October 12, 2026, 07:52:33 am
The Ragtop Express
5
Topic: The Ragtop Express (Read 235792 times)
tpb_karl
Re: The Ragtop Express
Reply #90 on:
August 01, 2025, 21:25:13 pm »
So I’ve started tearing down the engine. The slotted screws for the cooling tins were not very fun to remove...
Good thing I split the case, because I found this little gem along with some other small remains from the guide for the fuel pump...
Before tearing the engine down, I measured the end play, which came out to 0.14 mm, and the main bearing saddles don’t look disastrous. But you can feel a ridge with your fingernail. Still, this engine will be reassembled with the same internals it was taken apart with. The plan is for a bigger engine in a couple of years.
Then I spent a day at a friends garage and got to borrow a hot water pressure washer, small parts washer, and the vapor blasting cabinet.
The vapor blasting cabinet works wonders. Here’s the cam plug as an example.
The heads also got a once-over.
Even the valves!
I lapped the valves to the seats before reassembling everything. The valve guides were really nice on the intake side, and a bit loose on the exhaust side, but not catastrophic.
Quite a difference!
I also blasted the pistons and all the rocker components.
Back in the garage, I was ready to assemble a short block.
…almost, anyway. I thought I could drop in the crankshaft with the distributor shaft in place—immensely difficult. If the distributor shaft has to come out, the bakelite guide for the fuel pump has to come out too. Yeah… you probably know how that usually goes...
Eventually, it was out, the case halves cleaned again, and all parts in place without issues.
I also honed the cylinders.
Then the fuel pump and carburetor got a bath in the ultrasonic cleaner and new gasket kits.
The distributor got new contact points and a light cleaning.
A pair of old valve covers from “the stash” got a coat of black paint.
This engine is by no means rebuilt—just cleaned and reassembled with fresh gaskets. It’ll live, as long as it lives. I had previously planned a 130–150 hp engine build, but I’ll build a “Stage 1 engine” first in a couple of years which can go in my bus when this one is taken apart and turned into a proper “Callooker.” I’ve got a case to send off for line-boring and have started collecting parts and sketching a build plan. Dual relief case, deep-stud, large oil pickup, and M8 case savers.
I also got a set of super-Chinese IDF 40 carburetors that will go on that engine.
The Wondervolks
1963 - The Ragtop Express
Instagram: @slinkysspeedshack
Youtube:
https://www.youtube.com/@Slinkysspeedshack
Steve67
Reply #91 on:
August 02, 2025, 19:17:15 pm »
paint blending looks great on the finished body! What product do you use for rust removal on the paint?
Looks like you're on the home straight
tpb_karl
Reply #92 on:
August 02, 2025, 21:15:16 pm »
Quote from: Steve67 on August 02, 2025, 19:17:15 pm
Thank you! It is way worse in real life
I will probably mend the doors in the future and paint the sides up to the chrome trim.
The product i used is called 'Fallout'. It is sold by a Swedish company called Arcticlean.
The Wondervolks
Youtube:
56BLITZ
Reply #93 on:
August 12, 2025, 20:41:30 pm »
Enjoyed watching your videos! Was it more work making them or more work repairing your Beetle?
Nice job... thank you!
tpb_karl
Reply #94 on:
August 14, 2025, 20:23:31 pm »
Quote from: 56BLITZ on August 12, 2025, 20:41:30 pm
Thank you! I'm glad you enjoy them!
The editing sure make the hours go by like crazy
But it is nothing compared to the hours spent in the garage
The Wondervolks
Youtube:
tpb_karl
Reply #95 on:
August 17, 2025, 19:48:40 pm »
So back in the garage after a week on vacation. Of course, I managed to do a little shopping at Custom & Speedparts in Hyllinge! Always a pleasure to visit that store!
An 8-dowel 69mm crankshaft ala CB-performance. Perfect for the upcoming "mouse-motor" 36mm, big washer chromoly gland nut, Schadek 26mm oil pump plugged for full-flow, and a few other bits and pieces.
Some pictures from the store:
Back home, the first thing on the list was to check the new piston rings, file the ones that needed it, and lap the piston against its respective sealing surface in the heads.
Once that was done, all pistons were mounted in the cylinders, ready to drop into the case.
During the week, I read "How to rebuild your aircooled VW engine", where it mentioned that exhaust valves commonly drop a valve head from the stem when worn. Since new valves were so cheap, I replaced all the exhaust valves.
With that done, it was just a matter of putting together a longblock.
I can't recommend the black valve cover bails. They were almost a centimeter too short for the valve cover. So I had to use the shabby originals. I’ve used chrome bails before and they’ve worked just fine.
Both sides done and a new oil cooler in place.
New gasket in the oil filler cap…
It’s starting to look more and more like an engine!
But here I ran into trouble…
Some aluminum hose from a local hardware store solved it.
Once on the ground, the endplay was set to about 0.14 mm (same shims as before), and a new rear main seal was installed.
New clutch disc since the old one was completely worn out. The engine was filled with oil and was now ready to be mounted in the car!
But before that, both heater cables were replaced since they had been cut… (One end of the cable is slightly longer than the other. That one goes on the car’s left side.)
Some other preparations before the engine goes in. New seals in the engine bay.
Fuel hose with aluminum filter holder.
A REALLY serious repair of one of the heater boxes with chemical metal… Budget version, deluxe...
With that, it was time to drop in the engine!
It went in so easily! Very easy when you’re two people and use a motorcycle jack. After that, wires, fuel hoses, and heater connections were hooked up.
I also finally got to install the stainless steel tailpipes. Mmm shiny…
To start the engine, we need fuel. So the fuel tank came out and got scrubbed underneath. Also blew out the worst of the dirt.
Quickly cleaned up under the trunk and installed the tank with a new rubber hose underneath. Also a new gas cap and a new gasket under the fuel sender.
The next step is power to run the starter motor so I can test start the car. The battery terminal looked like it had seen better days, to say the least…
With new cables and terminals to the battery, it was just a matter of turning the key. I removed all fuses except those for the coil and starter motor since the fenders aren’t mounted and the wires are hanging loose.
Unfortunately, no start! Even though the battery measured 6V, the voltage drop was too great to turn the starter. The battery is junk and a new one is ordered… (Yes, I WILL convert to 12V..)
A local club member came by with a spare starter motor which sounded much better than the old unit… So that went in! He also helped me do a rough wheel alignment on the front end.
Oh, how close I was to taking a test drive today! But next weekend I’ll probably be able to take a proper test drive, and then it’s getting close to inspection if everything goes as planned.
The Wondervolks
Youtube:
tpb_karl
Reply #96 on:
August 26, 2025, 17:00:53 pm »
Some setbacks, but alot has happened and progress has been made! I even think this will have to be two updates..
While waiting for the ordered 6V battery, I cleaned the floor mats. Quite a difference it made... The mats went back into the car together with new boots for the shifter and parking brake.
First off, I never managed to get hold of a 6V battery..(There appear to be a national shortage) Since I was planning to convert to 12V later, I didn’t want to buy one that was too expensive. The battery I ordered online on a Sunday still hadn’t been shipped by Wednesday. So, I canceled that order and instead ordered all the lightbulbs in 12V and bought myself a 12V battery from a local autoparts store.
I already had an electronic ignition kit lying around (Thanks to David Ruiz), and earlier this summer I got hold of an alternator kit at a good price. At this point, it would be quicker to convert the whole car than to order another 6V battery..
First, the engine came out so I could switch to the alternator.
Then the bulbs in the speedometer and fuel gauge were replaced. These bulbs had a small solder blob I had to file down. The solder kept the bulb from going all the way down into the holder, so they could twist and lock in place. This resulted in them making poor contact and flickering sporadically..
I had big problems building oil pressure in the engine, even with the 12V battery in the car. The engine coughed to life but the oil pressure warning light was still on..
To troubleshoot, I tried swapping the sensor. Same problem..
I pulled out the oil pressure sensor and put some paper outside the hole, turned the key but no oil came out..
I got a tip from a friend to feed the pump oil via the hole for the oil pressure sender. Lo and behold—It worked! Lots of oil came out when cranking.
The ignition was set and the carburetor adjusted! Cheers in the garage! I also made a spacer for the carburetor with the help of a paper template. That spacer turned out.. functional..
To be able to get out for a test drive, I wanted to get the fenders on and the rest of the electrics! Starting with the rear fenders.
Polished up the T-bars and mounted them too!
The other side as well, of course!
The license plate light got its 12V bulb and a little freshening up.
Then the front fenders slipped into place. Quite a bit of trimming was needed to get the trim strip around the end of the fender right.
Washed off the running boards since they had gotten really dirty from lying on the shelf so long. I took the opportunity to apply rubber/tire treatment to them as well. Mounted the stainless trim and put them on the car. Very pleased with the fit of both running boards and fenders.
In went my sports seat that I made in 4th grade woodshop, and off for a spin around the neighborhood!
I can hardly believe it’s my car. It changes so insanely much just by getting fenders and working lights on it.
To be continued...
The Wondervolks
Youtube:
Steve67
Reply #97 on:
August 27, 2025, 06:24:12 am »
wow, the car looks absolutely great finished from the outside.
Outstanding job
Reply #98 on:
August 27, 2025, 07:51:16 am »
Quote from: Steve67 on August 27, 2025, 06:24:12 am
Outstanding job
Totally agree, cars look really good
tpb_karl
Reply #99 on:
August 28, 2025, 06:31:12 am »
Thanks guys!
I finished up my front license plate bracket and mounted it, removable with just a single thumbscrew. Doesn’t look too bad!
I also designed and ordered a rear bracket using the same 3D-printed mounts. This one went on the engine lid with a rubber sheet to protect the paint.
I've started sketching up a press tool to make “US-style frames” that fit these modern Swedish plates. That’ll be a future project though…
Next step was to scrub the interior and get the car fully assembled.
Didn’t take many before/after pics, but I think the sun visors give a good idea of how filthy it was.
The headliner also came out nice.
Seats and door panels got a proper wash too.
After that I could finally start laying in all the carpets and interior pieces.
The car finally earned its TPB-member sticker too. Slightly smaller than the regular version and mounted inside the glass. These will be the only two stickers going on the car.
Next day was the first proper drive—to the gas station for a fill-up, about 10 km each way.
The trip there went smooth. Once there a couple of issues popped up: the gearbox is spewing oil out over the front mount, and I need to raise the front end since I’ve already rubbed down to bare metal in the fenders…
On the way back to the garage the car started running really rough. Oil pressure light also came on at idle.
Managed to limp back to the garage, to figure out what went wrong and what to do next.
Had to cancel the inspection I had booked for the next day.
After checking the gearbox and linkage more closely, I’m pretty sure the oil is coming from the vent/overflow at the top of the nose cone. It sprayed oil on the Bowden tube, but the bakelite plugs and shift linkage are dry.
Before inspection, the horn also had to be replaced since the old one was dead. The new one is way sportier and lighter than stock!
As for the engine not holding oil pressure when warm at idle, I’ve got one last shot. Since it’s been struggling to build pressure from the start, the issue is probably the pump. Either I used too thick of a gasket between the pump and cover, or the pump is just worn. I also ran too thin of an oil, 10w-40. I had 2.5 liters lying around and wanted to use it up, so I figured I could burn it during break-in…
Plan now is to swap in a new pump, mount it with a thin gasket (or just sealant), and run 20w-50 oil. On top of that I need to bleed the brakes and grind down the ridge on the rear drums. If all goes well, inspection might happen Friday or Monday.
The Wondervolks
Youtube:
Steve67
Reply #100 on:
August 28, 2025, 14:52:05 pm »
most of the engine gasket sets have too thick gaskets for the oil pump cover. That might be a reason for the low pressure at hot idle conditions as well as the poor pressure build up, 20W50 will off course also help.
As last option you could think about using a 26 mm pump instead of a 21 mm pump as interim solution until the new engine is finished. They are availbale for 6 mm studs at CSP and others.
Interior came out really nice, the license plate bracket is great. I definitely need something similar for my 67
tpb_karl
Reply #101 on:
September 01, 2025, 19:52:23 pm »
Lucky I film almost everything. I was able to go back and watch myself install the oil pump. Caught red-handed! Here you can see me putting the thick gasket between the pump and the cover.
The oil pump puller deformed before it managed to budge the pump from the block. I also measured the axial play on the gears in the new and old oil pumps with feeler gauges. The new pump was between 0.05 and 0.1 mm, while the old pump that was already in the engine was less than 0.05 mm. So I kept the old pump and mounted the cover without a gasket. Only Curil T2. The pump was packed with grease to help during startup.
I also Designed and 3D-printed a tool to find and mark TDC and 30 degrees on my pulley using the original marks at 7.5 and 10 degrees.
I then changed the bushing in the distributor to the one that gives 20 degrees advance. Then I set the ignition so I have about 28 degrees at roughly 3000 rpm, which landed at about 8 degrees at idle.
The carburetor was also cleaned and fitted with a larger jet of 127.5 since I assumed it was originally jetted for old gasoline without all the 10% ethanol we have here.. I also switched to 20w-50 oil and checked the valve clearances.
After this it was startup time! The oil pressure light went out on the second turn of the key with just the starter motor. The car fired up and I took another trip to the gas station. I removed the T-bars in case they would complain about them at inspection for some reason..
I drove the car back to the city to my apartment. So far no problems! I also swapped to the large license plate in the front that I’m supposed to have in according to the registration papers.. Because the next morning it was time for inspection!
The inspection went fine except for two unnecessary faults. The low beam was aimed too high and CO was too high… I had 7.0 and the limit is 4.5.
I went to the garage during the weekend, swapped to a 120 jet, adjusted the headlights lower, and gave the car a well-deserved wash.
The re-inspection on Monday went really well! The headlights were aimed low enough and I measured 0.1 in CO! I’ll probably switch to a slightly larger jet.. like 122.5 or 125.
So now the car is fully street legal and completely ready to use and enjoy! Now it’s officially a rolling project!!
I had also scheduled a wheel alignment the same day. I swapped back to the small front license plate and reinstalled the T-bars.
I still have some small fixes to do, but mainly I’ll be putting miles on the car to discover any potential issues before the trip to the Netherlands on September 18th!
The Wondervolks
Youtube:
tpb_karl
Reply #102 on:
September 02, 2025, 20:45:27 pm »
And the fourth episode is finally finished.
https://youtu.be/37rcueZyJJ8?si=hrW9RZfOnYhlbSza
The Wondervolks
Youtube:
tpb_karl
Reply #103 on:
September 14, 2025, 16:20:32 pm »
So far everything seems to be working fine. I’ve mostly just enjoyed the car. Went for some Twin peak boxers Wednesday-burgers to reveal the car to the local club. As well as a Cars & Coffee-event with two members from the club at the local racetrack, where two of us took home a small trophy.
A local club member bought a cheap tachometer at a swap-meet recently. Since I had previously mentioned that I had been looking at tachometers, he let me buy it from him for the same price. True friends!
A 5" Autometer 8K without shiftlight.
Tried it out at the office and it seemed to work just fine!
It needed some kind of mount so the 3D printer got to work a bit and voilà, I had a clamp. This one was then made in 2 more versions before I was satisfied. I’m still not entirely happy though.. Especially not with the print quality..
From the boating section at the local hardware store I bought a stainless shackle. I figured the screw from this could fit nicely for the mounting. The existing hole in the dashboard was used and the gauge fit like a glove!
Reluctantly, yet another hole was drilled for the cable..
Wired up the gauge with connectors from Amazon and secured it with a 2A fuse on the lead wire from the ignition. (Unfortunately, I couldn’t find a green cable for the coil signal so it ended up being gray..)
The lighting for the gauge is on its own wire and since I took it from the fuel gauge lighting, the dimmer works as well! Luxurious!
I also made a new mount that moves the tach a bit lower, but it still hits the glovebox when opened..
Wrapping up this post with some edited photos I took the other evening. Cheers!
This week it’s the Airmighty Show in the Netherlands. My trip down there departs from Sundsvall on Thursday. That gives us all of Thursday and Friday to cover 1650 km (1000 miles). Hopefully the car holds up, and maybe we’ll see you there?
Last Edit: September 14, 2025, 16:22:17 pm by tpb_karl
The Wondervolks
Youtube:
Reply #104 on:
September 14, 2025, 18:39:55 pm »
the car looks really good. well done. I keep being amazed by what and how you did amp of this . have a good trip.
Steve67
Reply #105 on:
September 14, 2025, 20:23:34 pm »
the car looks gorgeous, especially when looking at what you started with a little bit more than one year ago.
Curious to see it on Saturday.
JezWest
Reply #106 on:
September 20, 2025, 07:35:30 am »
That's a good looking car, amazing work. I hope you're enjoying driving it!
tpb_karl
Reply #107 on:
September 25, 2025, 20:14:16 pm »
Time for an update! Tuesday before the Airmighty show, the Express had been sitting in the garage since the day before. The gearbox was definitely leaking too much to make it 3,200 km... I checked the level and it was definitely low...
The only thing I could think of was that the plugs in the gearbox were bad and the ventilation hole clogged... Tried poking around a bit in the vent hole with welding wire. Luckily, I had 3D printed a set of plugs in different diameters this spring which I replaced the existing ones with. These were fixed with Permatex...
Hoping that solved my problem, I adjusted the valves and changed the oil. Unfortunately, My friend who i was supose to be traveling with got sick on Tuesday. So I decided to head down on my own and start the trip already on Wednesday after work.
Work clothes, jack, jack stands, tools, and spare parts packed.
Made several stops on the way down. First in Gävle to visit Icka and Jimmy in the garage. Then I stayed overnight near Västerås.
Next stop was in Helsingborg where I of course dropped by CSP in Hyllinge. Thanks to Nils Komet and family for the accommodation!
On Friday morning, the ferry went to Helsingør and then the next ferry to Puttgarden from Rødby.
Also made a stop at CSP in Hamburg, nice showroom!
Finally, 1650 km or 1025 miles later, I arrived in Oldenzaal where I checked in at my AirBnB. First thing I did after checking in was to head to the self-service wash and rinse off all the insects from the car...
SATURDAY and Airmighty show!
Janik Otto caught me on camera while I was looking for a spot in the Callook line-up.
Absolutely incredible cars on site. Both inside the hall:
(First one might be familiar)
And outside as well:
Got properly star-struck seeing the Red zeppelin roll in as soon as i got out of my car! And seeing Dean Kirsten himself walking around the area!
There was also a small swap meet on the grounds. Of course, you got caught up in the atmosphere, and i had to buy SOMETHING... Right?
DFL also organized a cruise-night at McDonald’s parking lot in Enschede on Saturday evening. Amazing cars there too and very nice company. A nice sticker was on my car when I was about to head home. Thanks for that! Other Swedes down there were Lars Häsä and Janne Hernebro, whom I got to know during the weekend. Thanks for a great weekend guys!
Sunday was the same and I got to meet both BossHogg76 and Steve67! Great to meet you guys!
Also huge thanks to my guardian angel who closed my ragtop when it started raining while i was inside the hangar! I owe you a few beers!
After an incredible event, the journey home began. The first day I drove to Puttgarden and the second day to Nyköping. The whole trip home went flawlessly except that it spits out a little oil and rattles a bit more than before I left. The 1200 had to work hard, but of course I’m now very motivated to build a new engine with fresh bearings and preferably a bit more power.
Once home, I just had to test the shifter. 60% shorter throw than stock make the gear changes really quick. Doesn’t look too bad either. But the idea of cutting the original floormats for the sake of the shifter doesnt sit right with me. Looks like a carpet kit is in order..
A memorable weekend and I’m already eager to head down again in 2027. But hopefully with a different engine and transmission..
The trip was absolutely worth it!
The Wondervolks
Youtube:
Reply #108 on:
September 26, 2025, 06:11:39 am »
Your car fitted right in, in the line up.
Looked beautiful.
Glad you enjoyed the show. I agree on you the amounth of quality cars was amazing.
Regards eddie
Reply #109 on:
September 26, 2025, 07:40:06 am »
That's a proper test drive
Very cool that you drove all that way & back on your own in a old VW, sounds like a really fun trip, well done
tpb_karl
Reply #110 on:
October 15, 2025, 07:03:01 am »
Thanks Eddie & Richie!
The fifth episode is out, and contains a few short clips from the Airmighty show.
https://www.youtube.com/watch?v=79hC7BRgu7A
The Wondervolks
Youtube:
Odyssey
Reply #111 on:
October 15, 2025, 11:37:58 am »
Quote from: tpb_karl on October 15, 2025, 07:03:01 am
Brilliant stuff
Steve67
Reply #112 on:
October 16, 2025, 06:46:24 am »
I enjoyed the restauration videos, good job
It was nice to talk to you at the Aimrmighty Show
lawrence
Reply #113 on:
October 24, 2025, 01:53:47 am »
Your Part 5 video was recently recommended to me on Youtube, so I watched it and Parts 1-4. The metal patch work is very impressive, and I appreciate the care taken to preserve the honest wear the car has accumulated, while reconditioning everything. Looking forward to more updates, keep up the good work.
"Happiness is a Hot VW!"
tpb_karl
Reply #114 on:
October 25, 2025, 10:09:05 am »
Thank you all for the kind words!
Quote from: Odyssey on October 15, 2025, 11:37:58 am
Brilliant stuff
Nice too see you've found your way to the Callook forum!
Quote from: Steve67 on October 16, 2025, 06:46:24 am
Thanks Steve! It was nice meeting you!
Quote from: lawrence on October 24, 2025, 01:53:47 am
Nice to see the algorithm working for me
Thank you for your kind words, i'll keep making videos for sure.
A small update before winter.
The Express was driven down to my parents before winter and will be left alone until spring.
Before it was put away, I received a delivery of new rear brake drums that will be replaced in the spring. German-made from Zimmerman.
This winter I’ll mainly be working on my -63 bus, but the plan is a bit of “handling improvement,” if you can call it that.
I’ve received OEM bus snubbers and a camber compensator from CB Performance.
I’ll also be doing some touch-ups the VDM steering wheel and the Berg shifter.
A couple of purchases I haven’t documented yet are a pair of ported 113 heads with 40–35.5 mm valves that I bought on the way home from Holland. What I’ll do with these, I have no idea... Maybe an IDA engine?
The weekends after Airmighty show theres a Swedish VW swapmeet, I bought a turn signal stalk for the small taillights I have lying around.
Otherwise, nothing new! I buy small bits and pieces for the engine build now and then. Of course, I’ll update when some pieces of significance come in.
Otherwise this thread will be fairly quiet for a while.
Last Edit: October 25, 2025, 10:11:29 am by tpb_karl
The Wondervolks
Youtube:
tpb_karl
Reply #115 on:
December 09, 2025, 08:37:14 am »
Some more pieces for the Express. I've gotten a hold of a NOS decklid handle without a lock. Still unsure if it's for bus or bug though.. (or both)..
I purchased a CB hex bar linkage on a swedish auction site. However it is missing the filters.
Regarding filters i've decided to go with the K&Ns. As they come in different heights i've modelled and 3D-printed some "dummys" for testing what will fit the engine bay.
The other day i took delivery of a set of thick-wall 92s and Grant piston rings.
Previously i've been talking about building a "mouse motor" but at this point its starting to be more in the size of a cat.. Or a Badger?
Whatever the animal i think the next big purchase for the 1835cc will be heads.
Until then!
The Wondervolks
Youtube:
tpb_karl
Reply #116 on:
February 07, 2026, 21:31:44 pm »
Very little progress has been made. I've been traveling alot for work lately so not much wrenching going on. But some shopping!
I've started working on the Monstertach, since it was looking a bit tired and dusty. Kind of a hassle since the trim ring is folded over the housing.
Using a 3D-printed tool of my own design i was able to fold the edge over and pick it apart.
The sticker on the inside of the glass has seen better days. So i've designed a new one to replace it. It has not been ordered yet as the MOQ from "Stickerapp" is about 80 pieces... Well, at least i'll have spares..
Some shopping then! Some engine parts have started to roll in.
Titanium retainers from CB-Performance
Web 163 camshaft
11/32 dowel pins from Gene Berg
A licence plate holder from HotVWs made for american plates. I'll order a black and yellow showplate soon.
And a transmission! Kindly donated from a friend. I have a few transmission to put together into one. And my plan is to do this myself.. This donated transmission has a 4,125 R&P. Needs a superdiff! (MIGHT have one on its way)
More stuff is on its way from several places. Stay tuned.
The Wondervolks
Youtube:
tpb_karl
Reply #117 on:
February 14, 2026, 09:31:12 am »
Some more parts have shown up.
Equalizer steel pulley (Bling bling)
I had previously purchased a 36mm Empi Gland nut but i've now upgraded to a 38mm Chromoly unit from Scat.
Finally a superdiff and HD sidecover have shown up.
Now im waiting for the heads to arrive.
Cheers!
The Wondervolks
Youtube:
tpb_karl
Reply #118 on:
March 04, 2026, 20:12:37 pm »
I finally received my stickers for the tachometer!
Scraped off the old sticker and put the new one on. But something doesn’t look right..
Apparently, the cut comes out mirrored when you order stickers from stickerapp with adhesive on the front side.. So I’ll just have to order new ones.. It hurts a bit to throw away all 40–50 of them, however many there are… Disappointing, to say the least.
Some better news is that Servais Engineering has machined my engine case for the upcoming engine build!
The case was pretty beat up and needed quite a bit of love.
Line bored with new main bearings
Decked in relation to the crankshaft centerline and opened up for 92 mm cylinders, as well as drilled, tapped, and plugged for all oil galleries
Drilled for a full-flow oil system with the case clearanced for the fitting to fit behind the cooling tin behind the crank pulley.
Previously, someone had snapped off the oil pressure switch in the case. Peter managed to remove it, but since the threads we're damaged in the case, the hole was drilled out to M12x1.5, which fits VDO’s pressure sender with idiot-light.
All mating surfaces for M8 and M12 nuts on the case have also been resurfaced. All case savers have been countersunk as well. An additional upgrade was adding studs in the two lower holes in the case toward the transmission.
The case received a thorough overhaul and will be water blasted and carefully cleaned before it’s time to start measuring everything.
A huge thanks to Peter at Servais Engineering for a great job, and for kindly taking both photos and video to contribute to future YouTube episodes!
Here's a link to his facebook page:
https://www.facebook.com/servaisengineering
The Wondervolks
Youtube:
tpb_karl
Reply #119 on:
March 12, 2026, 09:48:19 am »
The heads finally arrived from Slide Performance! UPS really messed with me on this one..
These are the AA-500 series heads with 35,5 - 32 mm SS valves. I've had them flycut for my thickwall 92s and CCd to 48cc. The have also been given a valvejob. I've yet to disassemble the heads and inspect the seats.. They came with CB-performance HD Single springs, chromoly retainers and keepers. I will however use Oteva 75SC Single springs from Logmech and Titanium retainers.
What these need are blending under the seats and some unshrouding around the valves in the chambers.
I'll also have the valves ground to make sure they're perfectly round and i'll also have the intake valves back-cut.
In other news, the tachometer bracket has entered prototyping.
Last Edit: March 13, 2026, 09:29:51 am by tpb_karl
The Wondervolks
Youtube:
5
