September 22, 2026, 01:15:11 am
|-+  Tyre kicking
| |-+  Off Topic
| | |-+  5x130 bolt pattern in 5x205 brake drums
Author Topic: 5x130 bolt pattern in 5x205 brake drums  (Read 9504 times)
Mario/DKT
« on: December 07, 2007, 15:54:30 pm »
Hi guys,
is it possible to make the 5x130 bolt pattern in a wide 5 brake drum?
Or is it only possible with adapter's?
Thanks.
Mario/DKTS
maX cal-look
« Reply #1 on: December 07, 2007, 16:08:39 pm »
Hye !
No, sorry, it's not possible, you must to change your Drum brake for the 'recente' version ( 4 x 100 or 5 x 130 ) !
Because the holes down in the milde of the drum and you have not enougth material for make new holes !
Thank's for your understanding !
 Roll Eyes
« Reply #2 on: December 07, 2007, 18:06:37 pm »
You can do it on Porsche drums...
Mario/DKT
« Reply #3 on: December 10, 2007, 17:12:06 pm »
I will change the rear brake to another from 1968 an up.
At the front i will fix dropped spindels from cb perf. for disc brakes (1968 an up) and use the correct drums an discs with the 5x130 lug pattern.
This mod's are for the lowlight. The bug keep's the 5x205.
Thanks guys.
Mario/DKT
« Reply #4 on: December 10, 2007, 17:23:47 pm »
What year car? If you use the '68 and later drums on a short spline car, you will need to have the snout turned down. You will also need the '68 & later pads & cylinders. (Or use front cylinders for more braking power.) I did this recently on my '67 to fit Porsche pattern drums. I went with AC drums from SoCal Imports. They are thicker in the bolt seating area than redrilled stockers. If you redrill stockers you end up with one of the bolts being in a weaker area of the drum.
Mario/DKT
« Reply #5 on: December 10, 2007, 17:43:46 pm »
The car i a 1956 lowlight.
And now i know whitch changes i must do.
I will use the original gearbox for the roll out and first test drives. Later next year i will order a pro street gear box.
Thanks for help.
Mario/DKTs
