September 23, 2026, 06:05:02 am
Disk Brakes
Topic: Disk Brakes (Read 24597 times)
streetvw
Re: Disk Brakes
Reply #30 on:
February 14, 2008, 17:18:45 pm »
I'll bet he had a pointed head the next morning after drinkin that stuff! it ain't called DUVAL for nothin you know
Last Edit: February 14, 2008, 17:21:46 pm by streetvw
Re: Disk Brakes
Reply #31 on:
February 14, 2008, 17:32:36 pm »
a
Last Edit: May 26, 2010, 16:08:00 pm by Peter
Ivan
Re: Disk Brakes
Reply #32 on:
February 14, 2008, 18:47:49 pm »
Quote from: ruff on February 14, 2008, 17:32:36 pm
only one problem i had with my csp disks..
i wanted to exchange the studs in them ,
and by unscrewing the studs, the threads came out of the hubs..
so i had to put helicoils in them...
but it works fine...
I'm sure it states in the instructions not to mess with the studs in any way...
Re: Disk Brakes
Reply #33 on:
February 14, 2008, 19:11:45 pm »
Quote from: Ivan on February 14, 2008, 18:47:49 pm
Gunter
Re: Disk Brakes
Reply #34 on:
February 15, 2008, 10:49:36 am »
Mmmmm...BEER! Your killing me, Gunter!!
Looks like Nao's enjoying himself, too...
[/quote]
you bet, BugIn it is, only slight problem is your country will not allow me to bring in a sixpack of Duval
Re: Disk Brakes
Reply #35 on:
February 15, 2008, 13:01:01 pm »
yeah,
but to bolt on my empi repros i needed M12 studs opposed to the M 14 s that were installed..
darkmatter
Re: Disk Brakes
Reply #36 on:
February 16, 2008, 10:39:18 am »
Running CB 5-205 discs front and back for the last season, didnīt think they were so bad, the only thing you need to be wary of is the fitment according to what wheels youīll be running - it says specifically when ordering - if you are running BRMs because you need longer studs, but I found that pretty much everything other than steels/356 or centrelines/ercos would need longer studs to run responsibly - and then you canīt run the bubble type centrelines or ercos (3.5") without spacers because the caliper is too chunky.. Iīm considering at least to swap out the calipers or maybe run CSP instead..
canīt beat the exchange rate to europe though....
my tuppence worth...
qubek
Re: Disk Brakes
Reply #37 on:
February 26, 2008, 14:35:39 pm »
Quote from: monkiboy on February 13, 2008, 23:38:39 pm
CB Kits are cheap for a reason dude - THEY ARE CRAP
for a start they use FIAT calipers
Do you know which Fiat?
Re: Disk Brakes
Reply #38 on:
February 26, 2008, 14:41:42 pm »
I bought a complete CB front end - 2" narrowed beam, dropped spindles and disc brakes, all second hand but unused and still in the box, but I haven't used it yet. I thought the quality was reasonable although not as good as the CSP set up on a couple of friends cars. The only thing that sucks is the use of different studs for the Flat Four BRMs I've got for the car - my discs are for Erco's I think!
jaakko
55 old school oval
Re: Disk Brakes
Reply #39 on:
February 26, 2008, 15:51:26 pm »
Csp disk brake is good!
easy to install, just bolt on.
very good quanlity, that brakes kit gomes everything what you need it..bolts, nuts, brakeplades..ect..
minus ---price.
http://ovalkafer.blogspot.com/
Re: Disk Brakes
Reply #40 on:
February 26, 2008, 20:37:42 pm »
Quote from: qubek on February 26, 2008, 14:35:39 pm
I have no idea which fiat but which ever it is - ITS CRAP!!!!!! I have an idea that they are in fact REARS
you see they come with a "Banjo" type bolt fitting for the flexy hose which by its very nature trys to undo its self ever time you turn the steering wheel -
NOT A GOOD IDEA
!!!!!!!! Also the bolts that come with the banjo fitting are too long for the calipers and "Bottom out" or worse still SNAP
One last thing they don't even come with backing plates.
Me and Gav (G77) are in the process of fitting a brand new set of CSP's to his 63 - and from what hes told me so far they are pretty much PERFECT - everything
FITS
and
WORKS
Last Edit: February 26, 2008, 23:10:02 pm by monkiboy
christophe
Re: Disk Brakes
Reply #41 on:
February 26, 2008, 22:33:54 pm »
And what about the kits sold by SoCal Imports:
http://www.socalautoparts.com/
Any return on those products?
thehanz DVK
Re: Disk Brakes
Reply #42 on:
February 27, 2008, 12:24:19 pm »
will bubble centerline's fitt to a CSP wide five disc set ? at this moment i have a cb set and on those it will not fit with out a spacer, will it fit directly to the CSP set ?
