September 28, 2026, 11:45:32 am
| | |-+  Small powerhouses and old school
Pages: 1 ... 27 28 [29] Print
Author Topic: Small powerhouses and old school  (Read 1829084 times)
Joel Mohr
« Reply #840 on: June 19, 2018, 15:56:13 pm »
Yes! Jose at DPR said it be stronger than adding counterweights to a 40 hp crank...
SEE YA AT THE RACES!!!
slowlearner
« Reply #841 on: August 31, 2018, 09:51:15 am »
1672, 65 x 90.5, 46 x 36 Clyde Berg large oval ports, Hemi cut, detailed chambers, Berg short IDA manifolds, Berg 37/42 venturis,  9.9 to 1, Web 86b, Mohr Performance 3 step header, makes 155 on 91 octane....
Love to see a vid of that running. What's it going in?
Joel Mohr
« Reply #842 on: September 17, 2018, 18:19:33 pm »
It's in my Puma...
1946vw
« Reply #843 on: September 27, 2018, 16:21:58 pm »
alex d
« Reply #844 on: September 27, 2018, 21:24:15 pm »
any input on this? Shocked Shocked Shocked Shocked Shocked
1946vw
« Reply #845 on: May 09, 2019, 20:45:46 pm »
G/D goes 8.51 149.86 300 plus hp 1700
dangerous
« Reply #846 on: May 09, 2019, 22:38:42 pm »
Awesome 1946VW Wink
What is the weight?
..or weight/ci ?
1946vw
« Reply #847 on: May 09, 2019, 23:35:19 pm »
104 cid 870 lbs
1946vw
« Reply #848 on: July 16, 2019, 18:47:26 pm »
Woodburn
« Reply #849 on: July 16, 2019, 20:41:17 pm »
I can just make out Comp Eliminator on the trophy - tell us more! That is a Wally, isn't it?
1946vw
« Reply #850 on: August 06, 2019, 19:38:55 pm »
Seattle 2019
Abadco2
« Reply #851 on: August 06, 2019, 23:26:22 pm »
Fantastic, well done!
JeeWee
the Netherlands
« Reply #852 on: May 03, 2020, 09:47:33 am »
awesome topic which I enjoyed last week during my holiday... at home. Fantastic to read about 140hp per litre from these engines, incredible work and lot's of respect! I was already happy with my 1192 36hp engine putting out 48.9hp, but now I am wondering... with some clever blueprinting what is possible with that pre war design engine and modern thinking...
Anyhow any updates on cool projects?
brewsy
« Reply #853 on: May 03, 2020, 11:09:29 am »
Check out the 36HP class in LSR.
Those peeps are doing some big stuff with those old engines..
Glauco
« Reply #854 on: August 22, 2020, 16:08:41 pm »
Anyone got more info on the new JPM 1600cc challange engine?
Not sure if it's ok for me to post it here, but his work is quite impressive!
brewsy
« Reply #855 on: August 24, 2020, 20:50:37 pm »
WOW.
Somebody post some dyno videos quick!!  Cheesy Grin
mymedusa
« Reply #856 on: September 19, 2020, 20:07:14 pm »
Hi folks,
I build and testet a 1285cc turbo
K03 7074 twin scroll turbo, water intercooler system, water meth spray, MS1extra efi
AB engine
77mm stronger pistons, stock barrels
Stock ballanced crank
Heads slightly portet (35x33)mm stainless valves
Jpm single valve springs plus scat inner spring
Cromo puschrods
Cb H-beam rods 20mm pin
TCS20 engle camshaft, stock rockers 9,2:1, 102oktane fuel
Nothing real special on the engine intselfe
225hp@6800rpm 260nm@3500rpm at 1,35 bar
250hp@6300rpm 293nm@3500 rpm at 1,8 bar flatten to 1,6bar
Very streetable, full body car with 205/70 r15 tires
0-100 in 5,01sec still to improve
3.88, 89 4th. Pro street
Slow 13,77s at 1/4 mile @169km/h full body street tires
Also still to improve because of bad 60feet times far over 2 sec.
Real fuel saver try to reach unter 7l/100km
On the list: destroyed axle and later 1. Gear both at the 1/4 mile track.
« Last Edit: September 19, 2020, 20:26:07 pm by mymedusa » Logged
brewsy
« Reply #857 on: September 20, 2020, 15:44:31 pm »
Hi folks,
AB engine
Cromo puschrods
AWESOME!!
Im guessing 102 Octane isn't 'street' fuel??
Marc
mymedusa
« Reply #858 on: September 20, 2020, 20:20:44 pm »
In germany it is. I just need it for the 250hp.
Chris
« Last Edit: September 20, 2020, 20:28:36 pm by mymedusa » Logged
DRED
« Reply #859 on: September 20, 2020, 20:52:55 pm »
hello chris,
can you tell me more a bout the tcs 20?
it's an ils profile, what did motiver your choix, do toi think you can use it with 1.25 rocker. would you change it and by what?
brewsy
« Reply #860 on: September 21, 2020, 09:57:32 am »
Chris
Hi Chris,
Thats pretty cool. I 'think' our (UK) street best is Shell 98.
Really like your exhaust. It looks like you have paired the cylinders front & back to give 1+3 & 2+4 cylinders and then 'siamised' them together to keep the gases separate to the twin scroll entry, correct?
Can I ask where you have the water/air radiator? Is it at the front of the car and do you run the water pipes inside or outside the car?
Marc
mymedusa
« Reply #861 on: September 22, 2020, 10:13:50 am »
The tcs20 just matched my ports best. I wanted a range from 3500-7000rpm cam and port can do this. On the track i have fist till 8000rpm,
Sec. till 7500tpm and 3dr into finish line close the max hp.
98okt fuelnis std best fuel here too, but you can buy schell 100oktane and aral untimate 102oct. Fuel.
With the header its right. Because og the shape of the inlet into the turbine i build the true header with a friend exactly how you told. 4-2 and 1-3 and put a plate into a pipe to get all matched.
My whater tank is unter the back seat, pump is close and outside and radiator in floored under the car. Its ok. But not best solution.
DRED
« Reply #862 on: September 22, 2020, 19:36:45 pm »
ok, Thanks Chris. i'm currently building a 2074cc turbo with small cylinder heads for a street car, and i have a tcs20 on the shelf but I wasn't sure if it's a good choice..
brewsy
« Reply #863 on: September 23, 2020, 11:19:39 am »
Nice!
Im intending to see if I can get 2x coolers up the front for water and oil but had been considering only a water circuit . Then using a water-oil oilcooler sandwich adaptor. The water circuit would then cover turbo air-water intercooler, turbo water cooling and oil. That sounds like it would help with rapid engine oil warm up however I have a feeling that the water in the cooling circuit would only go as low as 80-90C and mean that the turbo intercooler wont be able to get the 'cool' air any lower than that temperature?
Would anybody agree/disagree with that?
johandryselius
« Reply #864 on: September 29, 2020, 21:29:21 pm »
I run a TCS30 on my 1600 Challenge engine - unporteded heads and original valves and it produces 312 Wheel HP@ 2bar (29PSI). When I ran my quickest pass, I ran 2,5 bar (36PSI) on gear 2-4.
Johan
1600cc Challenge Porsche 356:
1600cc Challenge Buggy:
Europes quickest ProStock VW:
gracey
« Reply #865 on: November 15, 2020, 09:38:34 am »
Is there a tuning reason for using 36mm venturi's in 48IDF's instead of using 44IDF's?
I'm thinking better signal, or maybe the 48's were available?
PPRMicke
« Reply #866 on: July 14, 2025, 22:53:01 pm »
Hi everyone
Are there any new engine projects
Would be nice to know if anyone is working on small valve sizes in any small engine volume projects [ Attachment: You are not allowed to view attachments ]
Jokke
« Reply #867 on: October 06, 2025, 17:47:45 pm »
So im putting together an ”old school” 1679 for my early cal look bug im building and wondering if any yall can give me some pointers for what I need/dont need.
Currently have
40x35.5 valves ported DP heads
Welded CW 69mm crank
Weismann cast lifters all weighing in at 98g
DDS rocker covers
Gene Berg oil pump cover
Gene berg and early empi magnesium deep sump (planning on using the empi sump to keep it oldschool)
DDS clone throtle linkage
Engle W120
Dual 48 IDA
DDS IDA intakes
Mahle forged 88mm pistons thickwall
010 Distributor
Bosch Blue coil
Refurbished Original vw fuel pump
