August 12, 2026, 12:15:54 pm
| | |-+  why are this early cars so fast?
Author Topic: why are this early cars so fast?  (Read 22087 times)
dirk zeyen
« on: February 14, 2008, 22:38:09 pm »
hello,
i read the "cal-look bibel" every 2 month again and again. one thing i can't understand is the time on the quarter mile they run, for example:
greg aronson: 14,17 sec with a 1700cc engine with stock gear box ( normaly at that time i think was a 110 cam and 40/34 valves with 48 ida in this combo)
and later a 1800cc engine runing 13.5o
dave rhoads: 12.40 with a 82x88 engine 40/35.5 valves 130 cam and 10.1:1 compression ratio
this engines are build more than 30 years ago with no big spezial tricks and they are more powerfull then today....?
are this early cars very light or what is the trick?
i dont think that greg aronsons 1700cc engine make more than 110 - 120 bhp, today cars with that power run in the low 16 maybe high 15 or i'm so wrong?
can somebody explain?
dirk zeyen
back again!!!
« Reply #1 on: February 14, 2008, 23:21:39 pm »
I think some of it had to do with higher octane gasoline back then and some probably had higher compression ratios then 10.0:1.  Another reason could be car set-up...most of us ran on 165X15 tires compared with 205/70's or 205/65's.  A "short" tire will launch better with a 1700-1800cc motor then a taller tire.  Also, it was common to have close-ratio gears back then...something that's sometimes "overlooked."  For myself, I tried as hard as I could to get my car as light as possible.  Then there's the issue of having drag strips everywhere back in the day, so we got plenty of time to fine tune things.
tikimadness
« Reply #2 on: February 14, 2008, 23:26:25 pm »
i think that the time and knowledge put in those (old) engines is more then most people put in it today.This is I think because options where very limited by means of availabity of performance parts.They had to invent the wheel themself.Today people just go bigger because it is available and as the americans say there is no substitute for cubic inches.We now get the horsepower easier then back in the days allthough I don't think most people are going the length of getting the most of their engine but go for durability rather then full on race engines.
michael
NIDGAFWYT
Casey
« Reply #3 on: February 15, 2008, 01:12:17 am »
Dirk, I often wake up in the middle of the night wondering the same thing. "40mm intake running in the low 12's" Wow. Goes to show bigger hole is not always the answer. Like Sarge said too, the fuel back then, lots of 10 and 11 to 1 motors. Couple this with correctly set up rear suspension, light weight car............walla! Lots of seat time too. Remember, the cars you talk about born here in the O.C. These guys raced a few times a week. I for one am on board with takin' a little weight out of er'
The one car that I just can't get over is Dave Conklin (hope I have the correct last name) and his black 67' 2 liter, 10 to 1, NON welded 40mm intake!!!! the thing ran in the 20's at Carlsbad years ago. What a trip to see. It's consistent too. Later Casey.
bullitt
everything as it was at the good old days.
« Reply #4 on: February 15, 2008, 02:41:09 am »
all was better in the sevnties...tht's all Cheesy
Lanny Hussey
« Reply #5 on: February 15, 2008, 04:00:13 am »
Ohio Pump Gas.. Wink Wink
Cheesepanzer
« Reply #6 on: February 15, 2008, 22:57:12 pm »
I've often wondered about this as well.  Displacement was less than today.  The average performance cylinder head had smaller valves and port sizes.  Merged headers maxed out at 1 5/8".  IDA's were run with 37 or 40mm venturis.  Early engines ran 88 bore, and it was "wild" to run 92's.
I think it all came down to port velosity and the right part combinations.
But it is weird to consider a 74x88 engine pushing a 1600lbs car into low 12's or high 11's.  And it takes a 2300cc's, 44x38 welded heads and "big" parts to do it today.
63 Type 2 Single Cab
Cornpanzers
« Reply #7 on: February 15, 2008, 23:08:00 pm »
Better part quality back then !
« Reply #8 on: February 15, 2008, 23:09:59 pm »
guys like Sarge weighed less back then
Frank LUX
Back...Soon...hopefully!!!
« Reply #9 on: February 15, 2008, 23:14:27 pm »
 Grin Grin Grin Grin Grin Grin Grin Grin Grin Grin Grin Grin Grin
Frank
Frank LUX
« Reply #10 on: February 15, 2008, 23:19:13 pm »
Seriously,
I think it has to do with Better Fuel (High Octane), High Compression Motors and alot less Security stuff, Cars where Ultra Light and no huge Cages...
Frank
« Reply #11 on: February 15, 2008, 23:29:39 pm »
You MUST be right, the only thing that hasn't changed since the seventies is the laws of physics.
The guys back then just had better heads, just think about it, you couldn't buy the wrong head of the shelf...  but the right head could be made for you. And with them you received the porters recommendations for the rest of the engine. How could you fail?
It just comes down to know how
You can still get this service today , but it comes at a cost...
henk
« Reply #12 on: February 16, 2008, 13:39:29 pm »
how high was the octane back then?
you can still buy fuel with 100 octane but it's leaded fuel
G77
« Reply #13 on: February 16, 2008, 15:16:05 pm »
I use 4 STAR leaded petrol every now and then, it makes quite a difference to my 1776, Cheesy good boost in horse power over unleaded.
I've never adjusted the timing to suit!
Does using leaded have any negative effects?
KDF
dirk zeyen
« Reply #14 on: February 16, 2008, 17:03:24 pm »
hello,
thanks for the information.
head job is one thing another is lightwight, but one thing is often overlooked: the smaller rear tires (165/15).
less diameter means to me something like a cheap way to shorten the gear ratio, today many guys running 205/70-15 with stock or near stock gear ratios, perfect on the freeway but on the track.....bad bad bad.
my rear tires are 195/65-15 but if i put on this ugly 195/50-15 it fells like somebody put a turbo on my car, ok i have a stock 4.375 ratio gear box no close ratio but the difference is fu..ing fantastic Grin Grin Grin
dirk zeyen
back again!!!
« Reply #15 on: February 16, 2008, 22:55:31 pm »
hello,
dirk zeyen
I cant speak for the others but Daves car i know well Smiley  When he was racing it regularly[twice a week or more] it weighed 1750lbs with him in it,all it has missing from stock are the bumpers,rear seat,front indicators,and the side chrome Cheesy   It still is the same compression  10.1/1 as it always was[since 1980] all that changed is a few years ago,he added 1.25/1 rockers instead of the stock 1.1/1 VW Shocked  it comes down to a good set of heads,a well put together engine,the best suited gears in the trans[geared for 26inch tall slicks] and constant test n tune.
cheers richie,uk
PS heres a thought for you,Dave had different length rods for different tracks,do people try things like this now?HuhHuhHuhHuh?
« Reply #16 on: February 16, 2008, 22:57:03 pm »
oh and of course changed the heavy steel wheels for BRMS Cheesy
cheers richie,uk
« Reply #17 on: February 17, 2008, 10:17:30 am »
In another thread, Keith says that this old mouse engine were also grenade engine. Powerful, but not as reliable as big guns we have nowadays.
And I think also that, back in the days, peoples take more time to build there engine. They don't have as much perfo parts as us. They took time to adapt originals parts to hi performance use.
Now, you go to a shop, buy a 82mm crank, 94mm pistons, an alu case already bore and machined to accept this big cranck, take a set of those nice 044 cnc heads with 42*37 valves. That's pretty much simple! You can also order them from your armchair by Internet!
dirk zeyen
« Reply #18 on: February 17, 2008, 10:25:53 am »
hello ritchie,
different lenght roads is interresting, so dave is a man we can ask about the best road-ratio, not many people tryed different roads in the same engine. but hasen't he changed the heads, today there are 42/37.5 valves i read somewhere (maybe DKP-site). i'm interrested if he could fell a big difference in changing his heads. in the good old days they run smaller valves and good head jobs and i think this works better then todays cnc ported monster valved heads.... Shocked
dirk zeyen
back again!!!
« Reply #19 on: February 17, 2008, 11:40:19 am »
i am not an expert, but i don't think CNC is the all-make-good-solution in heads.
you can get lucky that the head fits the engine combo right out of the box, but in most cases it comes down to porting and adapting. and it really doesn't matter what you start from... in rough black and white thinking. it is a bit more logical to start with a CB cnc head that allready has 44x37 valves insted of welding up stock duals. it can be done just as good, but there are other benefits as well.
plus if Dave raced his car twice a week it is about 50 times more than our 2 times a year... and he can indeed finetune his engine way better.
but i really like to know more about these engines as well. if only for the fact that CR is not always that big of a boost in HP. sometimes i read about very similar engines, but with a totally different CR, but HP isn't that far from eachother.
i always have to think about the first dynoday of VWtrends. Bill's  car only has 8,6 CR and reached the number 2 spot ( a hair away from first) and yet he had one of the lowest CR's of all the cars.
« Reply #20 on: February 17, 2008, 11:42:13 am »
Wasn t this on the orange and white gary berg drag beetle decklid
"They re is no substitude for a good head job"
« Reply #21 on: February 17, 2008, 17:35:59 pm »
Quote
That was Clyde's car, but the wording is correct.
« Reply #22 on: February 17, 2008, 20:23:25 pm »
hello ritchie,
dirk zeyen
he has his ideas on rods,but am not sure he wants to share them Wink    The head were a recent upgrade,same old heads just needed freshening up after years of use and they tried a 42 intake valve,with new seat and porting,slightly different trans ratios to suit and changed rods Wink   it has only been to vegas like this and with me driving[i proberly weigh 80lbs more Cheesy  ]  and i was slower Sad   it should get a couple of outings to the trck this year so we will see if the changes helped or not Smiley
cheers richie,uk
« Reply #23 on: February 18, 2008, 00:18:47 am »
One overlooked factor today is weight.  Few people today consider how heavy their parts or cars are.
Back then, you could get a Berg Mg sump, Mg intake manifolds.  Today, everyone wants to bolt on a 13lb overkill sump, and big Beef manifolds.  205/70s weigh more than 165s.  Fake BRMs, double the real thing.  There's a current topic in another forum about a guy who wants to lay 10lbs of braided steel fuel line from the front to rear where less than 2lbs of Al tubing would do the same job.
An 84 crank weighs more than a 74, 94 P&Cs more than 88s, 1 3/4 exh more than a 1 5/8.  Fatboy muff more than a QP.  Full bumpers more than Tee bars (or none at all!)  One could go on all day.  No wonder today's tanks need so much hp.
« Reply #24 on: February 18, 2008, 00:41:40 am »
Very true Bruce, and I made mention of this a year or so ago....how much attention do guys today pay to how much their cars weigh after all the "in" things are done to them?
I can think of a few cars that have all the look, but because of their weight, don't have the go of some simpler cars, with smaller cc engine. IF I ever build another "hot rod" VW,....IF......, it will weigh less than a stock Beetle, fueled-up at the curb. Cut unsprung weight to a minimum, build a welter-weight cc motor and go flying. Kind of like a Cal Look bug "R" model... Grin
Russell
« Reply #25 on: February 18, 2008, 00:48:32 am »
better air quality ? the ozone layer was in far better condition then.
Best Regards
Russell
« Reply #26 on: February 18, 2008, 00:58:21 am »
russell, you forget to mention we have to cope with higher temperatures due to global heating as well!
dirk zeyen
« Reply #27 on: February 18, 2008, 20:20:48 pm »
hello,
less weight is a very impotant thing: 5kg/ps means
1) 700kg and 140ps
2) 800kg and 160ps
3) 900kg and 180ps
so if you want to safe some money build your cars as light as possible and you run fast enough with a smaller engine!!!
for this year i will change my rear windows to some makrolon windows and put everything out of the car i don't need!!!
nicolas you want more information about dave rhoads engine, here we go 82x88, engle 130 cam, 40/35.5valves, compression 10.1:1 and 48 IDA 180bhp@7000rpm, if you want to know more you should ask fabs, this car was featured in a "christmas vw-trends" could be 1991 i have this issue but can't find it at the moment.
dirk zeyen
back again!!!
« Reply #28 on: February 18, 2008, 20:32:39 pm »
thanks! i may have that issue myself... time to dig it up.
but richie please tell us more about the car (at least the parts that are not top secret  Wink )
« Reply #29 on: February 18, 2008, 21:37:32 pm »
Hi nicolas,well what do you want to know?  Wink
 cheers richie,uk
