November 03, 2026, 23:42:35 pm
| | |-+  difference between "cal-look" rubbers and original vw rubbers with no chrome
Author Topic: difference between "cal-look" rubbers and original vw rubbers with no chrome  (Read 9790 times)
wolfswest
« on: January 24, 2008, 13:18:01 pm »
Hi guys,
Maybe this question is more for the dutch and belgian guys here.  I'm thinking to remove my chrome strip rubbers for plain black ones.
Now I see in the paruzzi-catalogue: "cal-look" rubbers and "original rubbers without chrome strip"....  They are both plain black but what is the difference?  the originals cost twice as much as the cal-look ones...  Or is it just a "quality" issue....  Hope to receive more info and pictures if there are visual differences...
Dem
Gunter
« Reply #1 on: January 24, 2008, 13:34:17 pm »
or check the CSP catalog
CalLook and Standard version both carry no chrome or plastic trim
that is why the confusion
but it is indeed two different models
pm me on gh@csp-shop.de and I will quote for your model the callook and std version (off course the std version in german quality)
Gunter
« Reply #2 on: January 24, 2008, 13:34:44 pm »
Both Look the Same both Black without Chrome But Remember you get what you pay for  Most Cal Look Rubber Kits Vary in Thickness depending on who's kit you use also the Cal Look Rubber kits all have a Heated Seam which you can see but some are better then others depending on who and where it was made Japan?Tiwann?India? Ect. Now on the Original Window Kits without chrome they are Original Quality Fit Well And and have a nice looking seam and the rubber holds up much better.  In the past I have used the Cal look Rubber kits from BugPack They are made in the USA and the seams are not to bad, West Coast Metric are also made in the USA and are also good but the Rubber is wider then stock the only advantage to that is if you car was painted at on time with the winbows in the wider lip covers the old paint edge. hope this Helps  just Remember you cant get Better Rubber and trim Piece's then the VW Factory German made.
« Reply #3 on: January 24, 2008, 13:56:30 pm »
The cal look rubbers are more rounded profile than the standard ones, and can look really bulged. Wink
wolfswest
« Reply #4 on: January 24, 2008, 14:12:29 pm »
Okay, Gary, Neil, Gunter,  Grin
thx for the good information.  If I do it I will go for the original german vw ones...
Dem
« Reply #5 on: January 24, 2008, 18:29:58 pm »
not sure if you have popouts, but if you do you can always paint the chromestrip Satin black and it will look like a callookrubber.
wolfswest
« Reply #6 on: January 24, 2008, 18:39:41 pm »
yeah,  I have pop outs and that was also a question...  I don't like the look with all black rubbers and "aluminium strips" on the pop outs...  I will paint it black together with my front side window chrome...
Dem
« Reply #7 on: January 25, 2008, 07:10:36 am »
hecho en Mexico
Eddie DVK
« Reply #8 on: January 25, 2008, 12:22:29 pm »
Thats what I thought too, have a set of both. and the Cal look ones look fat.
While the 'Standard' (from a spar Käfer) are more flat.
Regards Edgar
benssp
www.callookvw.com
« Reply #9 on: January 25, 2008, 16:34:53 pm »
We(VW Heritage) stock aftermarket plain rubbers(quite wide and thick) genuine plain rubbers(thin and flat) and the deluxe OE rubbers to accept the trim Grin
www.vwheritage.com  My Job
YMCA
« Reply #10 on: January 26, 2008, 01:41:25 am »
you can take the frames apart and have them powdercoated black
« Reply #11 on: February 11, 2008, 12:59:50 pm »
any chance Empi makes good cal-look rubbers?
i found an unused set for no that much....
« Reply #12 on: February 11, 2008, 17:02:01 pm »
if is EMPI it will be the Tiawann or China Made Rubber the Real Empi never made cal look rubber
PIMPPRIDE
« Reply #13 on: February 28, 2008, 02:03:13 am »
original rubber would have molded corners for the bends, where cal look is a straight extrusion, molded corners release the tension on the sharp bend of the rubber in the corner to prevent cracking and ultimately fit better then the non molded versions...
Anthony / ISP WEST
~ the link to a small FAQ / Guide I wrote http://reviews.ebay.com/Window-Rubber-for-Air-Cooled-Volkswagens_W0QQugidZ10000000004885409
« Reply #14 on: March 15, 2008, 01:11:19 am »
too bad you don't sell cal-look window seals for my year...
