September 22, 2026, 23:17:56 pm
1914 longblock £1350 :)
Topic: 1914 longblock £1350 :) (Read 2880 times)
71CALRIPPER
January 30, 2008, 13:17:33 pm »
Recon AS41 Case- Drilled and Tapped for Full Flow
Reground and Balanced 69 Crank 8 Dowel
200mm Lightened Flywheel with HD nut
Rebuilt and balanced rods
New c35 Scat cam with scat followers
New CB Performances Full Flow Pump
New Mahle 94mm Barrells and Pistons
New Chromoly Push Rods
New Bolt up Rockers
New Burg Lash Caps
New Big valve heads 39mm inlet 35mm exhaust s/s valves
with Scat Hd springs and retainers.
Needs a cam Burn and running in and its good to go
Last Edit: January 30, 2008, 13:21:15 pm by 54caldub
71CALRIPPER
Re: 1914 longblock £1350 :)
January 30, 2008, 20:55:18 pm »
Nobody want a cheap motor
