October 13, 2026, 01:27:13 am
| | |-+  48IDA’s new or used Italian?
Pages: [1] 2 Print
Author Topic: 48IDA’s new or used Italian?  (Read 26047 times)
Rocket Ron
It's old school for a reason
« on: December 19, 2007, 21:20:30 pm »
48IDA’s new or used Italian what are the differences and what are the problems to look for on the old ones? What you buy? Huh
13.12 @ 101.84
Grooving out on life
« Reply #1 on: December 19, 2007, 21:47:53 pm »
I just went through this procedure. What I found was finding a good set of unmolested Italian IDAs was difficult. (And expensive.) A lot of them have been modified, beat up, hacked up, missing parts etc. Then once you get them you have to have them rebuilt, rejeted etc. Unless you just have to have the Italian IDAs, I would go with a new set. There is no difference in performance and you know they have not been beat to death. If you do go after a used set, check the throttle shafts to make sure they are tight. Make sure all the parts are there. And that none of the screws/brass have been cross threaded. Then get prepared to send them off and pay about half of what you bought them for to get them rebuilt and jetted.
Rocket Ron
« Reply #2 on: December 19, 2007, 23:01:03 pm »
Dont know what to do as the new and old ones are about the same money and everyone seems to go on about Italian IDAs
thank for the coments Louis
13.12 @ 101.84
Black Sheep
less is more
« Reply #3 on: December 19, 2007, 23:05:08 pm »
I've been told the same thing Ron , as much as I want a pair of Italians' Cool ,it makes far more sense it would appear to get a pair of new one's  Undecided
13.03 @ 98mph
« Reply #4 on: December 19, 2007, 23:13:08 pm »
I have no personal experience with the new ones, but I know I wouldnt swap my Italians for a set that speaka spanish Wink
One thing I dont like about the new ones is the color of the casting.... its way off from the Italian versions.
Rocket Ron
« Reply #5 on: December 19, 2007, 23:16:59 pm »
 though I may treat my self to a pair for xmas before the dollar starts dropping off.  Cool
13.12 @ 101.84
Martin Greaves
10.88@128.58
« Reply #6 on: December 19, 2007, 23:22:37 pm »
Ron why do you want to buy some old shit just get some new one's. Cheesy
Rocket Ron
« Reply #7 on: December 19, 2007, 23:27:02 pm »
we're all suckers for old shit .............
thats why we drive old vws  Wink
13.12 @ 101.84
« Reply #8 on: December 19, 2007, 23:58:08 pm »
Yeah, having said all that, I went out and bought a pair of Italian ones too.   Wink  But I talked to several people who deal with them on a daily basis and their opinion was, unless you just want them to say "Made in Italy" there is no performance reason to buy a used set. And the initial cost may be the same, but you also have to factor in repairs to the cost on the old ones. Last time I checked, Art T. charged around $300 - $400 in labor alone to rebuild a set. (Fortunately, mine were already rebuilt which is the only reason I bought them.)
Fasterbrit
« Reply #9 on: December 20, 2007, 10:47:25 am »
Original Italian IDAs are just like having genuine BRMs... It's all about the kudos Cool
Sure, they can be beat to death (and cost a fortune), but having the real deal on your car makes it just that little bit special.
Genuine all the way!
www.air-kraft.com
www.marcomansiperformance.com
Martin
Cash Converter....
« Reply #10 on: December 20, 2007, 13:54:43 pm »
Oi, Keeno, get back in that shed!
You've a car to finish!
Wink
Martin
www.taylormachine.co.uk
OFF/500
« Reply #11 on: December 20, 2007, 15:26:45 pm »
Amen" Grin
« Reply #12 on: December 20, 2007, 18:00:25 pm »
Who says you have to pay someone to rebuild it? Buy a rebuild kit and do it yourself, its a carburetor not rocket surgery Wink
« Reply #13 on: December 20, 2007, 18:41:37 pm »
Couple of things I would watch out for if you try to find some used ones...
water/moisture damage, which on the carb bodies, will show up as a white fuzz. On the jet stack it will appear as a dry greenish fuzz. If the damage is left to spread, it can erode the carb bodies away. Water down the jet cavities and into the float chamber is the worst.
Jets that don't seat correctly are a problem, caused by gorilla-fisted tuners and/or the moisture damage mentioned above. The jet stacks should seat firmly with a minute amount of effort when screwing into carb bodies. If the jet stacks seem to bind up as you screw them in, or seem to never seat, or seat "softly" then rest assured there is a problem in the jet cavity.
twisted throttle shafts can be checked with a feeler gauge. Make sure butterfly to throat clearance is the same on both throats. set idle speed screw so a .006" gauge drags between closest throat and plate, then check the other one.
Some carbs I have heard of are sold with whored-out jet stacks and/or needle valves. What I mean, is it seems like some sellers sweep up the weirdest jet combos, emulsion tubes, needle valves etc, in order to sell the carbs "complete." If you have to replace every jet, tube, holder, etc....then you might as well find a bare set.
Funny drillings, hogged out float bowls, aftermarket stuff would all tend to make me look elsewhere too. If you need to buy new needle valves, I would HIGHLY suggest using only original Weber ones, not aftermarket ones.
good luck,
Jim
Tony M
« Reply #14 on: December 20, 2007, 21:54:08 pm »
now that every one is getting IDA's - must be a over flow of IDF's out there - not to change the thread - but looking for 44's or 48's  IDF's - in good shape of course
« Reply #15 on: December 20, 2007, 22:52:40 pm »
Actually I think a bunch of IDAs are coming on the market due to the turbo craze. Guess some people think they are upgrading when they go from IDAs to a hair dryer.  Roll Eyes
Black Sheep
less is more
« Reply #16 on: December 20, 2007, 22:54:45 pm »
drop me a line in the spring once i've got my ida's sorted out , may have a pair of 44idf's up for grabs
13.03 @ 98mph
« Reply #17 on: December 22, 2007, 08:47:16 am »
Sorry, but I have to disagree with you.  Your comparison to BRMs is rediculous.  There's a HUGE difference between a heavyweight Aluminum fake BRM and the Mg real one.
The new Weber IDAs are GENUINE WEBER.
Anyone considering buying used carbs should not buy any carb used in an offroad application, or from a car with an open engine.  Sand and dirt destroys carbs real fast
Fasterbrit
« Reply #18 on: December 22, 2007, 11:19:46 am »
There is a huge difference between a genuine IDA and a Spanish or other remake. Put them side by side and check out the difference in quality of casting. The new ones look rough in comparison. "Made in Italy" means quaility. All of the Weber carbs built outside of Italy do not come close to the quality and precision of the orginators. Pull out the jets on a new 'Weber ICT' or IDF and you will see a great diference between the acuracy of machining, especially recently. I fitted a brand new set of ICTs to a Fastback last week and could not get the thing to run any sense. It ran lean and then ran rich all of a sudden. Pulled the carbs apart and found that every single jet drilling hole had been done a ham-fisted chimp with a square drill bit. Never seen such poor quality work in a carburettor, ever. Had to pull the carbs and send them back to the supplier. Junk Angry
Oh, and don't get me stared on those Chinese Empi HPMX pieces of junk. Fitted two sets and they were both junk. Porous float bowls, amongst other quality control issues. Won't ever fit a set again.
Italy all the way.
www.air-kraft.com
« Reply #19 on: December 22, 2007, 13:03:48 pm »
Just go for Jenvey
 Tongue
simplicity all the way Smiley
Martin Greaves
10.88@128.58
« Reply #20 on: December 22, 2007, 13:10:15 pm »
Italy all the way.
Well Matt what side of the bed did you get out of. Grin Grin Grin Grin
« Reply #21 on: December 22, 2007, 19:44:13 pm »
I have worked on both old Italian and new Weber IDAs, and the difference in quality of manufacture is minimal.  Your examples of flaws in IDFs or ICTs is irrelevant to the discussion.  Those are crap carbs.  The new IDAs are not.
Just MO based on working on both.
« Last Edit: December 22, 2007, 19:48:58 pm by Bruce » Logged
Fasterbrit
« Reply #22 on: December 25, 2007, 11:26:42 am »
Italy all the way.
You guys are right... I am bitching. Grin
Just had a bad week with crap quality carbs and lost out on a day's pay as a result  Angry
Smiling again now though Wink
www.air-kraft.com
james wotton
« Reply #23 on: December 26, 2007, 01:26:52 am »
yeah just get one off those old shit holley's with a turbo no end of shit ah  boom boom! Tongue Grin
9.91 @ 139.90
outlawflatfour 2010 and 2011 champion.
Martin Greaves
10.88@128.58
« Reply #24 on: December 26, 2007, 01:37:02 am »
Yes you got me there thanks mate. Grin
But that Holley is still better than your FI. Tongue
Rocket Ron
« Reply #25 on: December 28, 2007, 10:54:26 am »
Thanks for the advice guys.
Currently looking at a few options and will let you know how I get on.
13.12 @ 101.84
« Reply #26 on: December 28, 2007, 18:05:53 pm »
rocket ron, good luck with your project. Here is another site you can get "opinions" from.... I lurk here, just to see what these 48IDA guys are up to:
http://www.gt40s.com/forum/gt40-tech-engines-induction-exhaust/
also, I know Mazda RX7 guys are using 48's... so you can check around with them for carbs for sale and/or their opinion of the New vs the Old.
have fun,
Jim
Rocket Ron
« Reply #27 on: December 28, 2007, 22:42:20 pm »
Cheers Jim some real cool stuff on there. I love the IDA injection setups  Shocked Shocked Shocked
I'll let you know how I get on.
13.12 @ 101.84
Ninho/DKM
« Reply #28 on: August 11, 2008, 00:47:52 am »
Hi, i am Italian.....so i bought a pair of old made in Bologna 48 Ida's. NOw i need a lot of spare parts like pumps rods and screws and so on....who can i contact, could you write me any links to ask for?
many thanks.
1974 Superbeetle Porsche affected and influenced
1957 Gasser Project work in progress
1973 Thing type 181 Civil version (sold)
1959 Bug waiting attentions
1963 Surfin'Bird Street and Strip race Bug 1776cc Best E/T 14,769 at Hills Race#10
www.Surfinbirdbug.blogspot.it
www.Ninho-Reloaded.blogspot.it
andy M.
« Reply #29 on: August 11, 2008, 13:31:03 pm »
there is a huge difference between a genuine IDA and a Spanish or other remake. Put them side by side and check out the difference in quality of casting. The new ones look rough in comparison. "Made in Italy" means quaility. All of the Weber carbs built outside of Italy do not come close to the quality and precision of the orginators. Pull out the jets on a new 'Weber ICT' or IDF and you will see a great diference between the acuracy of machining, especially recently. I fitted a brand new set of ICTs to a Fastback last week and could not get the thing to run any sense. It ran lean and then ran rich all of a sudden. Pulled the carbs apart and found that every single jet drilling hole had been done a ham-fisted chimp with a square drill bit. Never seen such poor quality work in a carburettor, ever. Had to pull the carbs and send them back to the supplier. Junk Angry
Italy all the way.
[/quote]
My mum had a FIAT 127 and that was made in Italy, it was fucking shit!
kindest regards
Andy
L.B.C.R.
Pages: [1] 2 Print
