October 13, 2026, 00:15:02 am
How do you determine the size of your header?
Topic: How do you determine the size of your header? (Read 14004 times)
Tobi/DFL
December 03, 2007, 22:15:49 pm »
After reading the great thread about mouse motors I recognised that obviously some of the little beasts use pretty large headers for their engine size. Is there a formula similar to those formulas you can use when you want to find a starting point with your jets and venturis?
What header size would you recommend for the following engine:
2176cc (78.4x94mm), W 140, Bugpack ratio rockers (advertised as 1 : 1.25 but in fact 1 : 1.31), welded 040 heads with 44/37.5mm valves, oval ports, 11:1 CR (runs on 100 octane Shell V-power), 48 IDAs (42mm venturis, 180 main, 120 air, 60 idle, F11 emulsion tubes, third hole bored, enlarged float bowls. Jetted with the help of a LM1 wideband lambda meter) on short race Trim manifolds. The current header is a 1 5/8" bugpack which is shortened about 1" to use a large flange. The muffler ist a CB Performance merged dual quiet pack which is shortend as well (about 1.5") to get a large flange fitted. In that trim (but without the current jetting and ignition timing) the engine made 198.56 bhp at 6770rpm and 237.3 Nm of torque (donīt know how much thatīs in ft.lbs.?) at 5130rpm.
I think that the mufflers are quite restrictive so Iīm currently welding a custom dual quiet pack as I donīt like the look of todayīs turbo mufflers. The tubing from the flange to and through the mufflers is 2 1/8" and after the mufflers its diameter is 2 1/4". The flange is 2.5" in diameter. Do you think that I could make a little more power in the higher rpms with this set-up or should I change to a 1 3/4" header or even bigger? Currently it seems like the engine is lacking a little bit of top end power.
Currently the engine sees limited street use but it must remain driveable so it mustnīt have no power until 4000rpm. Do you think that a 2" header would be way to big or would make the engine anything but fun to drive?
Your opinions please!
Bye,
Tobi
Re: How do you determine the size of your header?
December 03, 2007, 23:18:00 pm »
1 3/4, I think 2" would be way to big,
cheers richie,uk
Tobi/DFL
December 04, 2007, 09:41:02 am »
Thanks, Richie!
Tom G.
December 04, 2007, 11:18:16 am »
Hi my friend...
Did you use the mufflers, which i have given to you...? I think if you use them, it is a first step to get down in backpressure instead of your cool but restrictive dual quiets with such a too small diameter for your power range...But it is allways incredible to see that you have produce 196 ?HP...I know the engine and it is really impresive for 2,2l..So what can you expected if you have the bigger ones on it?:-))
If you also change the header to 1 3/4" it could cost you a little tourque in the lower RPM ranges...I would go for 2 steps..1 step the mufflers...if you notice a HP gain and it is enough...let it go...if it is not so much you can go to step 2 to change also the header to max. 1 3/4....
Good luck
Regards
Tom
Tobi/DFL
December 04, 2007, 13:03:02 pm »
Hi Tom!
Yes, the mufflers I will use are the ones you sold me 2 years ago.
The tubings however are not the ones you sold me as those were not of good quality (the bends were crap) so Iīve ordered them from Jegs. The greatest problem at the moment seems to be getting the stainless steel tailpipes flared like they are usually are on old dual quiet packs. I will have an attempt in the next days at a friendīs garage who has a 20 ton. press.
i guess I will in fact use the old 1 5/8" header at first to see if the engine has more top end power with the new mufflers.
Bye,
Tobi
benssp
www.callookvw.com
December 04, 2007, 13:18:08 pm »
What if, (in my case) i'm running a 1776 with an 1 3/4" header and am downsizing to an 1 5/8", would i have much of an issue in the step between the exhaust port and the header?
www.vwheritage.com
My Job
www.bernardnewbury.co.uk
My Team
any work related enquiries to
ben@vwheritage.com
YMCA
December 04, 2007, 16:03:27 pm »
Quote from: benssp on December 04, 2007, 13:18:08 pm
No,I would doubt you ex port is anywhere near 1 5/8 let alone 1 3/4 so should be nothing to worry about.
cheers richie,uk
benssp
www.callookvw.com
December 04, 2007, 16:30:05 pm »
cheers richie, it actually is opened up to 1 3/4"
I got some 1 3/4" gaskets from bernie and they line up perfectly, I have no problems with the bigger header and like the sound it mjakes at 7.5K, just want to see if my times drop with an 1 5/8" header
www.vwheritage.com
My Job
My Team
ben@vwheritage.com
YMCA
Peter Shattock
December 11, 2007, 12:44:09 pm »
Ben, that is one hell of an exhaust port on a 1776, I know you said you had Tony looking at the heads, it will be interesting to see how things work out. I'll try a 1"3/4 header at some point this year so I'll let you know how I get on but my exhaust port is way less than 1"5/8 currently but I do run a 1"5/8 header (small flange).
See you at the AGM no doubt
benssp
www.callookvw.com
December 11, 2007, 13:29:53 pm »
hi Pete, I could lend you mine if you like, there's a nice turbo muffler attached to it too, although i think it's too shiney for your liking!
Speak to you soon
www.vwheritage.com
My Job
My Team
ben@vwheritage.com
YMCA
Peter Shattock
December 11, 2007, 14:08:07 pm »
I think your right I think I'll stick with my old GB dual QP's, they might not be the most efficient but you cant beat the look not to mention the thrashy sound! Thanks for the offer but I think Phil said I could have a blast with his old header when the time comes and his is also a small flange 1"3/4 which I'm keen to try first.
Thanks for the offer though, Ill keep you posted. Have you heard back from Bugpack yet about the valves?
December 11, 2007, 14:46:53 pm »
Quote from: benssp on December 11, 2007, 13:29:53 pm
Hey Ben, do you want to sell me your muffler? You won't be needing it any time soon...
benssp
www.callookvw.com
December 11, 2007, 15:48:32 pm »
Quote from: Fastbrit on December 11, 2007, 14:46:53 pm
not a chance Sir
I had to beg they guy who had it to sell it to me, it cost me a pair of Flat4 Fuchs! it's a lovely handmade piece by a man you know, Uk Hot Rod Supremo Jon Golding
p.s PK tells me your gearing up for next year, can't wait to see the car run
pps. what are you doing with your lexan windows?
www.vwheritage.com
My Job
My Team
ben@vwheritage.com
YMCA
December 11, 2007, 16:01:12 pm »
Quote from: benssp on December 11, 2007, 15:48:32 pm
not a chance Sir
Oh, swapping them for your muffler, probably...
benssp
www.callookvw.com
December 12, 2007, 17:19:44 pm »
http://www.volkszone.com/VZi/showthread.php?p=4037643#post4037643
THIS ANY USE TO YOU KEITH?
www.vwheritage.com
My Job
My Team
ben@vwheritage.com
YMCA
December 12, 2007, 17:36:29 pm »
Quote from: benssp on December 12, 2007, 17:19:44 pm
Ta, but it's for a Bus.
JS
December 15, 2007, 21:40:54 pm »
How do you determine the size of your header really? I understand that you can try out different sizes, but is there a relatively simple formula to calculate the diameter of the tubing?
Signature.
