October 28, 2026, 15:13:03 pm
352330 Posts in 28962 Topics by 6929 Members
Latest Member: Hanibal1
| | |-+  New engine
Pages: 1 ... 19 20 [21] Print
Author Topic: New engine  (Read 812239 times)
karl h
« Reply #600 on: February 02, 2026, 21:46:16 pm »
i saw a pair on mexxs workbench Grin
Elnef
« Reply #601 on: February 03, 2026, 12:58:27 pm »
Yes my set has no 1 but there is more sets out there Paul Bate for examble
karl h
« Reply #602 on: February 03, 2026, 18:27:17 pm »
those on mexx workbenche are for paul
Elnef
« Reply #603 on: March 29, 2026, 08:36:44 am »
Some testing
bedjo78
« Reply #604 on: March 30, 2026, 06:14:16 am »
Hi Elnef.
would you share the valve size with those awsome heads
mikko k
« Reply #605 on: March 30, 2026, 06:45:35 am »
« Last Edit: March 30, 2026, 06:48:38 am by mikko k » Logged
Elnef
« Reply #606 on: March 30, 2026, 16:41:54 pm »
Hi Elnef.
54 40
bedjo78
« Reply #607 on: March 30, 2026, 22:54:16 pm »
That is very good  spread valve guide. I have old JPM but max only 48 38 and the valve almost touching each other
mikko k
« Reply #608 on: March 31, 2026, 14:23:29 pm »
Evo350 has 54/40 valves and 4” bore. All other jpm heads have 48/38. But you can fit about 50/40 in those.
bedjo78
« Reply #609 on: April 01, 2026, 06:13:08 am »
yes may be 50/48 doable. but I think, Is it worth to change Ti valve for 2 mm bigger?
anyway Elnef engine look very promising
mikko k
« Reply #610 on: April 01, 2026, 14:08:35 pm »
48/38mm valves at jpm230/250 heads are manley ss, meaning stainless steel and retainers are titanium when new. What anything is worth at racing, you have to deside that yourself. Sometime 2mm is needed.. I had… 304hp/320Nm from 230 heads at NA engine…
bedjo78
« Reply #611 on: April 01, 2026, 22:48:19 pm »
Yes Miko. original valve on MS230 are SS. I changed to Ti from CB perf complete with psi spring and Checy Ti retainers
ibg
« Reply #612 on: April 02, 2026, 09:28:25 am »
Mikko, what cam/compression/engine size did you use to get 304hp/320Nm out of those heads?
many thanks in advance.
mikko k
« Reply #613 on: April 02, 2026, 17:49:29 pm »
Ok.
mikko k
« Reply #614 on: April 02, 2026, 18:15:28 pm »
4”x88mm (2850cc), 14:1 comp ratio, special camshaft, originally jpm but modified later, 50/40 valves,17mm lift at valve, heads modified; welded, reshaped, etc. Efi, ms109 fuel, Jenvey 60mm throttle bodys, 3-step stainless steel exhaust that I made myself. So, nothing special. Unfortunately, driver isn’t good (me), gearing not the best possible and car were a little pit heavy, so best et were 10,7s/202,5kmh. Today engine is base for turbo engine.
Sorry Elnef messing your thread.
Elnef
« Reply #615 on: April 03, 2026, 06:13:34 am »
No problem
 Yes there is more room between valve guide on evo350 you need that with this size valves
You will also need a new rocker shaft the stud outside left and right is locatet different and new valvecovers because the head is a little bigger
bedjo78
« Reply #616 on: April 03, 2026, 23:13:10 pm »
very cool engine.
Sorry Elnef
ibg
« Reply #617 on: April 06, 2026, 00:07:16 am »
Thanks Mikko for the engine details  Grin
Elnef
« Reply #618 on: May 23, 2026, 06:52:08 am »
More testing
ibg
« Reply #619 on: May 26, 2026, 09:40:32 am »
OMG  Smiley
What a beautiful set of carbies. What are the spacers between the carbies and manifold made out of?
Elnef
« Reply #620 on: May 26, 2026, 16:42:23 pm »
OMG  Smiley
They are made in peek
Elnef
« Reply #621 on: June 13, 2026, 06:11:54 am »
First test fitting in car
bedjo78
« Reply #622 on: July 02, 2026, 13:01:15 pm »
looks very cool.
is it new carburetors ?
Elnef
« Reply #623 on: July 03, 2026, 08:21:22 am »
looks very cool.
Yes they are new
