After exams, reports, and assignments at the university, I finally got a few days in the garage—four, to be exact!
It's time to tackle the tedious work on the rear ends of the rocker panels.
First up, some more parts for the build!
Metal behind the doors and the outer section of the rear inner fender.
2-inch shortened tie rods, shock absorbers, and new rear lower quarter panels with bumper brackets.
Here's the first side to address.
After cleaning up a bit, it’s easier to see where the problems lie.
Looks like some repairs will also be needed under the heater channel before inspection.
I’ve temporarily removed the jack mount, and the car will likely remain without it.
I started with the easier task: the lower rear quarter panels. It’s only held in place with welding clamps for now.
Carefully removing rusty parts from the front inner fender corner.
The heater channel is, as usual, in bad shape, so I made a small repair.
Eventually, I plan to lift the body from the chassis and replace the entire heat channel.
Further research showed double layers of metal at the end of the heater channel toward the rear wheel well.
Ideally, I’d lift the body to fix the entire cross member, but for now, I’m patching it as best I can.
First, the inner layer.
With that in place, I could fit the outer piece—and while at it, i gotta test a T-bar!
When everything looked good, I welded it in place.
Next up: the metal behind the passenger door.
This part will need lots of love before it’s ready to weld.
I started by cutting off the bottom section and replicating the original panel, including the drain hole.
All welded nuts were removed.
The lower part now uses a stud, and the upper part will follow the same approach as the front fender repairs.
It took some persuasion to match the radii reasonably with the original.
Unfortunately, I didn’t get further this weekend, as I spent some time on the reinforcement plate for the inner fender.
I experimented with heating and hammering a bowl into a piece of metal, smoothing it with an English wheel.
I tried 3D printing a press mold with alignment pins in aluminum but failed.
I then traced the bracket onto the plate and made one from 2mm steel.
All this was testing for the final parts.
I’ll likely skip the "bowl" and go over the bumper bracket to allow for torque bars in the future without excess metal in the way.
That’s the current situation! Work continues next week.
