September 02, 2026, 21:57:37 pm
352300 Posts in 28955 Topics by 6923 Members
| |-+  For sale!
| | |-+  Engine stuff for sale(turbo)
Author Topic: Engine stuff for sale(turbo)  (Read 4400 times)
german8rcoupe
« on: January 17, 2008, 17:54:48 pm »
  I have decided to sell the following parts as realsitically I,m never going to get around to racing again........
 My tube framed Ghia will be coming up soon too once I get some new pics.
  Engine bits:
  CRANK AND RODS: SCAT VOLKSTROKER 2 82MM STROKER CRANK/PORSCHE JOURNAL NEVER USED.
                                  BUGPACK RACE RODS PORSCHE JOURNAL 5.352" LENGTH.  TWO SEASONS USE.  £400 for both.
  PISTONS/CYLINDERS:  EX-MARTY STAGGS STROKER HEIGHT 90.5s WITH CHAMFERED DOMES, TOTAL SEAL 2ND RINGS, TEFLON BUTTONS.
                                      CYLINDERS HAVE BEEN POWERSLEEVED TO FIT HEADS CUT FOR 94s. WILL TAKE 40LB BOOST. FEW RUNS USEAGE ONLY.£150
HEADS: EX-MARTY STAGGS TURBO PREPPED STREET ELIMINATORS.COPPER SEALS."They have custom sized valves that are around 45 x 38mm (stainless steel). They also have special dual springs that are VW diameter but have 340 pounds of pressure at full lift. This is about 40 to 50 pounds better than most and is my preferred setup. I have never had valve float with these. The retainers are Ti. They are fully ported and polished and have had the chambers re-worked for turbo use. The chambers are 60 cc's. They are used but in perfect working order." £500
   HOLLEY 650 CARB WITH POWER VALVE CONVERSION BY MARTY STAGGS.NEW UNUSED WITH FILTER.£215(now sold)
   TURBOCHARGER TO4B. NEW UNUSED.£400(now sold)
 DELTAGATE WASTEGATE.NEW UNUSED.£100(now sold)
OBERG SCREENED OIL FILTER.USED. £30
  LIGHTENED FLYWHEEL. SURFACE RUST ONLY.£45
 1.4:1 RATIO ROCKERS.£65(sold)
  3/8 MOLY PUSHRODS.NEW UNUSED.£25(sold)
 BERG OIL PUMP.NEW UNUSED.£40(sold)
 BERG OIL PRESSURE RELIEF COVER.NEW UNUSED.£10(sold)
 SCAT MOLY GLAND NUT. NEW UNUSED.£5(sold)
   Postage will need to be sorted obviously.........
  Cheers,
   Ross.
« Last Edit: January 19, 2008, 01:02:19 am by german8rcoupe » Logged
german8rcoupe
« Reply #1 on: January 17, 2008, 20:28:41 pm »
  Oil pump and cover sold to DTH.
64 RCR
« Reply #2 on: January 17, 2008, 22:54:02 pm »
german8rcoupe
YGPM
 Wink
german8rcoupe
« Reply #3 on: January 17, 2008, 23:02:38 pm »
 Paul, you should have a PM back.
autobarnhauler
« Reply #4 on: January 18, 2008, 08:08:50 am »
hi, im interested in the push rods! can u pm me with postage, im in uk! thanks Cool
GWB, founder member
.... there and back again, a rocket buses tail....
german8rcoupe
« Reply #5 on: January 18, 2008, 11:29:55 am »
 Sorry mate, think they are sold.......
