September 22, 2026, 06:13:40 am
| | |-+  whitch breather box do you use?
Author Topic: whitch breather box do you use?  (Read 14057 times)
Mario/DKT
« on: December 13, 2007, 14:49:33 pm »
I am searching for a sufficient breather box für my 2276ccm type 1 engine.
Whitch size or manufacturer do you use?
Maybe anyone can post pics of his engine/breather box.....
Thanks.
Mario/DKTs
« Last Edit: December 13, 2007, 19:45:37 pm by Mario/DKTs » Logged
benssp
www.callookvw.com
« Reply #1 on: December 13, 2007, 16:12:05 pm »
I run a Bugpack breather box with a feed from each rocker cover and a return to the oil filler Grin
www.vwheritage.com  My Job
YMCA
« Reply #2 on: December 13, 2007, 16:16:40 pm »
I use a Sil Modesti breather box.  The valve covers vent into the bottom and the carbs bleed off the top.  There are two baffles between the top and bottom fittings.  It works very well and looks great.
IP359
« Reply #3 on: December 13, 2007, 18:56:13 pm »
An old NOS Claudes Buggies breather box not mount on my engine yet......
Mauro Cattan
Manovra So Cal
« Reply #4 on: December 14, 2007, 01:01:59 am »
I use a tube with 20 little hole on top
Ciao
Mauro
« Reply #5 on: December 14, 2007, 01:06:54 am »
This is the one on my car.
 Grin
Steve D.
« Reply #6 on: December 14, 2007, 01:31:00 am »
I have always used the Bugpack boxes screwed to the back of the shroud- for the big motor, 2" ABS courtesy of Home Depot.  I should find a picture...
Über Alles
10.77 avg. on pump fuel.
238I
Mauro Cattan
Manovra So Cal
« Reply #7 on: December 14, 2007, 01:47:56 am »
 Grin
brrrrrrr.....gnam gnam gnam......frrrrrrrrrrrrr grrrrrrr Grin brrrrrr Grin wonderfull!!!!!!!!! brrrrrrr
« Reply #8 on: December 14, 2007, 02:10:25 am »
Do like the SSB and use a Coors can.
JustinCase
« Reply #9 on: December 14, 2007, 02:25:27 am »
Now when we got to the breatherbox conversation, what does the majority of people here think about these in your valvecovers A big no no , or worth of a try ? I do have a Bugpack box but I though of trying these in my covers.
« Reply #10 on: December 14, 2007, 02:48:11 am »
Looks like a mess waiting to happen to me.
The GTV uses the ol' hose to the EMPI aircleaner breather.
« Reply #11 on: December 14, 2007, 07:20:20 am »
i know from experience the amount of oil that gets thrown around by the valves, i just had the hoses on their loose once and it went everywhere.  Those filters will fill almost instantaneously and then drip.
I am using a Gene Berg tower and a Clyde Berg breather box, valve covers into CB box, then CB box drain into GB box, fuel pump linked to GB box as well.
Steve D.
« Reply #12 on: December 14, 2007, 07:25:58 am »
2" i.d. by somewhere around 12~14" long (kinda forgot), all screwed to the back of the shroud.  Metal screen inside as a baffle, sponge stuffed in just above the highest fitting, and a whole bunch of holes drilled in the top to breathe- cheap, works great!
Über Alles
238I
GreenTom
« Reply #13 on: December 14, 2007, 08:32:42 am »
for engine as 2776ccm I would use VWSS custom breather tube... made of aly, propper stuff. You can see them on most Fastest bugs and buses in UK Cheesy (for egzample: Glyns, Pauls digger and 12.5 sec bus, Dazes, quite a few people from  JG54Grunherz etc...). just go to the VWSpeedshop.com.
all best. GreenTom /Molotov/
Aircooled Performance Gear
Quick Stick Performance
www.QuickStickVW.com
ESH
« Reply #14 on: December 14, 2007, 10:12:14 am »
I'm currently using a GWD one which has been very good and I'm liking the look of the new CSP one, we might put one of those on my girlfriends new 2332.
 Cool
« Reply #15 on: December 14, 2007, 19:13:09 pm »
I'm using a Berg...never got around to hooking up the hoses for the valve covers though.  Back in the day, before breather boxes became popular, it was common to run a hose from one valve cover to the other (with a small notch cut in the center) over the top of the trans...my choice  Roll Eyes.  I'm using a Berg 1 1/2 quart sump and keep the oil level just a hair over the first mark on the dipstick...which seems to eliminate a lot of the need for a breather box IMO.  My $.02
empicolector
EMPI RULES
« Reply #16 on: December 14, 2007, 22:06:40 pm »
I am using a NOS AUTOHAUS RACE TRIM breather box
Frank LUX
Back...Soon...hopefully!!!
« Reply #17 on: December 14, 2007, 23:25:19 pm »
Berg Breather Box aswell as an CB or Bugpack One as "T" fitting for the Valve Covers...
Frank
empicolector
EMPI RULES
« Reply #18 on: December 14, 2007, 23:27:07 pm »
MORE A BERG ONE LIKE FRANK
