November 03, 2026, 21:52:01 pm
| | |-+  Berg Traction Bar
Author Topic: Berg Traction Bar  (Read 7120 times)
« on: February 04, 2008, 19:03:18 pm »
Okay, while I was under the car last night putting in the little sump I noticed my Berg traction bar had slipped forward under the engine case. I followed the directions and had it pretty tight. Any suggestions for keeping it from sliding forward? I am thinking a little bracket to bolt to the case. Though that would probably defeat the rubber vibration dampener.
Fritter
« Reply #1 on: February 05, 2008, 01:13:10 am »
Louis, make sure you have the proper preload on the bar, then it shouldn't slip.
Mike F.
'64 Indigo Blue sunroof Bug
lawrence
« Reply #2 on: February 05, 2008, 02:13:57 am »
I had that same problem with my traction bar. The asymetrical nub on the bottom of the case is what causes the problem. I cut the nub off of the case and made a small bracket out of flat stock and square tube. Simple and effective.
"Happiness is a Hot VW!"
stealth67vw
« Reply #3 on: February 05, 2008, 03:43:04 am »
I made a bracket for mine along time ago and bottomed out the bar on a speed bump and broke my case. I'd rather have it able to slip off in that kinda situation.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
« Reply #4 on: February 05, 2008, 03:55:00 am »
Good point.
I moved it back and tightened up the preload. I plan to take it on a long drive tomorrow to test out the steering. I will see if it stays in place this time.
John Rayburn
« Reply #5 on: February 05, 2008, 04:04:08 am »
A deep sump will keep it from going anywhere.
I also park at Nick's.
« Reply #6 on: February 05, 2008, 18:06:34 pm »
Worked for me as well.
I just welded a tab on the bar so i can "loosely" secure it with a nyloc nut to the case.
