October 12, 2026, 18:26:53 pm
Off Topic
Car Rotisserie
Topic: Car Rotisserie (Read 14040 times)
Car Rotisserie
February 12, 2008, 15:00:00 pm »
Anyone ever built or know of someone who has built a rotisserie for a VW? Pics, plans whatever? Just something I have been thinking about for when I start the bodywork on the '67. I was thinking you could make something from two cheap V8 style engine stands. Fab up some mounts that would connect to the front and rear body mounts.
team97
3M TA3
Re: Car Rotisserie
February 12, 2008, 18:58:39 pm »
Danny, Danny where are you? Here's a topic that you actualy help with.
Der Kleiner Panzers III
D.K.K.
Re: Car Rotisserie
February 12, 2008, 19:07:47 pm »
Looking around on the samba I found two I like.
Body:
Pan:
With a little thought, you should be able to make one that can do both. Probably make it so you can disassemble it and store it out of the way.
Last Edit: February 12, 2008, 19:15:14 pm by louisb
John Rayburn
Re: Car Rotisserie
February 13, 2008, 06:01:51 am »
Jim Gordon's Restorations in Paramount , Ca had one, in fact those pictures look just like his shop. That might be his.
I also park at Nick's.
Re: Car Rotisserie
February 13, 2008, 15:20:57 pm »
I would think positioning the posts to the outside of the car would be a better idea... that way you could rotate the body 360 degrees without the posts getting in the way...
Re: Car Rotisserie
February 13, 2008, 15:35:28 pm »
Quote from: Zach Gomulka on February 13, 2008, 15:20:57 pm
It probably would be, but it would also be more complicated and costly. Plus, unless your eight feet tall, being able to turn the car up side down doesn't seem to have any advantages.
Re: Car Rotisserie
February 13, 2008, 15:38:46 pm »
I built mine to spin the body 360° but I rarely tilt it more than 90 -100° to weld on it, so if you prefer it to be low it can be done lower than mine. When I don't use it I unbolt the cross member so it takes up very little space. For the time being its holding a bay window
Last Edit: February 13, 2008, 15:41:12 pm by JHU
Re: Car Rotisserie
February 13, 2008, 15:41:43 pm »
If you get a sec, please snap a pic or two and post them.
Re: Car Rotisserie
February 13, 2008, 15:50:08 pm »
"click"
Re: Car Rotisserie
February 13, 2008, 18:11:05 pm »
I like the way you've moved the pivot point above the mounting point. Seems like it would be easier to control the rotation that way.
Re: Car Rotisserie
February 14, 2008, 10:31:04 am »
Quote from: DKK Rick on February 13, 2008, 18:11:05 pm
You are right. I wanted to get close to the center of gravity of the body. In combination with allowing enough room to rotate it 360° this is what I came up with. I actually moved the pivot point to high, so its bottom heavy, but I guess that is better than top heavy.
Re: Car Rotisserie
February 15, 2008, 04:07:38 am »
I have two type's , One that pivet's like engine stand's and the other one I have two large hoop's rolled 6-7 foot dia. I bolt them on each end of what I'm working on. and when I'm done, I can lean up against wall or on the roof of my office. just another Idea.
Re: Car Rotisserie
February 16, 2008, 00:56:56 am »
Who's orange ghia, pretty wild,very tasteful kustom
Re: Car Rotisserie
February 16, 2008, 01:47:44 am »
Quote from: danny gabbard on February 16, 2008, 00:56:56 am
Not sure, I just ran across the pics on the samba. I agree, it looks nice.
Re: Car Rotisserie
February 16, 2008, 03:40:22 am »
anybody seen the george forman car rotisserie
Re: Car Rotisserie
February 16, 2008, 06:10:16 am »
Quote from: danny gabbard on February 16, 2008, 03:40:22 am
I thought it was the ronco car rotisserie??
Just set it... and forget it!
Re: Car Rotisserie
February 16, 2008, 06:26:07 am »
It was between the two
