September 26, 2026, 07:40:13 am
2276 Typ1 engine block, with ARPM , 82er GB Crank and 5,5" NEW Pauter Rods..
Topic: 2276 Typ1 engine block, with ARPM , 82er GB Crank and 5,5" NEW Pauter Rods.. (Read 10213 times)
Lammynator
February 07, 2008, 09:56:45 am »
ATTENTION Drag Racers!! For sale is the originally 2276ccm Typ1 engine ( just engine block ) with nearly 210HP and good for 12,0 sec over the 1/4 mile ( depends on gear box, transmission, tires and weight of the car ) from the "Stage Fright" "Wild Child" Drag Racer built in the early 80s in the USA!!
SELLING ALL PARTS SEPERATLY!!
The motor got an NEW VW AS41 crankcase with tie rods, geared up for "full flow" oil cooling system and ready for 94er Pistons and 82er crank ( 800EURO)!! A spezial 82er wadgemated Gene Berg crankshaft ist taken, also were used brand new 5,5" Pauter rods for 50mm Mitsubishi rod bearings crankpins..the crankshaft is hardened, grounded und polished!! (crank shaft+Pauter rods+ lighted flywheel and Kenedy clutch 1600EURO)The 94mm pistons and cylinders by MAHLE are forged, used but in very good condition with valve seat pockets!! The camshaft should be a FK 87 Engle..because the motor is not putting together yet, another camshaft could be used if wanted!! Of course, all bearings would be new!! The cylinder heads are old school ARPM cylinderheads with 44er admission valve and 37,5 mm exhaust valves with Chevy double valve springs and a compression over 11,5 : 1, for 48er IDAs mashined manifolds are inklusive(800Euro)!! Rockers are made by Scat with ratio of 1,40:1 !!The Motor will be assemled by UDO BECKER, known as a fast, good and extrem excellent Typ1 Motor Tuner!! For 4000Euros you have to complete the engine by yourself!! I would like a 2000ccm Typ1 motor to take in payment but we got to talk about the price, depends on the condition of the engine..just ask for questions !! Shipping the engine all over the world is possible :-)
PRICE is 4500Euro
!!! Please ask for MORE pics or information!! Best regards Lammy
Last Edit: March 05, 2008, 15:45:29 pm by Lammynator
funnycarmike
Re: 2276 Typ1 engine block, with ARPM , 82er GB Crank and 5,5" NEW Pauter Rods..
December 11, 2010, 03:05:02 am »
Quote from: Lammynator on February 07, 2008, 09:56:45 am
PRICE is 4500Euro
I realize this is a few years old but I had to chime in . . . . . The ORIGINAL engine in "Stage Fright" was a 2180 cc and later changed to a 2110cc. This was from 1984 untill it was sold in 1988. During that time I ran a "roller" crankshaft which I bought from a guy named Pete Edmonds. I broke a rod in '87 at Antelope Valley Raceway (Palmdale) and had to have Roger Crawford repair it. (rods were pressed on like a motorcycle crank). The heads might be the originals because I did have Ray and Mitch Evenson from R&R Machine in Napa do the work on them and the valve covers.
funnycarmike
December 11, 2010, 03:08:56 am »
OOPS!!! I should of hit "reply" instead of Quote . . . . Sorry!
December 11, 2010, 19:22:42 pm »
All the new parts like crank and rods where replaced here in germany . The heads are still the old ones .
But now the engine ended up on the street and i think it will die there. I assembled everything for the last owner
www.Udobeckertuning.de
Carsten
December 13, 2010, 08:31:08 am »
The one you put it together for sold it again to someone else.....That guy again sold the engine... Maybe again to the guy you put the engine together for . Thats what i have in mind ...
Carsten
1969 IRS bug
GetBackOnTrack
December 14, 2010, 00:01:32 am »
Will you sell the crank seperately? And in case yes, what is the price?
Check: gbot.dk
December 14, 2010, 20:12:27 pm »
Those parts are no longer avaliable. the engine was assembled and sold . Nobody know where it is now
Carsten
December 15, 2010, 10:08:46 am »
Quote from: Udo on December 14, 2010, 20:12:27 pm
"The one you put it together for sold it again to someone else.....That guy again sold the engine... Maybe again to the guy you put the engine together for . Thats what i have in mind ...
Carsten"
Engine was sold from the guy you put it together for to someone ( i know him ) from Austria. He then sold it back to that guy he had it from . So when i am right , it should be the one you put the engine tohether for , who has it now !
Greets , Carsten
1969 IRS bug
Stephan32
December 15, 2010, 11:59:33 am »
So,
Knowing it is not the original engine spec price is a bit high for a semi-used not complete drag racing engine...
How much for the complete heads, if still available??
Stephan
Carsten
December 15, 2010, 12:41:54 pm »
Quote from: Stephan32 on December 15, 2010, 11:59:33 am
So,
Stephan
SOLD!!!!!!
Read above.....
Carsten
1969 IRS bug
