September 22, 2026, 23:17:19 pm
Red Dashboard lamp on old Empi gauges
Topic: Red Dashboard lamp on old Empi gauges (Read 16740 times)
1957lowlight
Philip Steenackers
January 20, 2008, 20:43:10 pm »
Hey guys,
Does anyone knows what kind of red lamps were used on the empi-gauge panel to check the oil pressure? I want to install one between my period VDO gauges
First picture is an Empi gauge set up which is in my friend Kurt's 1967 Ruby Red Ragtop
Second picture is where I want to put it (I think above the gas gauge...)
If you have such a redlamp for sale, please let my know...
Philip
Re: Red Dashboard lamp on old Empi gauges
January 20, 2008, 20:48:57 pm »
philip the red lamp under the amps
? that light was for the hand brake i've the same in my car
Last Edit: January 20, 2008, 22:49:17 pm by speedwell
January 20, 2008, 20:56:54 pm »
here's the lamps mine is broken
1957lowlight
Philip Steenackers
January 20, 2008, 21:47:22 pm »
Hey thanks speedwell, I didn't know it was a handbrake warninglight (very trendy item for the days back then), but I would use it as a oilpressure warning light.
Thanks for the info and pictures...
Philip
Russell
January 20, 2008, 22:27:07 pm »
what about a shift litght very discreet...
Best Regards
Russell
January 20, 2008, 22:39:43 pm »
brilliant idea!
but how to hook it up if you're not running a monster tach? are seperate shift light modules available?
DVK ~
1957lowlight
Philip Steenackers
January 21, 2008, 19:43:01 pm »
Yes indeed, my friends, a little shiftlight would be very cool, but as my RPM tacho is 50 years old, I think, I can't put a shiftlight to that... If anyone has a sollution for this, that would be fine.
Philip
January 21, 2008, 20:34:42 pm »
may be able to run just a shift light off some ignition boxes?
January 21, 2008, 20:57:01 pm »
mmh, i was wondering the same.
does an MSD 6AL have provision for that?
DVK ~
Frank LUX
Back...Soon...hopefully!!!
January 21, 2008, 21:56:42 pm »
Quote from: 1957lowlight on January 20, 2008, 20:43:10 pm
Hey guys,
Philip
Hi Philip,
I have what you looking for...
But i don't know where at this moment...
Will keep looking and will let you know,
Frank
lawrence
January 22, 2008, 03:58:09 am »
One of these would work well
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM%2D5330&N=700+4294925228+4294922411+4294859118+400442+4294786786+115&autoview=sku
but you would have to get these items also
http://store.summitracing.com/partdetail.asp?part=ATM-5310
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ATM%2D5356&N=700+4294925228+4294922411+400442+4294859118+4294786786&autoview=sku
Last Edit: January 24, 2008, 00:36:20 am by lawrence
"Happiness is a Hot VW!"
Tobi/DFL
January 22, 2008, 09:51:04 am »
I use one of these in my oval and it works just fine with the Mallory HyFire VI box.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2DG2945&N=700+115&autoview=sku
Bye,
Tobi
1957lowlight
Philip Steenackers
January 23, 2008, 21:54:39 pm »
Thanks guys for all your nice info.
Frank, if you found it back let me know, take some pictures. We can meet at the Volksworldshow.
Philip
lawrence
January 24, 2008, 00:37:48 am »
Just realized that my first two links were exactly the same. I have made the necessary corrections, lowlight.
