October 25, 2026, 08:09:48 am
352327 Posts in 28959 Topics by 6929 Members
Latest Member: Hanibal1
| | |-+  Improving Ride Quality
Author Topic: Improving Ride Quality  (Read 43680 times)
dive!dive!
« on: August 26, 2025, 09:53:54 am »
Hi All
Been away from this hobby for a while. Had my '71 T1 for close to 40 years now but its not seen much attention the last few years. Now retired and have time for it. Fully rebuilt some time back, its immaculate and garaged, I wont bore you with all the details but the engine is a stout 1776 built on an Autolinea Al case, fuel injected through 38mm ITBs and does about 130hp on the dyno. I'm not really happy (and never have been) with the ride quality. At A road speeds (50-60mph) its pretty well behaved but slower speeds on less than good surfaces it feels 'bouncy' to me, especially on the front. Suspension set up is as follows - Front has a 2" narrowed beam with adjusters, dropped spindles, heavy duty anti roll bar. Rear (swing axle) has 24mm torsion bars, adjustable spring plates. The car is lowered, but far far from extreme. Tyres are 155 15 on the front and 195/65 15 on the rear. I've been running it with standard shocks and just changed to the GAZ adjustable ones. I have these set on the softest setting front and seven clicks harder on the rear. Seems better but its not as good as I would like.
Thoughts on improving this would be much appreciated.
Steve
karl h
« Reply #1 on: August 26, 2025, 12:45:30 pm »
the best ride i ever had was my old 67 with narrowed beam, dropped spindles and red konis all around. my 63 now rides good too with bilsteins in the rear, but a little stiffer.
i have short bidlsteins valved for a lowered front and will try them soon. its kind of a trade off between ride quality and how fast you want to go through corners IMHO
Felix/DFL
« Reply #2 on: August 26, 2025, 14:37:57 pm »
Hey Steve,
I would  definetly change the HD roll bar to an original one so that one wheel can move easier.
Those HD one's are way to stiff...
Check that the axle moves free and is not too stiff itself.
Red konis are superb front shocks, those work brillant,
Another big point is too much tire preasure front & back.
At my notch I am running max. 1.6 & 1.9bar, with a bug you could even go lower.
Best Greetings, Felix
andrewlandon67
« Reply #3 on: August 26, 2025, 16:04:43 pm »
I'll be another vote for the red Koni Special-Ds, nothing has made a bigger difference than when I went with those. Another good change is some meatier front tires, when I went up to 175/65r15 my car almost completely changed, it's not bouncy or jarring, it's just smooth over everything.
14.877 @ 88.85 mph
He who waves at 911 drivers
dive!dive!
« Reply #4 on: August 26, 2025, 17:49:05 pm »
Thanks all for some quick input. Tyre pressures are pretty low (!) 1.3 front and 1.6 rear, so I dont think I can go lower there. I do have space for wider tyres on the front as I currently have a 6mm spacer so they fill the arches just right, so thats worth looking at. I do suspect the anti roll bar - it is indeed a big chunk of steel! I will see If I can find a std one for narrow beams. I do have a set of Koni Red somewhere....I recall trying them 30 years ago or so but that was without the current beam and rear torsion so could re visit those. May take me a while to do all that but will report back. Any other ideas are welcome!
I know it is a 50+ year old car and wont ride like a modern one, but I think I can do better :-) Its really about comfort so we use it more rather than speed into corners - I'm nervous of that anyway and I have other cars that will do that much better!
Steve
andrewlandon67
« Reply #5 on: August 26, 2025, 20:53:37 pm »
Between the Konis and the bigger tires, my car became better at going over railroad crossings than my Saab, and while handling is also greatly improved, the ride improvement is possibly my favorite thing I've done to my car.
14.877 @ 88.85 mph
« Reply #6 on: August 27, 2025, 06:10:31 am »
I agree on the Koni / Billstein, rides much better.
But switching to IRS rear made it also a lot less bumpy than the swing ale.
Enjoy it a lot more than before.
Felix/DFL
« Reply #7 on: August 27, 2025, 09:58:11 am »
Ah ok, that's on the lower level with the tire pressure. I would maybe test a bit higher preassure at the back...
Not enough weight is also an effect that it rides bouncier, espacially with bigger torsion bar's at the back.
Put a spare tire at front if you don't have at this moment, and throw in some people or stuff and check how it behaves.
Track measurement front & BACK is spot on?
How old are the tires?
dive!dive!
« Reply #8 on: August 27, 2025, 10:21:07 am »
@felix/DFL : Tyres are old...no cracks etc but they have to be 20 years? Tracking is good. I put the 24mm rear bars in because the originals were sagging and the engine is heavier than stock. I cant see a standard size front anti roll bar for narrowed beams listed anywhere. I may have to narrow the original.
@andrewlandon67 : Do you have a reference for the Koni shocks ? Part number ?
Thankyou
Steve
andrewlandon67
« Reply #9 on: August 27, 2025, 16:23:59 pm »
Thankyou
Steve
Steve, the fronts are 80-1787 and the rears are 80-1350, at least for a balljoint car.
14.877 @ 88.85 mph
Steve67
« Reply #10 on: August 27, 2025, 18:33:11 pm »
my 67 has a 2 inch front axle, dropped spindels and red Konis, camber is set to -1°.
I am very happy with the setup in the front.
I managed to assemble a standard roll-bar to the narrowed beam, no need for a special part on my beam.
Maybe you can give it a try before you buy a narrowed one.
Felix/DFL
« Reply #11 on: August 27, 2025, 21:18:10 pm »
Even if there are no cracks visible 20yrs old tires are rock hard and will drive like that!
You better invest in some new contact points to the street. Pirelli's for example are superb tires and keep soft for a very long time.
lawrence
« Reply #12 on: August 28, 2025, 02:20:27 am »
its pretty well behaved but slower speeds on less than good surfaces it feels 'bouncy' to me, especially on the front.  I have these set on the softest setting front and seven clicks harder on the rear. Seems better but its not as good as I would like.
Steve
Have you tried adjusting the settings, especially on the front shocks? Seems like the softest front setting would cause the bouncing described. It would also be best to increase the tire pressures a bit, front and rear. Too little air will add bounce and wobble to the ride.
Some good recommendations thus far. In the distant past, changes that improved the ride of my car were: tire pressure adjustment (20psi front, 30psi rear) and factory oil shocks in replacement of much to stiff silver, lowered KYBs.
« Last Edit: August 28, 2025, 02:25:00 am by lawrence » Logged
"Happiness is a Hot VW!"
dive!dive!
« Reply #13 on: August 28, 2025, 17:35:24 pm »
@andrewlandon67 : Thanks!
@steve67 : I have found the original sway bar. I will see if it fits, if not, 10mins work for me to narrow it.
@Felix/DFL : Tyres....noted!
@lawrence : Yes I tried a few settings as they are so easy to adjust. Started +3 on the front, not too bad, tried +7, undriveable!, now on 0 but think the sway bar is affecting things. Rears are on +7 , tried +5 but felt it too soft.
Good suggestions all. Thanks!
Plan of action is to 1)change from sway bar 2)optimise shock settings 3) change tyres (they need it anyway) 4) re optimise shocks 5)Try the Koni reds
« Last Edit: August 28, 2025, 19:16:08 pm by dive!dive! » Logged
dive!dive!
« Reply #14 on: September 08, 2025, 16:27:45 pm »
Quick update: Narrowed the original sway bar and have that back on the car. Drove 100 miles (I had some errands to run, and it was dry!) , front shock settings from zero to plus one click. Ride is improved but I still think it could be better. I will play with tyre pressures then change the tyres next.  Its sometimes hard to be 100% objective when you have just jumped out of a very modern car, which is hardly a fair comparison!
Steve
