September 24, 2026, 21:43:06 pm
| |-+  For sale!
| | |-+  Dragster Manx dune buggy from the 80's
Author Topic: Dragster Manx dune buggy from the 80's  (Read 3428 times)
guillaume
« on: January 22, 2008, 19:10:56 pm »
Built in the 80’s in California on a VW 1955 Chassis.
It wons many trophies at this time. It was a very fast car and it runs in the 10s.
In 1991, the Manx was imported by FROG SPECIALITIES for VW PARTS with the current engine. It was pink and blue. Then it was used in France for few years and after it has been stored for 15 years.
Engine has been fully rebuild and works perfectly.
Specifications:
Engine 2276cc
Crankcase: TYPE 1 MAGNESIUM AS21
Cylinders: JAYCEE 94mm
Pistons: J&E 94mm
Crank: BUGPACK 82mm WEDGEMATED
Rods: BUGPACK H-BEAM 5”354 PORSCHE
Camshaft: MODIFIED ENGLE FK87
Rockers: 1.5 : 1 AUTOCRAFT
Lifters: GENE BERG LUBE A LOBE
Pushrods: GENE BERG CHROMOLY
Heads: BUGPACK SUPERFLO PORTED AND POLISHED by SLIDE PERFORMANCE
Valves: 48 x 38mm TITANIUM
Ratio: 12.6 / 1
Carbs: 48 IDA MODIFIED
Exhaust: 1”7/8
Ignition: MSD 7AL-2
Oil system: MELLING OIL PUMP MODIFIED, FULL FLOW, SYSTEM 1 FILTER
Trans:
DAVE FOLTS Swing Axle gearbox. Aluminium SPOOL
Contact:
autohaus047@aol.com
0033(0)620067474
« Last Edit: May 11, 2008, 02:33:22 am by guillaume » Logged
guillaume
« Reply #1 on: February 24, 2008, 20:23:34 pm »
Still for sale.
