September 02, 2026, 00:30:05 am
| | |-+  Jesse's '64 - Dynoday
Pages: 1 ... 5 6 [7] 8 Print
Author Topic: Jesse's '64 - Dynoday  (Read 153874 times)
« Reply #180 on: May 17, 2011, 19:13:51 pm »
Here we go Smiley
peach_
« Reply #181 on: May 17, 2011, 20:15:56 pm »
Here we go Smiley
 Cool sweet dude  Cool
SAS RENN-WAGENS and proud
#CALLOOKDRAGS
volkskris
« Reply #182 on: May 17, 2011, 23:12:08 pm »
nice! Cool seems like only one to two full days work to get it complete Smiley
« Reply #183 on: May 22, 2011, 19:28:33 pm »
Put on some fenders etc Smiley.
And new stacks
Felix/DFL
« Reply #184 on: May 25, 2011, 21:30:49 pm »
Nice!
Maybe you want to switch that yellow plastic "things" against HD supports made by VEWIB out of OEM castings.
http://www.ge-ma-classics-shop.de/index.php/cPath/8_90_302/category/hinterachse-kaefer-karmann-typ14.html
Very nice pieces and they aren`t higher like the yellow one`s which lift your engine & gearbox and could get you into shift problems. Lay both side to side and you see what I am talking about.
The HD spring plate bushings are even wonderfull and non comparable to the red plastic litter which even aren`t correct in measurement.
http://www.vewib.de/cms/website.php?id=/en/brand.htm
Have fun.
« Reply #185 on: June 02, 2011, 21:31:49 pm »
A1! And Steve Tims welded heads Smiley
« Last Edit: June 02, 2011, 21:52:44 pm by Jesse/DVK » Logged
« Reply #186 on: June 02, 2011, 21:46:46 pm »
Nice!
« Reply #187 on: June 06, 2011, 09:00:37 am »
My cars Smiley
Crankshaft etc will be balanced tonight so I can start building the engine this week and weekend. Deckheight came out to 1.25mm which is ok with 53cc heads. 9.8:1 CR
« Reply #188 on: June 13, 2011, 22:29:21 pm »
Worked quitte some time on the engine this weekend. Hope to start her up next weekend!
Pushrodlength
Back together
Almost done
thehanz DVK
« Reply #189 on: June 15, 2011, 18:35:50 pm »
looking good....when it's running okay i have the next engine to build for you  Grin....
see you at Budel ?? or engine time this weekend ?
« Reply #190 on: June 16, 2011, 21:36:48 pm »
Engine time this weekend Hans! Just finished mounting my breather box, coil, wiring etc. Putting in the engine tomorrow night and than start up this Saturday.
Maybe Budel on sunday depends on the weather.
Building your engine is no problem! We will discuss it Cheesy
« Reply #191 on: June 16, 2011, 22:28:43 pm »
Where's your pick-up tube Huh
« Reply #192 on: June 16, 2011, 23:14:01 pm »
Removed it with trial assembly and to clean the case. Didn't forget it Zach Wink
« Reply #193 on: June 18, 2011, 22:22:14 pm »
So put in the engine and cranked for oil pressure. Everything ok. But than we found out that the magnaspark 2 coil was leaking! They are hard to come by in the Netherlands so thinking of replacing it with a MSD blaster 2 coil. Should be ok?
« Reply #194 on: June 19, 2011, 21:32:46 pm »
Anyone has a quick answer if the MSD blaster 2 or high vibration coil will work with the magnaspark 2 and magnaspark 2 wires? The coils have the same specs so I guess it should be ok.
« Reply #195 on: June 20, 2011, 09:40:49 am »
too bad the coil is malfunctioning, one would expect more of a new product.
where will you get the MSD coil?
have you contacted CBPerformance yet? perhaps a quick phone call would help.
« Reply #196 on: June 20, 2011, 10:17:20 am »
Just ordered a MSD High Vibration coil at a local Honda/Tupperware tuning shop Cheesy
« Reply #197 on: June 24, 2011, 06:43:25 am »
Fired her up! To bad she is leaking at the valve covers. Need to sort that out.
« Reply #198 on: June 24, 2011, 15:13:55 pm »
looking gooood!
perhaps someone can chime in how on earth you got an oil leak at the valve covers??
the oil pressure was fine, right?
peach_
« Reply #199 on: June 24, 2011, 17:53:49 pm »
 Cool Cool awesome dude, what exhaust have you got on that?
#CALLOOKDRAGS
volkskris
« Reply #200 on: June 24, 2011, 21:51:13 pm »
A1 lowdown Wink
Felix/DFL
« Reply #201 on: June 25, 2011, 18:58:57 pm »
Now that looks perfect!
What v.covers are you using? I learned that it`s always a good idea to "glue" in the sealing in the aftermarked v.cover with dirko HT or other simular products.
Have fun!
« Reply #202 on: June 25, 2011, 19:13:29 pm »
Stock but they are do not have enough room.. Have to find a solution quick before EBI!!
fredy66
« Reply #203 on: June 25, 2011, 20:36:58 pm »
good luck man some body here can help  you
arabia slugs
airstuff
« Reply #204 on: June 27, 2011, 21:20:20 pm »
Beautifull engine man Smiley
« Reply #205 on: June 28, 2011, 14:00:51 pm »
Thanks! Just ordered a pair of SCAT valve covers which should work perfectly! So EBI here I come!
Small vid!
<a href="http://www.youtube.com/v/NLbnvS1_GrY" target="_blank">http://www.youtube.com/v/NLbnvS1_GrY</a>
peach_
« Reply #206 on: June 28, 2011, 14:50:29 pm »
Small vid!
Sweet dude looks the dogs!
Have you got any tips for first time start up? like cam break in etc?
#CALLOOKDRAGS
« Reply #207 on: June 30, 2011, 12:41:07 pm »
buddy, you busy at work or something? i sent word...
are YOU ready and set for tomorrow?  Wink
peach_
« Reply #208 on: July 12, 2011, 23:13:39 pm »
So is this all done now then dude?
#CALLOOKDRAGS
Sander/DVK
« Reply #209 on: July 20, 2011, 23:58:45 pm »
Yeah, tell us how it drives Jesse  Huh
