February 06, 2026, 20:43:13 pm
352001 Posts in 28861 Topics by 6914 Members
Latest Member: 67gtv220
| | |-+  51.5 webers ???
Author Topic: 51.5 webers ???  (Read 7176 times)
Russell
« on: January 19, 2008, 00:09:16 am »
Guys
Q1: apart from CB performance does anyone else stock these, i seem to think Empi did them as well ??
Q2: Do the bolt on to 48IDA manifolds ? as i cant seem to find manifolds for 51.5s ??
Any advise greatly appreaciated, cheers
Best Regards
Russell
Frank LUX
Back...Soon...hopefully!!!
« Reply #1 on: January 19, 2008, 00:28:01 am »
Answer to Q:2 Port them if you can't find them... Wink Grin Grin
Frank
Frank LUX
« Reply #2 on: January 19, 2008, 00:28:41 am »
BTW: I think EMPI casted the 51.5 IDA's as well....
Frank
71CALRIPPER
« Reply #3 on: January 19, 2008, 01:49:28 am »
i am sure Jack C would ?
The Burnout King
« Reply #4 on: January 19, 2008, 02:28:01 am »
PM Sent....
go BIG or go HOME
www.theburnoutking.com
Joe_G
« Reply #5 on: January 19, 2008, 09:46:32 am »
Got mine from Vee Dub parts Unltd with all the mods done Smiley
SteveW
« Reply #6 on: January 19, 2008, 09:55:53 am »
The best ones to buy are the JayCee 51.5mm IDA's, I'm sure it was all over cal-look.com that the empi ones were crap! CB or Vee Dub parts and of course Jack himself are the only stockists as far as I know.
Shawn Geers may also do them(?) but I think his main carbs are the bigger Terminator II carbs..
Steve
1961 Oldspeed Beetle
1970 Stock Beetle.
« Reply #7 on: January 19, 2008, 10:31:36 am »
Russel
I do the work too if you don't want to ship them so far . Main thing is that you cannot bore every 48 to 51,5 because of the progrssion hole of the idelescrew .
I use my own manlfolds for Type1 heads and CB's for superflows .
Russell
« Reply #8 on: January 19, 2008, 11:47:29 am »
Its for the 3litre aprm motor i have, i need to check the heads to see that the manifolds i have are 48idas, if so Ill give you a call, please pm me your number, cheers
Dom, Thanks if i can get them in europe it will be quicker, will let you.
All, Thanks
Best Regards
Russell
« Reply #9 on: January 19, 2008, 14:35:02 pm »
Pm sent
For your engine you need all done , bore for 51,5 , larger float chamber , bigger venturis , cut the auxiliary venturi and some good velocity stacks . I do diffenet versions , depends on engine size and needs . Most of the older carbs can not be bored to 51,5 only smaller .
