September 22, 2026, 04:38:44 am
Rev Limiter for Vertex Magneto
Topic: Rev Limiter for Vertex Magneto (Read 26630 times)
Ole
March 10, 2006, 00:31:14 am »
I need to get a Rev-Limiter for my engine. It has a Vertex Magneto, the Tach is an old Autometer.
I think about purchasing an Autometer Pro Control. So far so good.
Summit offers 8 different Pro Controls
, which one do I need? I guess my Magneto is the OAC type, right? After my car ain't supercharged, it should be model 5302
http://store.summitracing.com/default.asp?target=partdetail.asp&autofilter=1&part=ATM%2D5302&N=115+4294925143+400442+4294816773&autoview=sku
Anyone experience with that? BTW, what's the difference between Supermag, OAC and OXC Magneto?
Muchas gracias,
Ole
no cerveza?
no trabajo!
Frank LUX
Back...Soon...hopefully!!!
Re: Rev Limiter for Vertex Magneto
March 10, 2006, 07:09:32 am »
Quote from: Ole on March 10, 2006, 00:31:14 am
Muchas gracias,
Ole
Hi Ole,
Yes you'll need the ATM-5302 unit, Nico is using the same one in the muppet racer and we just ordered one for Fred Twins to...
Concerning OAC and OXC it's internal and external magneto Coils....
Frank
March 10, 2006, 12:46:15 pm »
I use one of these Pro-controllers in my looker in combination with my Vertex Magneto.
To further complicate things I use a VDO 80mm rev counter and a converter from Autometer, called 9118.
I contacted Autometer to find out how you use the pro controller with the 9118... but they didn't know.
So I gave it my best shot... the revcounter works just fine, but I can't get the pro controller to kick in..?!
I don't feel that a magneto converted Monster 5" would fit in my car... so If you find out anything that could help me Ole, I would appreciate it.
Berger
www.bugrent.no
March 10, 2006, 13:42:14 pm »
I use the 5302 type together with Joe Hunt magneto and Pro-Comp tach in my car. Wireing gave some headache because the Pro-Control can be used for several tasks. Shout if You need any help when installing it.
Berger
This is my simple religion:
-Be cool
-Don't be an asshole
SOB/RFH
Have fun!!
March 10, 2006, 20:40:59 pm »
It is friday so, I hope no one is offended....here we go
Just use lighter valvsprings and the engine will self adjust....."We don't need no stinking revlimiters" is what Jesse James would have said!!
Happiness is a Hot VW!!
Ole
March 11, 2006, 01:00:04 am »
Thanks for the replies!
Quote from: JHU on March 10, 2006, 12:46:15 pm
Jon, my tach is the type for Magnetos, no converter needed. That means I can see it from the marks on the pistons AND on the tach, when I missed gear...
Quote from: SOB/DBR on March 10, 2006, 20:40:59 pm
Valvesprings? I converted to a pneumatic valve control system some years ago...
I wouldn't use a limiter if I'd earn half the $$$ Mr. James does...
That's true! ...as long as it has no eyebrows!
Saludos,
Ole
no cerveza?
no trabajo!
Ole
March 11, 2006, 23:31:37 pm »
maybe that helps?
http://www.huntmagnetos.com/auto_meter_tach_converter.html
http://www.huntmagnetos.com/index.html
http://donzig.com/vertex.html
Saludos,
Ole
no cerveza?
no trabajo!
March 12, 2006, 12:01:04 pm »
Thanks Ole, but I had that drawing, except mine said Autometer on the tin ;-)
I you compare this scheme with the one for the procontroller, you will probably see they don't mix to good...
But I must admit, I suck at electrics...
Berger
www.bugrent.no
March 12, 2006, 20:23:29 pm »
It should realy not be any problem JHU, if You wire like the print fore the Pro-Control says, and conect the brown/orange from the coverter to the TRIG. point at the Pro-Controller. And You don`t need to do two wires all the way to the magneto, only the one from the TRIG. to the primary terminal, and then You make a short loop from the TRIG. to N.O.
-Be cool
October 22, 2009, 12:00:44 pm »
just wanted to bring this topic back up.
JHU, did the wiring advice of Berger work for you?
is there no smaller device to use with a vertex magneto? i'm just wondering where to put the pro control since the glove box compartment is not ideal for a street car
DVK ~
October 22, 2009, 12:13:51 pm »
I don't think I tried it, as I got hold of a small old Autometer Tach for Magneto...
But please report back if it works...
The
old
Pro-controllers are much smaller and cooler... look at old gassers and you will see them from time to time...
My next project is to fit two pro-controllers
October 22, 2009, 12:41:48 pm »
very interesting topic - I want to use a mag on my 2180 SPG motor and I think it would be a good idea to have a limiter
October 22, 2009, 12:44:22 pm »
i am using a mag already and the thing i'm worried about most is missing a shift with a very light flywheel and the 1915 engine seeing 9,000rpm in a flash.
i'm not so much looking for the japanese 7,000rpm wop-wop-wop sound... or am i?
Last Edit: October 22, 2009, 12:45:53 pm by 67-indeed/DVK
DVK ~
October 22, 2009, 13:09:42 pm »
Quote from: JHU on October 22, 2009, 12:13:51 pm
The
old
I sent JHU a mail some time ago were I explained the wiring of both the pro controller and the converter. Works fine on my car. Do you still have it?
To the best of my memory it seems very similar to how Berger describes it.
Mounted the pro control just next to my left knee on the carpet in front of the drivers side door if you know what I mean...
I like JHU's way of mounting it better though...
October 22, 2009, 13:14:45 pm »
you mean cutting out the dash?
DVK ~
October 22, 2009, 17:03:11 pm »
I still got it Johnny, haven't gotten around to testing yet...
I use it for a rudimentary launch control so I needed to read the "pre-test button" from the drivers seat...
As we all know... form follows function... image is nothing...
October 22, 2009, 17:46:16 pm »
IŽm just DYING to see where youŽll fit the second one!!!
Marty
October 26, 2009, 03:40:22 am »
Here you go -
http://www.etcrevlimiters.com/
October 26, 2009, 10:01:14 am »
Thanks Marty, that's the perfect solution!
October 27, 2009, 15:15:00 pm »
Found those via Google too Marty.
Just have no idea of the price and there as a few different ones of which I have no clue how differ...
DVK ~
October 27, 2009, 16:12:35 pm »
I got a email from them:
"The Dual Range Rev Limiter sells for $375.00 (USD)"
October 27, 2009, 16:26:28 pm »
blimey, that's even the cheapest available, right?
DVK ~
jick
November 01, 2009, 20:13:15 pm »
Quote from: 67-indeed/DVK on October 22, 2009, 12:00:44 pm
i've just put in my pro-control this weekend, i too didn't want it in the glovebox, so i've put mine centrally on the front bulkhead, above the tunnel, i'm going to cut the carpet neatly around it and re-bind the edges.
www.custommotorbodies.co.uk
November 05, 2009, 13:03:43 pm »
sounds interesting jick!
i've been thinking of mounting it in the front trunk like the electrics in the berglar, whatever those parts are that car has a lot mounted there.
DVK ~
