October 14, 2026, 01:04:55 am
| | |-+  Shimming Scat Rockers for use on street eliminator heads!!
Author Topic: Shimming Scat Rockers for use on street eliminator heads!!  (Read 17136 times)
1953oval
« on: December 02, 2007, 17:45:05 pm »
 Hello all ,
             I have just registered for the site and am seeking some advice , I am rebuilding a 2110 t1 and am changing the heads for street eliminators, the rockers i have are scat bolt up ratio rockers. The old heads these were used on were CB 044 Oval ports and they fitted fine. When i fit the rockers on the street eliminators the exhaust rockers do not sit on the valve stems correctly and rockers only contact the half of the stem.
             Can anybody tell me if  there are  shims available to space the rockers further out to fully contact the exhaust stems !! Anybody know how they fit !! alternative solutions!!
                  Thanks Folks Justin Dawson (u.k)
Steve D.
« Reply #1 on: December 02, 2007, 23:25:57 pm »
If the valve spacing is wider than stock (aftermarket castings -> more room between the valves), you can usually make the Scat's fit by just removing the caps on the end of the rockers, flipping them around 180* and reinstalling.  This allows the rocker to slide over all the way to the end of the shaft, and should put you right where you need to be.  Stack up some shims to take care of the extra space on the inboard side of the rocker, torque 'em down and you are ready to go.
Über Alles
10.77 avg. on pump fuel.
238I
1953oval
« Reply #2 on: December 03, 2007, 18:24:45 pm »
 Thanks Bro , Will give it a try !!!! let the good times roll  cheers Justin
Steve D.
« Reply #3 on: December 04, 2007, 06:07:04 am »
There are other solutions, but those actually cost $$$.  Let us know if the *almost* free way works out for you- if not, I know other way$
Über Alles
238I
« Reply #4 on: December 04, 2007, 11:54:54 am »
Hi Justin,
I did the same as Steve D when I ran Superflo heads on my first 2276, but i had some larger diameter rocker shafts so I gad to grind out the centre of the shims too! Worked fine tho! Grin
benssp
www.callookvw.com
« Reply #5 on: December 04, 2007, 12:48:34 pm »
Welcome dude, long time no see Grin
www.vwheritage.com  My Job
YMCA
SMO
Typ 1 -61
« Reply #6 on: December 05, 2007, 23:11:09 pm »
Have same problem with my Street Eliminator heads.
I have tryed both .. think the first one is best to modify
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13%2D21%2D2162
http://www2.cip1.com/ProductDetails.asp?ProductCode=C15%2D20188S
coments please
Steve D.
« Reply #7 on: December 12, 2007, 23:02:11 pm »
Soooooooooooooooooo, did it work?  What's the word?
Über Alles
238I
