November 03, 2026, 00:27:25 am
gearbox build
Topic: gearbox build (Read 6590 times)
danny714
gearbox build
November 25, 2007, 16:40:08 pm »
Thinking of putting together a close ratio type 1 box , got my head around most of what i need to do , got tools and jigs on the way , but a bit stuck on how to set up the pinion depth ? Any help would be appreciated
Reichspeed aircooled 0774 830 7137
Reichspeed.com
Vwdrc pro sponsor 2012
facebook - Reichspeed aircooled
Re: gearbox build
November 25, 2007, 18:49:48 pm »
Without the expensive pinion depth tools VW made, the method is to check the tooth contact pattern with prussian blue. If you go to this site, there is plenty of info in the archives:
http://www.shoptalkforums.com/viewforum.php?f=50
Here is a topic that will get you the starting point for the pinion shim:
http://www.shoptalkforums.com/viewtopic.php?t=105240
Once you have a starting shim, go here to see how to check the contact patterns:
http://www.shoptalkforums.com/viewtopic.php?t=91613
Last Edit: November 25, 2007, 18:53:47 pm by Bruce
danny714
Re: gearbox build
November 26, 2007, 21:26:27 pm »
cheers , some very usefull info there, are shims easily available and where from ?
Reichspeed.com
Re: gearbox build
November 27, 2007, 08:22:59 am »
Quote from: danny714 on November 26, 2007, 21:26:27 pm
Other dead gearboxes.
