attitude. But that hole would end up inside the front fender, which would probably let more water in than out… So I’ll stick with the original drainage.
Here’s a little overview since about half of the rust repair work is done.
Probably won’t get more done before Christmas, so until next time, I would like to wish you all, a Merry Christmas!  Cheesy
Twin Peak Boxers
BossHogg76
« Reply #42 on: December 22, 2024, 21:19:25 pm »
Another great update, Merry Christmas Karl have a good one
Steve67
« Reply #43 on: December 23, 2024, 08:47:38 am »
Great craftmanship. Retaining the original drainage hole ist the nicest option :-)
Pages: 1 [2] Print
