January 18, 2026, 03:44:18 am
67gtv220
my latest project 1962 COW-LOOK bug
10
11
12
13
14
Topic: my latest project 1962 COW-LOOK bug (Read 528109 times)
Re: my latest project 1962 COW-LOOK bug
Reply #300 on:
November 18, 2010, 05:18:42 am »
Doing some plumbing from resevoire to mastercylinder. Stainless tube i welded together for master. And I used a oval fluid tank or can and made a little alum tray to keep any drips off paint
Reply #301 on:
November 18, 2010, 05:20:30 am »
Mocked up, And now take it apart and clean and paint .
Kaferdog
Reply #302 on:
November 18, 2010, 09:30:10 am »
I am impressed .....AGAIN...!!...
low oval
Reply #303 on:
November 18, 2010, 09:39:15 am »
that's it! i'm not doing anything else on my bug till you finish this car. Or at least email me before you do these mods so I can see if I want to wait.
Nice job!
Reply #304 on:
November 18, 2010, 12:41:15 pm »
Quote from: low oval on November 18, 2010, 09:39:15 am
Nice job!
X 2,so many neat tricks and modifications.
61SNRF
Der Selten Kafers Charter Member
Reply #305 on:
November 18, 2010, 16:21:30 pm »
Don't mean to be a spoiler, but you know this limits the function of having a dual circuit M/C, right?
Someone needs to make a stealth reservoir with two chambers and two feed hoses to provide fluid to each port. In case of catastophic failure of one circuit, there would still be a supply of fluid to the remaining circuit.
Otherwise, outstanding attention to detail and craftsmanship. Well done Danny.
DKK - Lisa
Reply #306 on:
November 18, 2010, 16:53:48 pm »
Nice job!
Anything else? Have you been wrenching on the Oval?
roland
lates are the new splits...
Reply #307 on:
November 18, 2010, 17:20:23 pm »
Quote from: 61SNRF on November 18, 2010, 16:21:30 pm
Something like that? :
(not my work btw, but good stuff!)
Quote from: Deanodynosaurs on April 28, 2009, 22:09:06 pm
Right, I finally done something thats worth posting up!
The first part of this was siamising two brake fluid resevoirs together, as the car will be duel circuit, and I didn't want to fit a later plastic reservoiur.
I was actually really pleased with how this looked.
Next up was to cut the wheel well to accept it, and adjust the pressing. I was really nervous about doing as if I messsed it up their was no going back!
Anyway here's how it turned out! I think i'm happy with it!
Anyway, just thought I'd give you a bit more of a update!
Dude
And nice work Danny, as always!
Reply #308 on:
November 18, 2010, 20:04:26 pm »
Thanks for your input and I see what your talking about, But I dont see this part failing and starveing any fluid. If I'm correct duel circuit meaning theres a plunger for each front and rear brakes that fluid is being pushed. instead of one plunger for both front and rear,Thats what should be of concern in brake fluid being lost.
Last Edit: November 18, 2010, 20:05:59 pm by danny gabbard
61SNRF
Reply #309 on:
November 18, 2010, 20:18:43 pm »
The system is a failsafe in the event of some extreme failures and will probably never be tested in real life, so it's splitting hairs anyway
The idea behind the extra capacity of a separete reservoir is to ensure there is a adequate supply of fluid for the remaining good circuit. In your design, if there is a failure of one circuit there is little fluid in reserve for the remaining circuit.
I think a small improvement would be to put the Y right behind the reservoir so that you at least had the pipes and hoses to retain a small supply of fluid for each circuit indepenant of the other.
gibber!
Reply #310 on:
November 18, 2010, 20:19:45 pm »
Quote from: danny gabbard on November 18, 2010, 20:04:26 pm
I suppose you're right.
As long as there is only a failure in one of the circuits i.e. front or rear, then the other should retain the fluid already in the brake lines and still function.
Normally dual circuits are basically two independent systems with two reservoirs just contained together.
Last Edit: November 18, 2010, 20:21:17 pm by gibber!
1967 1500 Beetle
1970 Karmann Ghia
SSVWC member
61SNRF
Reply #311 on:
November 18, 2010, 20:30:55 pm »
A long standing design philosophy is
Form
follows
Function
. If you're going to change or modify any system then it should perform as good or better than the system it replaces.
Then make it look purdy
Reply #312 on:
November 18, 2010, 20:39:38 pm »
Quote from: 61SNRF on November 18, 2010, 20:18:43 pm
I think on the '67s they had a common reservoir with a little "dam" in it to separate the circuits. They could share the fluid up to the level of the dam.
Reply #313 on:
November 18, 2010, 21:59:29 pm »
I just made due with what I had. This deal is very low risk , you could probably cork the end of tube and drive it a hundred thousand miles and never have a problem. And if everybody followed the form and function rule you would not see 145s in the front of a lowered vw . Sorry if I sound like I am ranting.
61SNRF
Reply #314 on:
November 19, 2010, 04:16:16 am »
No, you're right. I knew someone would say something so I threw it out there.
It might have something to do with the original Federal Safety requirements that there was a complete separate system for each circuit. In actuality, I see little need for a large reserve of fluid in a drum brake car. Disc brake cars may require a little more reserve due to pad wear displacing the fluid.
What I would like to see is an early reservoir split apart and a divider inserted down the middle with two outlets on the bottom. This would be a stealth way to hide the dual reservoirs.
Running 145's is a little different than adapting a late model brake system to an early car too. I still believe in the three F's.
Reply #315 on:
January 12, 2011, 05:26:33 am »
Trying to get some loose ends like plumbing and electrical sorted out. I ended up with a faucet fuel pump and made a bracket to rubber mount. Painted and ready for install. And a bosch swith to turn on and off, Just want to thank paul or (plastic back) for switch !! God I hope this is DOT approved !!!!
Last Edit: January 12, 2011, 05:46:05 am by danny gabbard
Reply #316 on:
January 12, 2011, 05:31:54 am »
Few more shots of painted and installed. And will use braided line from pump to stainless bulk head fittings in tunnel of pan.
Reply #317 on:
January 12, 2011, 05:42:48 am »
Few things in trunk that I finished. 1st is a little plate to locate spare from slideing around and rubbing paint. and the finished brake fluid reservoir finished and painted and mounted.
Reply #318 on:
January 12, 2011, 05:44:55 am »
And the alum knob I am going to use to make key for hella battery cut-off swith to look like heater knob.
58vw
Reply #319 on:
January 12, 2011, 05:53:50 am »
that is trick....very cool idea...awesome work
www.4inbore.com
Angleflows...order them now
Chris W
Reply #320 on:
January 12, 2011, 06:07:40 am »
Great work as always!! I like the way you did the brake line through the tunnel to the passenger side.
Last Edit: January 12, 2011, 06:11:40 am by Chris W
Reply #321 on:
January 16, 2011, 23:03:46 pm »
DG,
Awesome work on the details!
That fuel pump mount is the TITS!
... super clean. And, the stock switch is the only thing to use ... back when I built my '67 race car I used lighted knobs (like emergency/defroster(green means GO!) flasher) so I'd know when everything was on; one for the ignition and one for fuel ... worked GREAT.
Also love the knob for the main cutoff ... just SUPER clean, as always.
TxT
you can barely see the green lensed knobs ...π
Reply #322 on:
January 17, 2011, 17:06:18 pm »
By the way, what tool and/or process do you use to roll the edge over on the fuel pump mounting bracket?
Reply #323 on:
January 17, 2011, 19:54:37 pm »
Thanks tom and chris, Tom the process is called hammer forming. You make a pattern and transfer and cut out to blocks of alum the shape of part to be, Can also be made of hardwood ! I usually only use hard wood on soft materials like alum , brass , copper. So now blocks are cut and holes drilled for bolting blocks together, Same holes in this case that pump will mount to. Now add a peice of material that part is going to be made into and scribe around blocks with dividers to get the sides or material to be hammerd down, and go make parts. DO NOT try and hammer complete in one hit, Go around several times turning edge very slow, So material dos not ball up. Again thanks Tom, Or brother of JACK ! That shot glass is working out fine!
Reply #324 on:
February 25, 2011, 22:42:43 pm »
any updates dany
Reply #325 on:
March 11, 2011, 00:45:55 am »
Hi fabs, Here is a little work I have been doing on the running boards. First pictures are of the untouched new running boards that to me dont fit that well !
Reply #326 on:
March 11, 2011, 00:51:17 am »
Well as we can all see, They are a bit short on the ends!!! So first thing is to make a pattern of what there suppose be. So I made alum ends and trimed them to fit, Later I will overlay them on added areas welded to running boards. And trim and turn a new 90 degree flange on all the ends.
Reply #327 on:
March 11, 2011, 00:54:05 am »
Now I will cut the ends off and weld filler strip on the ends. And a sample before and after.
Reply #328 on:
March 11, 2011, 00:56:03 am »
Now for the finished parts fit to car.
Reply #329 on:
March 11, 2011, 01:03:29 am »
Couple close ups of front fenders and of before and after rear corners
Last Edit: March 11, 2011, 01:05:56 am by danny gabbard
10
11
12
13
14
