May 28, 2026, 22:13:25 pm
mvptkfjb
New engine
20
21
Topic: New engine (Read 698765 times)
karl h
Re: New engine
Reply #600 on:
February 02, 2026, 21:46:16 pm »
i saw a pair on mexxs workbench
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
Elnef
Re: New engine
Reply #601 on:
February 03, 2026, 12:58:27 pm »
Yes my set has no 1 but there is more sets out there Paul Bate for examble
karl h
Re: New engine
Reply #602 on:
February 03, 2026, 18:27:17 pm »
those on mexx workbenche are for paul
61 panel
68 ghia vert
63 sunroof
86 caravelle
04 new beetle vert
Elnef
Re: New engine
Reply #603 on:
March 29, 2026, 08:36:44 am »
Some testing
bedjo78
Re: New engine
Reply #604 on:
March 30, 2026, 06:14:16 am »
Hi Elnef.
would you share the valve size with those awsome heads
mikko k
Re: New engine
Reply #605 on:
March 30, 2026, 06:45:35 am »
Last Edit: March 30, 2026, 06:48:38 am by mikko k
Elnef
Re: New engine
Reply #606 on:
March 30, 2026, 16:41:54 pm »
Quote from: bedjo78 on March 30, 2026, 06:14:16 am
Hi Elnef.
54 40
bedjo78
Re: New engine
Reply #607 on:
March 30, 2026, 22:54:16 pm »
That is very good spread valve guide. I have old JPM but max only 48 38 and the valve almost touching each other
mikko k
Re: New engine
Reply #608 on:
March 31, 2026, 14:23:29 pm »
Evo350 has 54/40 valves and 4” bore. All other jpm heads have 48/38. But you can fit about 50/40 in those.
bedjo78
Re: New engine
Reply #609 on:
April 01, 2026, 06:13:08 am »
Quote from: mikko k on March 31, 2026, 14:23:29 pm
yes may be 50/48 doable. but I think, Is it worth to change Ti valve for 2 mm bigger?
anyway Elnef engine look very promising
mikko k
Re: New engine
Reply #610 on:
April 01, 2026, 14:08:35 pm »
Quote from: bedjo78 on April 01, 2026, 06:13:08 am
48/38mm valves at jpm230/250 heads are manley ss, meaning stainless steel and retainers are titanium when new. What anything is worth at racing, you have to deside that yourself. Sometime 2mm is needed.. I had… 304hp/320Nm from 230 heads at NA engine…
bedjo78
Re: New engine
Reply #611 on:
April 01, 2026, 22:48:19 pm »
Yes Miko. original valve on MS230 are SS. I changed to Ti from CB perf complete with psi spring and Checy Ti retainers
ibg
Re: New engine
Reply #612 on:
April 02, 2026, 09:28:25 am »
Mikko, what cam/compression/engine size did you use to get 304hp/320Nm out of those heads?
many thanks in advance.
mikko k
Re: New engine
Reply #613 on:
April 02, 2026, 17:49:29 pm »
Quote from: bedjo78 on April 01, 2026, 22:48:19 pm
Ok.
mikko k
Re: New engine
Reply #614 on:
April 02, 2026, 18:15:28 pm »
Quote from: ibg on April 02, 2026, 09:28:25 am
4”x88mm (2850cc), 14:1 comp ratio, special camshaft, originally jpm but modified later, 50/40 valves,17mm lift at valve, heads modified; welded, reshaped, etc. Efi, ms109 fuel, Jenvey 60mm throttle bodys, 3-step stainless steel exhaust that I made myself. So, nothing special. Unfortunately, driver isn’t good (me), gearing not the best possible and car were a little pit heavy, so best et were 10,7s/202,5kmh. Today engine is base for turbo engine.
Sorry Elnef messing your thread.
Elnef
Re: New engine
Reply #615 on:
April 03, 2026, 06:13:34 am »
Quote from: mikko k on April 02, 2026, 18:15:28 pm
No problem
Yes there is more room between valve guide on evo350 you need that with this size valves
You will also need a new rocker shaft the stud outside left and right is locatet different and new valvecovers because the head is a little bigger
bedjo78
Re: New engine
Reply #616 on:
April 03, 2026, 23:13:10 pm »
very cool engine.
Sorry Elnef
ibg
Re: New engine
Reply #617 on:
April 06, 2026, 00:07:16 am »
Thanks Mikko for the engine details
Elnef
Re: New engine
Reply #618 on:
May 23, 2026, 06:52:08 am »
More testing
ibg
Re: New engine
Reply #619 on:
May 26, 2026, 09:40:32 am »
OMG
What a beautiful set of carbies. What are the spacers between the carbies and manifold made out of?
Elnef
Re: New engine
Reply #620 on:
May 26, 2026, 16:42:23 pm »
Quote from: ibg on May 26, 2026, 09:40:32 am
OMG
They are made in peek
20
21
