November 03, 2026, 06:32:03 am
| | |-+  Sleeving lifter bores
Author Topic: Sleeving lifter bores  (Read 6911 times)
airstuff
« on: February 02, 2008, 16:14:50 pm »
Hey guys,
I don't understand why is it needed and when is it needed to sleeve lifter bores on a new VW crankcase?
« Reply #1 on: February 02, 2008, 16:25:16 pm »
I guess the sleeve would wear and not the case - meaning these sleeves could be replaced if any wear occurs - Saving the case Smiley
just a guess mind you  Smiley
Steve D.
« Reply #2 on: February 02, 2008, 17:00:27 pm »
Mag is soft and is a pretty lousy material for, well, anything- it is light though and that is cool.
Aluminum is hard
Silicon Bronze is hard
Both make stronger/better lifter bores.
(here's my pitch) Brother's VW in Ontario, CA did my last case in Silicon Bronze for less than a hundred bux.
Über Alles
10.77 avg. on pump fuel.
238I
airstuff
« Reply #3 on: February 02, 2008, 17:11:38 pm »
does anybody have a picture of it when it is done?
so I stay with normal aftermarket lifters,or do I have to use any special lifters?
« Reply #4 on: February 02, 2008, 17:33:25 pm »
"Aluminum is hard
I thought that might also be the case - pardon the pun  Wink Smiley
« Reply #5 on: February 02, 2008, 18:49:35 pm »
Another reason is tighter tolerances need for higher RPM's.
