October 14, 2026, 17:06:35 pm
| | |-+  To Shuffle pin or not
Author Topic: To Shuffle pin or not  (Read 7362 times)
drgouk
« on: January 25, 2008, 07:35:58 am »
Hi,  Looking for advice on my next project engine, A 2275cc bulit on a mag case. Do i need to shuffle pin or not?
I am planing on using a DPR full circle 82mm welded crank with 411 centre main, vw rod journal.
It will have CE or JPM heads.
Look forward to your opinions.
Regards
David Gouk
« Reply #1 on: January 25, 2008, 07:43:02 am »
"full circle....411 center main....VW journal"
That's about the last engine that needs shuffle pins.
What RPMs will it turn?
drgouk
« Reply #2 on: January 25, 2008, 07:44:12 am »
I would think 7000-7500 rpm.
Yeah, i know, it should be a strong piece.
drgouk
« Reply #3 on: January 25, 2008, 20:01:34 pm »
The other thing is, how many guys run the rubber cam plug? Or should i machine the case to take a metal cam plug?
Jason Young
« Reply #4 on: January 27, 2008, 09:51:37 am »
the mexican cases use a rubber plug, mine fit nice and works well. i put some sealant around them, rubber or metal.
John Rayburn
« Reply #5 on: January 27, 2008, 19:05:30 pm »
Machine your case for the metal plug!!!! Also , it's always cheap insurance to shufflepin.
I also park at Nick's.
« Reply #6 on: January 28, 2008, 06:46:58 am »
Hi David
I would use shuffle pins on the center main in every case . It is a good way to make the case stronger . Don't know anything about full circle cranks .
Regards Udo
