September 22, 2026, 09:51:40 am
| | |-+  Stuck!!
Author Topic: Stuck!!  (Read 5072 times)
cal-look.net
« on: January 29, 2008, 22:11:52 pm »
Decided to blow the cobwebs out of my IDAs this eve.
but . . .
turned the key, starter clunked then nothing, just lights on the dash dimming!
engine turns just fine with a spanner, but can't shift car in gear at all, tried rocking it to free it up but . . .
seized starter?
let me know what you think, and what to try!
Cheers,
Steve
Paul Knight
« Reply #1 on: January 29, 2008, 22:30:15 pm »
voltage drop? try shorting a screwdriver across the starter terminals (main power to solenoid). if that kicks the starter in, you may want to fit a relay to fed the solenoid (as detailed in the berg book!). basically, you use the original solenoid feed to trigger a relay, which switches power from the main live feed supply. a generic 12-volt switching relay will work fine btw
oh, and if this doesn't work, consider charging the battery (!) or overhauling the starter. greasing the shaft (oo-er!) might help, too!
best of luck
pk
Russell
« Reply #2 on: January 29, 2008, 22:37:18 pm »
slack earth on battery maybe ?
Best Regards
Russell
Black Sheep
less is more
« Reply #3 on: January 29, 2008, 22:43:16 pm »
I agree with paul you may want to whip the starter out and try it out on the bench with a set of jump leads , if the solenoids stuck you may be able to free it up .
 If all else fails I've got a new one on the bench you can have for £50  Smiley
13.03 @ 98mph
cal-look.net
« Reply #4 on: January 29, 2008, 23:19:19 pm »
Cheers fellas, will have a poke around tomorrow eve.
Had a similar issue before setting off to Bug In, but a wire had dropped off - I blame the solid mounts!! - not this time though!
cal-look.net
« Reply #5 on: February 04, 2008, 16:45:59 pm »
OK, as always I feared something far more complicated than it was . . .  Roll Eyes
I am a muppet . . .
After a failed attempt to charge my battery, I replaced it with a fresh Bosch Silver - The IDAs sang and the cobwebs are gone!  Grin
Happy days.
Cheers fellas . . . I'll get my coat!
