June 07, 2026, 17:29:14 pm
352167 Posts in 28908 Topics by 6919 Members
Latest Member: mvptkfjb
| |-+  For sale!
| | |-+  Autolinea Casing, 86 mm flanged crank, H-rods, etc.
Author Topic: Autolinea Casing, 86 mm flanged crank, H-rods, etc.  (Read 6719 times)
buggyjanne
« on: February 03, 2026, 19:36:52 pm »
Brand New: Autolinea Casing w 94 mm bore. Rear end of casing is machined for sand seal and prepared for drysump. Easy to put in a ring if plan is not to use dry sump.
Used: Crank Scat 86 mm Flanged w Porsche journals. 12 bolted
Used: Flywheel, 12 bolted special made for 215 mm clutch, made by Sune Jansson (RIP) Sweden
Used: Pressure Plate, 215 mm, aluminum frame with steelplated surface=Light and expensive (German)
Used: Clutch Disc, Solid Center 4 Disc. (German Parts) Made by jan Ekholm (RIP) Bil &Trans Stockholm
Used: H Profile rods. 5.5" Checked
Brand New: Fk 89 Camshaft
Brand New: Lifters
Brand New: Glyko main bearings, reinforced w split front bearing (German)
Brand New: Glyko rod bearings Porsche dimension (German)
All used parts are in great condition and no restoration is needed. Crank, flywheel and pressure plate are balanced. I am the one who have used these parts and they were my backup after I built a new engine. I have run 11,50s w 720kg N/A car with the clutch, crank and rods with no issues. The case is just temporarily put together and can easily been taken apart for inspection of crank etc.
Price:
40 000SEK, 3800€, 4600$
If any questions please call or text me. Parts are located about an hour north of Stockholm, Sweden. I can ship where ever you want.
+46 766 778470, Jan
« Last Edit: February 03, 2026, 19:48:53 pm by buggyjanne » Logged
buggyjanne
« Reply #1 on: June 02, 2026, 19:28:25 pm »
Still for sale.
