September 22, 2026, 21:25:18 pm
| | |-+  Autometer Oil Pressure Sender
Author Topic: Autometer Oil Pressure Sender  (Read 6485 times)
« on: January 08, 2008, 15:02:50 pm »
I ended up buying Autometer gauges for the '67. From what I have been reading, the Autometer oil pressure sender doesn't like to be mounted to the engine. To much vibration. Anyone else seen this? How did you mount the sender if you are using the Autometer gauges?
Thanks,
« Reply #1 on: January 08, 2008, 15:33:38 pm »
Hi Louis Dont Know to Much On the Auto meter Sender on the VW But I know VDO use to make a Pressure hose that was about a foot long to mount the oil Pressure sender on a type4 motor I dont see any problems mounting it to the case  I ran Autometer Gauges in My Cuda and never had a Problem
« Reply #2 on: January 08, 2008, 16:29:12 pm »
Thanks for the input. I may just run it and see what happens.
ESH
« Reply #3 on: January 08, 2008, 16:35:00 pm »
My first one lasted for just over 30K (miles) but the second only made something like 5K. I have heard of quite a few failures in general. Mounting it remotely may be a solution or failing that just treat them as consumables and keep a spare handy.
Smiley
Lanny Hussey
« Reply #4 on: January 08, 2008, 16:52:12 pm »
I usually run a dash 3 hose from the case to a remote location for the senders. A 1/8 NPT to dash 3 adaptor will work in the VW case as long as you are very careful not to overtighten.
