September 23, 2026, 00:17:16 am
| | |-+  1680ccm basket case
Author Topic: 1680ccm basket case  (Read 14355 times)
Mangokid
"Inhale the world", (in memory of MH)
« on: September 06, 2006, 13:13:34 pm »
Ok guys, so it might be OT, and it's not my engine, but it bugs the crap out of me, and perhaps some of you out there can solve my problem, even though it's got nothing to do with IDA's and low 11's.
Engine is:
AS21 case
std. 1600 heads, (mild porting but std. valves)
SCAT Valvesprings, retainers, caps etc.
2x Solex 40mm Carbs
SCAT c35 cam
Mahle sylinders
std. balanced crank, rods, 300gr lightened flywheel
32mm filter-oilpump
009
Bosch red-coil
Problem is, it won't run right. It seemes ok in the high revs, but when i hit 80km/h in 4th, 60km/h in 3rd  it runs like shit, shaking, tumbling goddammit.
It smells like it runs rich but it's hot like it runs very lean.
What's up?
My old man's preoccupied with gas mileage so that's why we didn't put together a 2110 in the first place.
To really know the edge and what lies beyond, one must have passed it.
« Reply #1 on: September 06, 2006, 17:04:19 pm »
just an idea but those 40mm solex's are well known for wearing on the sharfts - I had this problem when I rebuilt an old stock 356 motor that ran these carbs.
Might be worth whipping them off and checking for play/movement in the throttle sharfts - just an idea dude
« Reply #2 on: September 06, 2006, 17:50:12 pm »
Do you mean 40mm Kadrons or 40P11 Porsche carbs??
What do your spark plugs tell you?
Where is the timing set?
Are the points adjusted correctly?
Are the plug wires worn?
Are the carbs in synch?
Pull off the valve covers, check your clearences, and generally make sure everything is ok. Ive had those Scat lash caps fall off!
Mangokid
« Reply #3 on: September 06, 2006, 18:32:50 pm »
Ok, sorry for the lack of info guys, but here:
I mean 40mm Kadrons, and they are brand new, and seller told me they were jetted for 1600+, and that they were well suited for the c35 cam. Much more than that I don't know.
They tell me that i got a bright and powerful spark on every turn, and they are just the right colour after being run for a couple of miles. I've tried several brands with identical results.
12 degrees pre, but I've also tried everything from next to nothing up to 21 degrees pre. Marginal differences.
yes, and I've tried a set up with WBX-ignition. Same result, crap.
Brand new, and i've tried a couple of others too, all from bone stock to "hi-tech" bullshit wires.
yes, both on idle and when it's revved up.
Valve covers have been off several times, and no clearances have changed.
Compression 8:1, equal on all four.
« Reply #4 on: September 06, 2006, 19:13:08 pm »
So if I read your post correctly, you are saying that it runs ok until about 80km/h, then it starts shaking, but when you get higher revs it cleans out and drives ok again? That sounds like the carbs are having a hard time transitioning from the idle to main circut. It wouldnt hurt to rebuild/clean the carbs, Kadrons are super easy!
Run the car up to the point where it starts to run like sh!t, then immediately shut it off, coast to a stop, and do a plug reading.
What jets are in the Kadrons? Factory is 55 idle and 130 main, these should work well on your motor. I would gauge the jets to make sure they havent been drilled out.
Good luck!
Mangokid
« Reply #5 on: September 14, 2006, 14:55:38 pm »
The Kadrons are brand new, as well as the manifoils, linkage etc etc.
Mains are 150 and idles are 60
I've done a few plug readings, and the answer is still the same. Like they should be, no matter where i cut the engine.
It sounds "ok" when I'm revving it up stillstanding, but when driving problems like the ones described above occur.
Still haven't figured out this one.
Anyone else? Thanks so far guys!
SilverPig
Alles klar?
« Reply #6 on: September 14, 2006, 15:40:51 pm »
Aha..."seller told me they were jetted for 1600+, and that they were well suited for the c35 cam"
When did you start to listen to other peoples beliefs and thoughts? Wink
Say hello to my little friend!
Mangokid
« Reply #7 on: September 14, 2006, 15:52:07 pm »
Never, just for once thought i could trust someone, but hell, that sucker is out of business today...guess whom, hehe.
