September 22, 2026, 11:52:08 am
| |-+  For sale!
| | |-+  Oxyboxer 103x84 SOLD !!!
Author Topic: Oxyboxer 103x84 SOLD !!!  (Read 7309 times)
Fredy Kucmocht
« on: April 06, 2025, 13:03:39 pm »
2.1 vanagon waterboxer case,machined by Geers engineering
It has been set up for type1 style lifters,align bored for all type 4 mains,has rear bronze thrust conversion,water jackets removed & been decked etc[head stud inserts converted for 10mm head stud use] to use 4inch aircooled cylinders.Comes with narrowed modified german KS type 4 bearings .
84mm flange crank,all type 4 mains/chevy rod journals with matching flange flywheel
Scat 5.5 h beam rods[3/8 arp 2000 bolts]
Kennedy stage 1 cover
All match balanced
Flange seal,
Webcam Custom : Duration 304 ,  @.50  Valve lift 0.573“
Thorsten Pieper Tool Steel lifters
Pauter 1,4 rockers
Autocraft heads ported by Mexxspeed  52x44 Titan valves [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
JE custom 103mm pistons[with pins/rings and clips]
AA 4inch cylinders bored to 103mm and match torque honed to the JE pistons[attachment=
Price 7800€
« Last Edit: August 04, 2025, 05:21:15 am by Fredy Kucmocht » Logged
Fredy Kucmocht
« Reply #1 on: July 14, 2025, 20:18:55 pm »
All match balanced
Flange seal,
Pauter 1,4 rockers
Only one race since the last rebuild
Price 7800€
