October 14, 2026, 05:31:22 am
WeldMating Cranks...
Topic: WeldMating Cranks... (Read 8148 times)
Frank LUX
Back...Soon...hopefully!!!
February 12, 2008, 12:49:27 pm »
Wedgemating is well known, but what about Weldmating Cranks???
Any Infos welcome...
Frank
Re: WeldMating Cranks...
February 12, 2008, 12:53:58 pm »
May be someone wrote wedgemating wrong ?
www.Udobeckertuning.de
Frank LUX
February 12, 2008, 12:58:12 pm »
Quote from: Udo on February 12, 2008, 12:53:58 pm
No, Sorry Udo...
Frank
Greg G
February 12, 2008, 16:26:40 pm »
Weldmating crank/flywheels is when leave the end of the crank flyhweel fit straight, weld up the flywheel crank fit area and machine it so it has ~.0025-0035 press fit on the crank. I usually heat the flywheel a little and draw it on with the gland nut. I normally set the end play with another flywheel that has the same mounting area depth so I don't have to install and remove the flywheel over and over again. The flywheel can be used on different cranks that that have a similar flywheel fit dimesion.
Greg G
flatfire
February 13, 2008, 00:33:36 am »
I'm in the middle of weldmating. I have had the bore TIG welded. Then I'm trying to measure the crank dimension in its built up state. I cant get the mic in.
its a CB 78mm crank. I can measure it with calipers but don't trust the dimension given.
Thanks Greg for the information given on the cal forum.
Greg G
February 13, 2008, 16:22:32 pm »
Most cranks measure ~2.105 on the flywheel fit. I have one that was reground that measures 2.104. Can you measure some thing else with the calipers that you could compare with a mic so you could get the feel of what is right, then measure the crank a couple times and see what size you are most consistant getting?
Greg
flatfire
February 13, 2008, 22:31:39 pm »
Thanks Greg great news thats the size I'm getting consistantly.
