June 10, 2026, 08:43:00 am
Latest Member: mvptkfjb
| | |-+  what lifters to use with engle cams
Author Topic: what lifters to use with engle cams  (Read 7609 times)
« on: December 04, 2007, 07:16:59 am »
again an advice that is not totally confirmed, but it would be a bad idea to run a FK8 with webcamlifters... it has to do with the hardness of both metals being different and pitting may occur. but what lifters should i use with the engle cam. i was interessted in the tayco's, but they may need sleeves in the case. so i always have used stock ones in the 1641 with the W110, bu they need replacement. so what good options are there to have. i know of Udo Becker lifters, but they are a bit above the budget. i was looking for something good and light and within budget... i know i have to pick 2  Wink
thanks for helping.
btw i may be able to pic up my crank later this week. happy happy joy joy
John Rayburn
« Reply #1 on: December 04, 2007, 08:28:58 am »
I've always run stock reground lifters for 27 years on Engle cams with no failures.
I also park at Nick's.
« Reply #2 on: December 06, 2007, 14:11:16 pm »
thanks
« Reply #3 on: December 06, 2007, 14:15:50 pm »
Never had a problem either and I have used CB superlightweights and Schübecks ceramics.
LGK
« Reply #4 on: December 06, 2007, 19:37:34 pm »
Nicolas,
You can go FEBI/BILSTEIN or MAHLE both will work fine and won't rune your wallet.
Regards Steve
Rasser
« Reply #5 on: December 06, 2007, 22:52:25 pm »
Whatever type of lifter you choose - you should ALWAYS avoid valvefloat due too excessive rpmīs and inadequate valvespring pressure. Itīs the valvefloat that really kills the lifters/cam.
Well - IMHO (and experience ;-) ) anyway.
I have had bad experiences with brazil mahle, scat.
I have had good expereinces with CB light weight racings (same as beetlebug refers to)
Using a FK cam instead of a W is also a thing that helps keeping lifter/cam alive longer.
Happy build!
/Rasmus
« Last Edit: December 06, 2007, 22:54:11 pm by Rasser DK » Logged
1955 type1
1966 type2 13w deluxe
« Reply #6 on: December 06, 2007, 22:56:33 pm »
Well - IMHO (and experience ;-) ) anyway./Rasmus
Agree 100%
qubek
« Reply #7 on: December 07, 2007, 11:21:34 am »
Agree 100%
Yes but what when you’re using your bug daily, in traffic, with a lot of idling all the time?
Too much valve spring pressure isn’t good either. Without having to much experience, it’s hard to find a good balance between those two factors.
LGK
« Reply #8 on: December 07, 2007, 12:29:34 pm »
The initial question/topic of Nicolas was "compatiblity" of lifters with engle cams...so i think setting up springs on heads for a certain type of cam is another debate..indeed it has a lot to do with "what kind of use in mind for your particular set-up?"
Regards to all,
Steve
