October 11, 2026, 14:50:57 pm
| | |-+  New engine
Pages: 1 ... 4 5 [6] 7 8 ... 21 Print
Author Topic: New engine  (Read 796121 times)
Elnef
« Reply #150 on: August 13, 2011, 21:17:58 pm »
Well was out testing today first run 11,3  2nd run 11.4 and bad oilpressure so back to the garage  Sad
RMS Boxer Service
« Reply #151 on: August 13, 2011, 21:41:23 pm »
Saw the car launching from a distance of less 3 meters (resque team) and the car is launching much better than last year.
Straight as a arrow down the strip.  The strip was an unpreped air strip. Let's hope you find the reason for the low oil
pressure and you get ready for some SUPER sticky track action at SCC.
Nice done, both the car and the driving, John
/Rolf
RMS Boxer Service
Trond Dahl
« Reply #152 on: August 14, 2011, 00:12:32 am »
Sounds good! See you next weekend
Race car 9.49/236kmt@SCC 2017
Elnef
« Reply #153 on: August 17, 2011, 06:18:11 am »
Yes see you tomorrow but without the car did not find the pressure Sad
Mags
2,2L 577Hk.
« Reply #154 on: August 17, 2011, 07:18:00 am »
 :othats was bad news John
See you
Magne
Elnef
« Reply #155 on: August 25, 2011, 21:05:42 pm »
Was on the weight today 660kg without wheelibars 50kg less than last year  Cheesy
Now time to take engine apart and find my oil pressure Wink
Elnef
« Reply #156 on: September 24, 2011, 16:37:31 pm »
Did find my oil preasure (bearing was gone) and was ready to das day
but after som warm up I got some problems with my terminatore and season was over I had no more energi left
Today I put it in the back of my garage and took my other car out in the sun
first time in about a year and took a nice ride i the sun stil fun to drive after 21 year in my ownership  Smiley
Elnef
« Reply #157 on: January 14, 2012, 17:07:32 pm »
New home made step header
« Last Edit: January 14, 2012, 17:11:43 pm by Elnef » Logged
SPRasmussen
ET 10,54 - 197,65 at SCC 2011
« Reply #158 on: January 17, 2012, 06:01:43 am »
Feeed  Grin
Søren Rasmussen
Owner of The Ultra Rat
www.TeamAngoraRacing.dk
Elnef
« Reply #159 on: January 28, 2012, 15:42:13 pm »
Tasalaha Søren   Wink
« Reply #160 on: January 28, 2012, 19:20:34 pm »
Ah... You're taking a Jussi  Wink If it doesnt fit, make it fit.
« Reply #161 on: January 29, 2012, 18:21:52 pm »
Does a type4 need wheeliebars  Wink
fredy66
« Reply #162 on: January 30, 2012, 00:46:18 am »
[/quote ]
 Cheesy Cheesy Cheesy Cheesy
arabia slugs
Elnef
« Reply #163 on: January 30, 2012, 06:48:10 am »
The Jussi way hmm if so that must be the old Jussi way the new Jussi way must be something with a lot of alu plate in last minute  Wink Cheesy
I will call it more like the factory way it look a lot more like a car without the "americanway" with big wing and a lot of alu  Wink Cheesy
If the wheeliebar is not needed I will put it in the corner of my garage with all the other leftover parts  Wink
Griebel has made some new bushing for the terminatore I hope they will last a little longer this time  Wink
« Last Edit: January 30, 2012, 06:52:02 am by Elnef » Logged
Elnef
« Reply #164 on: April 03, 2012, 19:32:00 pm »
Got some primer on the "new" rear end
Elnef
« Reply #165 on: April 15, 2012, 16:11:53 pm »
Got my engine started up a few days ago carbs works fine after rebuild thanks Griebel/Spring but my oil pressure is gone again no press under 1000rpm with 100 degrees c oiltemp  Angry
So if anyone need a racecar with or without engine feel free to take contact elnef@gvdnet.dk
John
« Reply #166 on: April 15, 2012, 16:27:14 pm »
John
Wow that really sucks John Sad  Did you find a problem last time that caused it?
Richie
« Reply #167 on: April 15, 2012, 16:34:44 pm »
 Sad  Sad  Sad
Sorry to learn about your problems Elnef. What do you think is the matter with?
BB
RMS Boxer Service
« Reply #168 on: April 15, 2012, 19:17:56 pm »
John
If you need any help or parts I might have, just say when and I'll be there.
Need another case??
/Rolf
« Reply #169 on: April 15, 2012, 20:59:29 pm »
Elnef,
Take a break. Time out. Get perspective and listen to people the advise on what it could be.
Do NOT draw conclusion yet.
It can be the most simplest oil presure control valve, a pump that has wrong play, a old oil hose that has collapsed inside, to a complex and more expensiive reason like a cracked case, but you do not know yet.
Now even with the most complex and nervwrecking reason, it is not enough for you to give up right now. Not likely anyway.
Just make sure you take the "time out and get perspective" on the situation before you decide on next step.
Elnef
« Reply #170 on: April 16, 2012, 15:41:59 pm »
Thanks for your comments  Wink
My oil problem started last year when my car was ready in primer
I was ready to install my engine but it had some leak behind the flywheel so I wanted to shift seal but there was something wrong with the last bearing so I took it appart yes bearing was gone and crank need grinding we took a check on the block its was okay and a local machine shop did grind my crank but it was under measurement so back to the shop they was sorry and did it again this time it was okay but coarse about 3 time more than a stock one but they say just put it together it will work but after 2 run at the strip no oil preasure then I change pump valve and so on but nothing help so again took it appart this time the bearing in the middle was gone and back to the shop they say the crank was straight and fine but I wanted it polish so they polished it and I started it up last year and got problems with my carburators they work now but no oil pressure when hot
Maybe its my block or crank or both hmm
bang
« Reply #171 on: April 16, 2012, 17:08:23 pm »
i will donate a type 4 case to you. you can come and pick it up next weekend
or i can have it in aalborg by thursday
RMS Boxer Service
« Reply #172 on: April 16, 2012, 20:53:01 pm »
Hi John,
I will donate lifter bushings, Time Serts for head studs and machining for larger cylinders,
32 mm oil pump, LAT oil of your choice. Peter and I will help you for sure !!
Please don't hesitate asking for any further help for parts and maching.
/Rolf
RMS Boxer Service
« Reply #173 on: April 16, 2012, 21:46:22 pm »
Here is what you need -- screw that TIV stuff
http://www.cal-look.com/forum/online-swap-meet/8-second-promod-motor/
« Reply #174 on: April 17, 2012, 13:14:57 pm »
Bang and Rolf, That gives me tears. Nice!
Elnef
« Reply #175 on: April 17, 2012, 18:43:26 pm »
Hi John,
/Rolf
RMS Boxer Service
Thanks Rolf and Bang very very nice of you I will make you a call
John
Elnef
« Reply #176 on: April 18, 2012, 05:20:04 am »
I like your idea with a new/another engine but turbo hmm the next you will suggest is I have to put it in a fiat  Wink Cheesy
Nice price on turbo engine anyway  Wink
« Reply #177 on: April 18, 2012, 06:15:16 am »
Sounds like you need another case if the crank is ok. But NO 32 mm pump . it will suck you the oil out of the sump. i hope you have a scat 1,5ltr sump !?
Do not stop working on it after all that work
Good luck !!!!!!! Udo
Elnef
« Reply #178 on: April 18, 2012, 11:04:14 am »
Hi Udo
Thanks for your advise
I have no sump on now
Do you always use sump on type4 engine or only when 32mm pump is used ?
John
« Reply #179 on: April 18, 2012, 19:40:55 pm »
Yeah, it sucks. John and I had a long chat the other day. And the symptoms are very much alike what I experienced on an Ally type 1 case about 3 years ago. At that time I did not find a crack in the case, but did replace it in the end and solved the pressure problem.
I think this has been the problem from day one with this case. We/I just did´nt  adress it because it was a type 4 and no one that we knew of have ever had this problem on a type 4.
