October 12, 2026, 22:47:21 pm
| | |-+  Roller cranks!?
Pages: [1] 2 Print
Author Topic: Roller cranks!?  (Read 37022 times)
« on: September 04, 2006, 19:12:40 pm »
Hey dude's - a good friend of mine is building an old gasser replica and he's thinkin of running and SPG roller bearing crank.
Does anyone have any usefull info or opinion's on this subject?
« Reply #1 on: September 04, 2006, 19:54:16 pm »
For drag racing duty the crank needs to be pinned or else it will twist. I would use a large oil pump to get alot of psi to those roller bearings, and a very light flywheel because those cranks are heavy!
Gunnar|Rennfahrer
« Reply #2 on: September 04, 2006, 19:57:35 pm »
If it's "All show no go" Superb! But if he's going to race it: Refering to "The bible:" Use it as a tablelight. Wink
Gunnar
Rennfahrers VW Club
Roman
« Reply #3 on: September 04, 2006, 19:57:54 pm »
They are weak, and expensive to rebuild. I have one in my garage that needs rebuilding, but I can buy at least three chinese cranks just for the rebuilding cost.
Who cares if it is a roller, you can't see it on the outside of the case. Put it on a shelf as a showcase instead, that is where it belongs.
The only exception would be if I was restoring a car like inch pincher, then it HAD to be a roller.
Roman
« Reply #4 on: September 04, 2006, 20:00:57 pm »
Here is my flywheel that was on the roller, this is a light flywheel!  Cool
« Reply #5 on: September 04, 2006, 21:25:28 pm »
Interesting way of removing metal there! I saw a flywheel at AJ Sims shop once that was lightened with what seemed like a 100 holes. I think it was something like 7-8lbs. Funny that flywheel there is only drilled for 4 dowels!
« Reply #6 on: September 04, 2006, 22:12:53 pm »
thanks for the advice guys - its pretty much what I have been told by people over here in the UK including Simon Emery
I don't want to say too much but the replica he is building did have a roller crank and it would be really cool to run one  Grin
does anyone know how high they can rev?
Roman
« Reply #7 on: September 04, 2006, 22:26:34 pm »
The funniest part is that  the crank is a SPG. The 8-dowel pattern is called SPG pattern, but this SPG crank has just 4!
« Reply #8 on: September 05, 2006, 06:56:48 am »
Ironic!
« Reply #9 on: September 05, 2006, 17:25:50 pm »
Ironic!
Sure is  Grin the only flywheel I've ever had come loose was on my 1200  Grin
BABOON
SCC Official
« Reply #10 on: September 07, 2006, 14:11:03 pm »
I know for a fact that Mr Schnellfahrer with the white ghia had 10200 rpm before the rod came through the roof of the crankcase.
« Reply #11 on: April 22, 2007, 01:32:12 am »
10200rpm that must have sounded AWSOME Smiley Smiley Smiley I wanted to get this thread going again and see if there was any more opinions out there  Huh
I really want to use a Roller bearing crank on my new project too maybe an 82mm SPG item on a 2180 just like Mike Mahaffey Wink - I want to know their advantages, they must have some  Huh Also didn't Porsche use them on the 912/ super 90 engine  Huh  Smiley
Does anyone have one for sale  Huh Does anyone know a specialist Huh
lets hear your opinions guys  Smiley
« Last Edit: April 22, 2007, 01:35:18 am by monkiboy » Logged
ugly duckling
« Reply #12 on: April 22, 2007, 04:50:10 am »
i know when i sold the little wopper fiat 500 to martin in the UK. that engine had been in the car since the early 70s the old 2180 when i tore the engine down it looked like brand new it was pined and welded. of corase the car sat for 23years in a garage. but before that it was hammerd at every drag stripe in so cal from liones to ocir true the littel fiat dident wight any thing but still was drag race started many times and street driven for years. i feel there preety darn strong for what they are. and if im not mastakin martin still has that same engine in the car and stands the car up on the stinger. i could be wrong to.   UD.
Frank LUX
Back...Soon...hopefully!!!
« Reply #13 on: April 22, 2007, 12:09:26 pm »
No, you're Right UD..., still the same Motor with the same old SPG Crank...!!!
Frank
« Reply #14 on: April 22, 2007, 12:19:17 pm »
no your not mistaken dude, I've seen that stinger dragin on the floor plenty of times  Grin I did not realise that Lil wopper had a 2180 with an SPG it seems like these are pretty good combo's (82x92)
I have always thought that they must be fairly strong especially when pinned and welded, and if I do decide to run one it will mainly be seeing street use so I think I should be ok  Smiley
The main thing I have been wondering is what are they like to drive with Huh and does anyone have an 82mm SPG for sale Huh
« Last Edit: April 22, 2007, 16:31:38 pm by monkiboy » Logged
« Reply #15 on: April 24, 2007, 21:36:04 pm »
come on guys some more of you guys out there must have a couple of cent's to drop in on this subject  Huh Smiley Huh
p.s thanks to Dave mayes for the pic Smiley
« Last Edit: April 24, 2007, 21:48:40 pm by monkiboy » Logged
SilverPig
Alles klar?
« Reply #16 on: April 25, 2007, 13:11:57 pm »
So what's the story with these roller cranks anyway? Please shed some light on the subject as I feel like a total ignorant fool.
Say hello to my little friend!
dave greiner
« Reply #17 on: April 26, 2007, 01:01:15 am »
We sold a ton of the SPG rollers back in the 70's at Auto Haus. They retailed for $349.95. They were originally built for industrial motors but were soon sold by Empi and others for racing use. The off road guys loved them because they reved very quickly (light rod weights) and were able to survive periods of low oil pressure because the rods are splash oiled from notches machined in the main bearings that created a "mist" of oil that lubricated the roller bearings in the one piece connecting rods. They were pressed together and we usually had them welded and pinned to prevent them from going out of index. They rarely failed but if you had one rebuilt with high mileage rods from other damaged cranks then they could create quite a mess when the rod let go. ( Corona Raceway, 1981) they are still popular with people building "retro" cal-look cars. I just picked up a nice example, but I don't know yet what I am going to do with it yet.
Proformancemotoring.com
« Reply #18 on: April 26, 2007, 01:25:08 am »
now thats some good info  Smiley and I'm finally glad to hear someone say "they rarely failed" I have always thought that they must be pretty dam strong - What size is that one you just picked up Dave  Huh
What sort of engine set ups did people use them with back in the day Huh
dave greiner
« Reply #19 on: April 26, 2007, 20:33:40 pm »
The crank that I picked up is an 82mm with the VW length rod. The Empi version had th shorter Porsche length rod with a narrower small end on the rod to work with the slipper skirt 88's.
Drag cars would use the standard 48ida, DDS 92 piston sets and either an Engle 160 cam or later on the FK-89.  At Ascot Park on Gardena the "Sprint Buggies' ran 48's on methanol with 13-1 compression  on a dirt track off road course. This is where 4 time Indy 500 winner Rick Mears started out and Richard Bays ,(original builder of the Little Giant Killer fiat) built engines that won several championships.
« Reply #20 on: April 27, 2007, 02:44:27 am »
I was wondering why some roller cranks wouldnt fit on EMPI's slipper skirt pistons! Thanks!
Bill Schwimmer
« Reply #21 on: April 27, 2007, 05:59:40 am »
"You can't hurt a roller"  right Dave ?
    Eddy Merckx
« Reply #22 on: April 27, 2007, 16:11:05 pm »
I am going to use one for sure  Smiley
I don't surpose you fancy selling me that crank you've  got dave  Huh Wink
dave greiner
« Reply #23 on: May 01, 2007, 17:28:14 pm »
Bill was with me that night in 1981. I had 2 or 3 people tell me that even though I had a smaller motor than most, that at least "You can't hurt a Roller". This was of course 15 minutes before it grenaded!  Bill has been quoting that line to me for 25 years. I think that he was only 5 years old at the time. LOL
Bill Schwimmer
« Reply #24 on: May 02, 2007, 00:52:35 am »
Only 5 yrs old at the time...  I wish..  I won't say anything about the time the waitress thought Greg Brinton & I were your sons.
    Eddy Merckx
« Reply #25 on: May 02, 2007, 01:20:33 am »
 Roll Eyes Roll Eyes Roll Eyes Grin
« Reply #26 on: May 02, 2007, 09:16:36 am »
LOL... is that cuz you all look alike?  Grin
Roller crankshafts
« Reply #27 on: June 07, 2007, 00:45:39 am »
There seems to be a lot of talk here about SPG Roller Crankshafts. Quite of a lot talked here is incorrect. I have been building these cranks for over 35 years and it is the only crank I use. If they are properly set-up there is still nothing on the market that can beat it. Yes they take special tools and knowledge to take apart and set up. That is why I am here! In the 70"s I ran a H Gas car called the Little Snort. A few years ago it was sold to Simon and since then he has sold it to a guy in Scotland. This car went 10.80 at 120 mph in 1970 and yes it had a 82 mm SPG roller crankshaft. Yes you need to pin the cranks in 4 places to keep them from twisting out of index. We prefer to pining next to welding. Welding is not smart. It causes a balance and fatigue problems. A lot of advancement over the years has been made in the rollers. Also advancement in flywheel attachment has been made. Yes the cranks are heavy around around 35 lbs but remember the rods are attached. Also because of the rollers the crank spins more freely and the extra weight becomes an advantage. As far as all this talk about oil pressure and such is just plain not correct. The mains need to be notched so the extra oil sprays on the roller rods. That is how the system works! Extra oil pressure and such is a lot of nonsense. The worst thing you can do to a roller as well as any engine is lug it. With the use of the high teck oils now days oil problems are a thing of the past. If you have a roller just laying around collecting dust email me at ghglass@sbcglobal.net and lets get it back on the road.
Gary
« Reply #28 on: June 07, 2007, 09:08:31 am »
At Last someone with some faith in the Old SPG's Wink Smiley - I have ALWAYS thought that these crankas were an awsome bit of kit and I never understood why they lost favour with the  VW world  Huh
I look forward to hearing some usefull information for my 2180 Smiley
lowfastbus
WUNDERWAFFE
« Reply #29 on: June 07, 2007, 11:18:06 am »
Hi Gary,
Great to have someone in the known about these cranks on here!
If you ever find the time, we would all love some story's or old pics about lil snort...
A lot off us on here are crazy about that car!!
Jelle
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
Pages: [1] 2 Print
