September 23, 2026, 00:17:46 am
| | |-+  HEAD WELDING TEMP ?
Author Topic: HEAD WELDING TEMP ?  (Read 9512 times)
Black Sheep
less is more
« on: January 25, 2008, 19:59:03 pm »
Im going to have some welding done on my 044's , what temp is advisable to get the heads to before they start ?
And any other tips would be appreciated  Smiley
13.03 @ 98mph
« Reply #1 on: January 25, 2008, 20:24:28 pm »
Tip no 1:
Get someone to do it that knows what they are doing,thats all Smiley
cheers richie,uk
Black Sheep
less is more
« Reply #2 on: January 25, 2008, 20:52:10 pm »
cheers fella , any suggestions ? on this side of the pond . Hows the sabbatical going  Wink
13.03 @ 98mph
« Reply #3 on: January 26, 2008, 00:50:54 am »
when I worked at Small Car (SCS) They always pulled the seats out before welding the Heads they use to have a Big Oven I think they heated them up to either 500 or 750 before welding then let them cool in the oven after welding  I would Check with a Good Head Porter?
« Reply #4 on: January 26, 2008, 02:21:50 am »
Russ?
cheers richie
ugly duckling
« Reply #5 on: January 27, 2008, 02:43:21 am »
hello. i prefurr 450deg. 4043 alloy is the norm to use. in some instunses 5356 alloy only in the chamber area. i would say 4043 on anything on the 044 head. hopefully you wont get any snap crakkel pop when they cool down. put a heat blanket or back in the oven let cool down slow. and cross your fingers. good luck to ya .  UD.
benssp
www.callookvw.com
« Reply #6 on: January 27, 2008, 11:37:20 am »
Just send them over to Jeff, he's done enough of Richies Tongue
if you use www.parcelstogo.com it won't cost much and they are quick too. if you pad the box out with PG tips tea bags mr Webb will much appreciate it! Grin
www.vwheritage.com  My Job
YMCA
Black Sheep
less is more
« Reply #7 on: January 27, 2008, 13:52:01 pm »
What's the exchange rate on tea bags to , a little head repair Richie  Grin
13.03 @ 98mph
« Reply #8 on: January 27, 2008, 21:57:26 pm »
Just send the t bags,dont need the head Smiley
seriously Glen if its worth fixing just send it over and it will be done
cheers richie
Black Sheep
less is more
« Reply #9 on: January 27, 2008, 23:06:45 pm »
Cheers Richie , they need four welds in each intake chamber where some muppet took too material out of them in some ham fisted attempt to port them   Angry, all was ok till we started to machine them for duel springs and found the machining for the inlet valve breached the inlet chamber  Roll Eyes
Mucho tea bags to follow  Grin
« Last Edit: January 27, 2008, 23:08:59 pm by 49-rag » Logged
13.03 @ 98mph
