October 12, 2026, 15:31:02 pm
My '70 karmann ghia project
Topic: My '70 karmann ghia project (Read 68011 times)
Glauco
Re: My '70 karmann ghia project
Reply #30 on:
January 20, 2008, 20:25:52 pm »
does anyone know how the back end of the body is mounted to the chassis, I found the bolts underneath the backseat and 2 under the car, but it still won't cave, found some welds today but they're gone now, anyone has an idea?
Reply #31 on:
January 20, 2008, 22:36:26 pm »
On the inner fender, like a bug???
Reply #32 on:
January 21, 2008, 17:33:32 pm »
Quote from: Zach Gomulka on January 20, 2008, 22:36:26 pm
Exactly like that. One under each arch, one under the back seat each side and the rest are under the floorpan. Don't forget that the rear seat frame is part of the body, not the chassis, and not seperate like a beetle.
Glauco
Reply #33 on:
January 21, 2008, 20:52:17 pm »
Quote from: Neil Davies on January 21, 2008, 17:33:32 pm
thanks!
do you by any chance have photo's of this?
Reply #34 on:
January 22, 2008, 13:19:19 pm »
I should have some photos at home - If I get home early this evening I'll have a look.
If the bodymount is rotted out, Beetle ones fit, and the front bulkhead is the same too. I think the crossmembers under the rear seat are similar, but I always repair mine rather than replace them as only the '71-on panels are available.
Grelland
Reply #35 on:
January 22, 2008, 17:40:48 pm »
Quote from: Mr.Oldskool on January 21, 2008, 20:52:17 pm
thanks!
here:
___________________
Roy
Grelland
Reply #36 on:
January 22, 2008, 17:50:22 pm »
Sorry I dont have a better pic of the rear seat frame, but here you can see the shelf beside the seat, and the frame is visible in the lower part of the pic, I can take a few more pics later tonight iy you like.
___________________
Roy
Grelland
Reply #37 on:
January 22, 2008, 17:53:38 pm »
Is there a z-bar on your car? In the picture of my inner fender, you can see an opening surrounded by the red paint. This is originally a hole for the z-bar, but I opened it up underneath, so I can lift the body without removing the bar. BTW, I will use a trapes so called cup-bar to stiffen the rear, not the std z-bar, but the issue may be the same
___________________
Roy
Grelland
Reply #38 on:
January 22, 2008, 17:58:24 pm »
Quote from: Mr.Oldskool on January 18, 2008, 19:40:58 pm
for now I still believe it will turn out just great, I don't think there is no unrepareble damage, but we'll see how optimistic I'll be furderon in the restoration
There is no such thing as unreparable damage, believe me :-)
___________________
Roy
Grelland
Reply #39 on:
January 22, 2008, 18:03:57 pm »
Great project, by the way, Ghias on EMPI 8s are great, and I still have a debate inside my head about bumpers/no bumpers :-)
Let me know if I can help you out in any way
___________________
Roy
Grelland
Reply #40 on:
January 22, 2008, 23:27:06 pm »
here's a shot of the crossmember under the seat, it is not attached to the floor pan
___________________
Roy
Reply #41 on:
January 23, 2008, 11:04:17 am »
I had a look through my pictures last night and they were all too big for my photo hosting site! I'll shrink them down tonight and try to get a few up, but Grelland has posted most of the ones you need!
Glauco
Reply #42 on:
January 23, 2008, 14:53:37 pm »
I think I have a different car, I don't recognize any of the pictures :p
I just removed a plate and found 2 other bolts, tomorrow I'll do the other side and then have another try..
thanks for the pictures, I've printed them and I am going to take another close look at the car
Glauco
Reply #43 on:
January 23, 2008, 15:47:26 pm »
Quote from: Grelland on January 22, 2008, 23:27:06 pm
Here are where the Bolts are located under the rear seat on a Ghia and there is also one bolt located in each rear wheelwell hope this helps
Last Edit: January 23, 2008, 15:48:59 pm by Shubee2 (DSK)
Glauco
Reply #44 on:
January 23, 2008, 15:52:16 pm »
thanks shubee2, you're almost like a gardian angle
Reply #45 on:
January 23, 2008, 15:55:48 pm »
Quote from: Mr.Oldskool on January 23, 2008, 15:52:16 pm
LOL
Glauco
Reply #46 on:
January 25, 2008, 18:44:21 pm »
I finaly got the body and the chassis seperated.
thanks guys! now the real work can start
does by any chance somebody knows how much men you need to lift a KG body
Last Edit: January 25, 2008, 18:57:01 pm by Mr.Oldskool
wolfswest
Reply #47 on:
January 25, 2008, 20:25:28 pm »
c'mon man, where are the pictures? you lazy @ss...
Reply #48 on:
January 26, 2008, 00:58:13 am »
Quote from: Mr.Oldskool on January 25, 2008, 18:44:21 pm
if it is rusty? you dont need as many just shake it a few times and see what falls off LMAO
I would Say 6 Guys
wolfswest
Reply #49 on:
January 26, 2008, 11:12:26 am »
No need to search 6 guys to lift the body. Just call Dim! He will fix it all by himself...
....If he didn't got bitchslapped by his wife...
Glauco
Reply #50 on:
January 26, 2008, 17:30:48 pm »
Quote from: wolfswest on January 26, 2008, 11:12:26 am
dim trew the ball and chaines out, he is a single man now
[/quote]if it is rusty? you dont need as many just shake it a few times and see what falls off LMAO
I would Say 6 Guys
[/quote]
all in all it isn that rusty, my guess would also be 6 guys...
Glauco
Reply #51 on:
February 10, 2008, 17:47:23 pm »
hye guys,
a little update.
yesterday I finally got the chance to bring the chassis home so that's a start.
I wanted do close the holes for the bumpers but found out that the the complete front end is welded and rewelded, doesn't look to good, half of it is wasted away, thinking about putting in a complete new front end.
I'll try to make some photo's tomorrow
wolfswest
Reply #52 on:
March 21, 2008, 16:38:27 pm »
C'mon man, give us an update. I know that you are working on a wicked backseat... pictures please!!
Glauco
Reply #53 on:
March 24, 2008, 18:25:53 pm »
Quote from: wolfswest on March 21, 2008, 16:38:27 pm
I'm still working on the backseat for now, I needs a little more polyester than I expected so I'll have to wait untill tomorrow to get some more, and then I'll show some pictures, first I got to make sure it gets together
Glauco
Reply #54 on:
March 29, 2008, 13:06:11 pm »
ok, a little update for now
I now it has been quit the last few weeks, but I've changed work and still need to get it all together
I've been working on a new backseat, made a form and coated it with polyester, it's not finished yey, but here are some photo's, don't mind the collourdifference, half of it is still wet...
what do you guys think?
glauco
Glauco
Reply #55 on:
April 06, 2008, 17:29:50 pm »
here you can see the backseat in the car, this is how it will stay for a little while, hope it won't rain this week so I can do some bodywork...
glauco
Glauco
Reply #56 on:
May 25, 2008, 17:17:30 pm »
hye guys,
long time no hear, here's a little update
I bought some weld in parts for the car, the headlights, the parts under the door, the weel arges.
the front end is almost finished, the holes in the dashboard are gone too, there will come new ones, the tank lid is closed, and that's about it for now I think
first foto shows my paintskills:p, it shows how the dasboard is going to look like (sort of), allong with meters, radio and equalizer, under the dashboard there will be an 8-trackplayer and maybe an amplifyer (all original '80s style). I was also thinking of a kamei console with 4 holes for more meters, also originaly from the '80s. what do you think?
second foto is the tank lid
third foto shows the front end
don't look at the bad welding, I had to archweld them because I broke the TIG-welder this will be fixed somewhere this week.
enjoy
glauco
Last Edit: May 25, 2008, 18:41:06 pm by Mr.Oldskool
Glauco
Reply #57 on:
June 05, 2008, 15:28:28 pm »
today almost was another day of doing nothing because of the rain (don't have space in the garage to work) , but I found a way to work in the rain
it keeps me dry and this way the work can continue
cheers
glauco
wolfswest
Reply #58 on:
June 05, 2008, 18:04:53 pm »
allright! Keep up the good work, it's not very long anymore till DDD, better not make it to ddd and finish the car like you want, don't start cutting corners and it will work out fine...
Dem
Reply #59 on:
June 05, 2008, 20:06:36 pm »
yeah keep up the good work.
is that a 205 GTI i see in the background??? love to own one. have had two 205's but never a GTI... supercars, but not good to have an accident in.
