October 11, 2026, 14:50:56 pm
| | |-+  New engine
Pages: 1 ... 6 7 [8] 9 10 ... 21 Print
Author Topic: New engine  (Read 796118 times)
« Reply #210 on: July 01, 2012, 19:20:18 pm »
Good luck John,nearly there Smiley
cheers richie
Elnef
« Reply #211 on: July 02, 2012, 21:23:41 pm »
Thanks Richie and yes youre are right its close now  Wink
« Reply #212 on: July 02, 2012, 21:28:11 pm »
Did you have the oil drainback from the heads before?
cheers richie
Elnef
« Reply #213 on: July 02, 2012, 21:43:23 pm »
No its new hope it will work
The valve cover breath hole and the one in my block is also closed (actually I never drill it in the new block) and now it breath from a 1" beside the alternator
« Last Edit: July 02, 2012, 21:48:06 pm by Elnef » Logged
« Reply #214 on: July 03, 2012, 05:33:38 am »
That is a good idea . specialy why the pauter heads have a big rocker room where the oil can stay in
« Reply #215 on: July 03, 2012, 09:06:34 am »
I belive you need more than just 25 mm, why not open the hole up a few mm's... It does wonders for the area.
Looking good Elnef, any chanse of seeing you in the Norwegian woods this fall?
Elnef
« Reply #216 on: July 03, 2012, 11:19:56 am »
I think 25mm is okay but I will find out in a few days or so
About scc right now I dont think I will be there this year
there is a race at the local drag strip same weekend and its perfect for test and tune (my car is still new build only ran 2x402m in it in this setup)
« Reply #217 on: July 04, 2012, 05:56:21 am »
If you have that 25 mm and one 12mm on each valve cover it is ok. Take the time and make some fittings on the covers
Elnef
« Reply #218 on: July 04, 2012, 11:05:04 am »
Hi Udo
Why do you want them in the valve cover ?
I renember Mufler Mikes test where one of them was full of oil
« Reply #219 on: July 05, 2012, 07:59:13 am »
I agree with you John, keep the venting going on in the case... no need to create a "wind" up thru the pushrod tubes.Two 1" fittings in the case roof of the only Pauter case I have seen IRL... makes sense.
Sad to hear your not coming to SCC as we would have loved to have you there.
« Reply #220 on: July 06, 2012, 06:00:41 am »
Hi Udo
For me it makes sense to get the pressure out of the valve covers. I had this also before i have the return lines and never oil comming out
Elnef
« Reply #221 on: July 07, 2012, 19:46:05 pm »
Thanks Udo for youre advise
Engine is running so far no problems  Grin
Erlend / bug66
Global Moderator
SCC Event
« Reply #222 on: July 08, 2012, 01:35:34 am »
Looks narrow! And thats nice  Grin
Really think you should head to Norway and Gardermoen in August  Wink
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Elnef
« Reply #223 on: July 19, 2012, 20:31:02 pm »
Ready for dyno next wednesday  Wink
« Reply #224 on: July 20, 2012, 06:58:55 am »
Good luck :-)
Richyrich
« Reply #225 on: July 21, 2012, 00:33:11 am »
Im likeing this Wink
magic
« Reply #226 on: July 22, 2012, 21:59:04 pm »
Hi John.
 Fingers crossed for Wednesday! please, drop a video in here, so we can see AND hear how it went! Smiley ( maybe Wednesday?!?) Grin Grin Grin
regards. Mads
pladegaarden
« Reply #227 on: July 24, 2012, 21:36:35 pm »
good luck with tomorrow john;-)
Henrik Hagen
« Reply #228 on: July 25, 2012, 22:14:56 pm »
Any news ?
Elnef
« Reply #229 on: July 26, 2012, 05:46:10 am »
Yes a little news was there all day yesterday and will be there again today
Engine sounds great still got preasure  Smiley respond wery well on the throttle but only about 270 hp around 6000 and something happen maybe tyre spin or ? we did try serval exhaust and so on
today we will try with another set of rim/tyre
Thanks to Rasmus for help all day long
« Reply #230 on: July 26, 2012, 07:15:40 am »
Sounds good- try slick tires and strap it right to the dyno. if this does not work i spray clue on the tires  Smiley
<a href="http://www.youtube.com/v/rVf2fPQLfmk" target="_blank">http://www.youtube.com/v/rVf2fPQLfmk</a>
« Last Edit: July 26, 2012, 07:18:15 am by Udo » Logged
Elnef
« Reply #231 on: July 26, 2012, 07:55:37 am »
Thanks but we actually did it that way and same at all my dyno times before with no problems but there was some rubber parts on the roof and you could see on the slicks surface at they were spinning so my dyno man want to try normal tyre and more strap down and more glue he say he had best results/grib with normal tyre
well we get the result later today  Wink
Elnef
« Reply #232 on: July 27, 2012, 05:55:44 am »
Well after another day at dyno my new tyre/rims make the dyno catch my power so now no spin  Smiley
But I still got problems ignition or fuel or both engine pull nice and power full up to a little over 6000 but then the curve look strange
we change fuel pump and coil but same and the pc at the dyno says everything okay with ignition and fuel but in real life there is something wrong
We now think there is not power enough in my old bosh ignition to make the fuel burn correct when we pull over 6000 with the more comp I got now 12,8-1 compare to before 12,1-1
now I will go on holiday the next 3 weeks an then take up the battle again  Wink Wink
John
« Last Edit: July 27, 2012, 11:14:38 am by Elnef » Logged
Elnef
« Reply #233 on: August 11, 2012, 07:29:21 am »
After a nice 3100km drive and camping around Denmark,Sweden and Norway with Pernille and our dog it was time to go in my garage again  Smiley
I have now put on a complete msd ignition and now waiting for a new dyno time  Smiley
« Reply #234 on: August 11, 2012, 09:12:24 am »
Good! Just in time for SCC.
Elnef
« Reply #235 on: August 14, 2012, 07:16:20 am »
Got a new dyno time tomorrow so lets see what happen  Wink
Trond Dahl
« Reply #236 on: August 14, 2012, 08:13:11 am »
go go go :-) Still many days left
Race car 9.49/236kmt@SCC 2017
Elnef
« Reply #237 on: August 15, 2012, 21:58:08 pm »
Well was at the dyno today and it worked wery well 308hp at 7500 and only 10 less at 8500 with belt on  Wink
Then I wanted to try a bigger muffler and it looks like it was better but there will go some time before we know it for sure if ever for we got a big bang and it was over got a big hole in my block
Have now taken it appart and my crank is in two parts with a lot of other broken parts
Elnef
« Reply #238 on: August 15, 2012, 22:05:09 pm »
Got this photo more will come tomorrow  Wink
Elnef
« Reply #239 on: August 15, 2012, 22:16:41 pm »
 Wink
