November 03, 2026, 05:30:30 am
for you D7EA guys
Topic: for you D7EA guys (Read 13405 times)
for you D7EA guys
January 22, 2008, 20:01:55 pm »
We were out of D7EA's at work the other day, but had the Bosch cross refernced plugs in stock....X5DC.
The Bosch plug has a projected nose, forcing electrode farther into chamber. When I was tuning stockers years ago, one trick I learned to get some more response from them was to run a W8BC or W7BC instead of "AC", meaning a projected nose plug. It would certainly sharpen up the idle and throttle response on a stocker or a Kadron motor. I have read that forcing the plug into the chamber further, is like advancing timing, and like having more "squish" in deck.
Anyway, for you D7EA guys, you might try the Bosch plugs next time around.
Re: for you D7EA guys
January 23, 2008, 01:31:03 am »
It doesn't send threads out into the chamber, does it? That's a no-no in the Fisher book, causing detonation.
January 23, 2008, 01:33:05 am »
Quote from: javabug on January 23, 2008, 01:31:03 am
no threads are the same length just the ceramic nose and electrode protrudes.
January 23, 2008, 01:33:54 am »
Humm, I may give that a try.
January 23, 2008, 02:27:20 am »
Quote from: Jim Ratto on January 23, 2008, 01:33:05 am
Should be ok for N/A but projected tip is a no no for nitrous &turbo applications,
cheers richie,uk
John Rayburn
January 23, 2008, 03:12:24 am »
Thanks Jim, I'll try them. I've always been a big advocate of projected nose plugs!
I also park at Nick's.
January 23, 2008, 04:27:05 am »
Cool, maybe I'll grab a set some time. I"m going to expand my jet collection soon and I'll be due for new plugs.
Dick Mitchell
January 23, 2008, 08:56:44 am »
I'll switch mine as well and be sure to get back to you on the results. Thanks for the tip
alex d
January 23, 2008, 10:08:26 am »
anyone tried the DP7EA compared to the D7EA?
January 23, 2008, 21:03:07 pm »
Quote from: John Rayburn on January 23, 2008, 03:12:24 am
sure John. Me too, seems the projected nose plugs in the little stockers sure woke them up. Let me know if you can't find the Bosch anywhere. The OE application was the old E30 BMW M3, S14 engine.
We have them here.
Jim
January 23, 2008, 21:49:08 pm »
Slightly off topic. Anyone have any thoughts on NKG vs Bosch plugs?
alex d
January 23, 2008, 22:30:46 pm »
Jim have you compared the Bosch versus the DP7EA (the projected tip version of the D7EA)?
January 23, 2008, 22:34:59 pm »
Quote from: alex d on January 23, 2008, 22:30:46 pm
no, wasn't aware of that plug, to be honest with you. My catalog doesn't cross ref to it.
thanks,
Jim
John Rayburn
January 24, 2008, 06:20:23 am »
Quote from: Jim Ratto on January 23, 2008, 21:03:07 pm
We have them here.
Jim
Thank's Jim, if I can't find them at my local haunts, I'll hit you up for a couple boxes!
January 24, 2008, 06:40:09 am »
DP7ea and DPR7ea are motorcycle plugs,cant help any more than that i am afraid
January 24, 2008, 09:00:12 am »
Quote from: louisb on January 23, 2008, 21:49:08 pm
i have always prefered NGK, but i am not sure why? but i have been told to stay away fro the Champion ones that are grooved and will eat the treads fo you head.
