November 03, 2026, 17:47:09 pm
| | |-+  Old Mallory Ignitor. How to tunes it?
Author Topic: Old Mallory Ignitor. How to tunes it?  (Read 8173 times)
« on: February 17, 2008, 19:24:19 pm »
I have two old Mallory ignitor. The dual points.
I don't know how to tune it. How much space for the points? 0.40mm?
How much advance? 10° in static and 30-32 @ 3.000 rpm like an 009?
How can I check the advance curve. I know that's its possible to modify it on this model. How can I check if it is still the originals set up?
Thank  Wink
Brew 66
« Reply #1 on: February 27, 2008, 04:08:52 am »
I have the same set up, any help out there?
JS
« Reply #2 on: February 27, 2008, 08:14:29 am »
I also have one that i´m planning on using. My question is how come "nobody" uses them? Are they no good?
Signature.
« Reply #3 on: February 27, 2008, 19:40:52 pm »
I used a first version of Unilite back in early 80s.
Then I borrowed a doubelpoint version from Mats Herrlander on several engines and I think it is still around in his ownership, running with his street 2332cc.
I just love them.
Unfortunately I have no data but try STF.
Or just ask Mallory. They have given me good support in the past.
JS
« Reply #4 on: February 28, 2008, 23:05:38 pm »
Interesting! I´ll give it a try for sure. Can you remember what point gap you used? The usual 0,4mm?
Signature.
« Reply #5 on: February 29, 2008, 20:23:20 pm »
Yes 0.4 mm is what I remember but I am not 100% sure.
If you know what dwell you need/want you could measure dwell and get right breaker point distance.
But again, if you want to be sure, check with Mallory.
Just got a reminder from Mats that in fact he did run the distributor still. BUT he had experienced on problem one day.
The engine simply died on the highway.
Long story but he got the car going with a borrowed distributor but when doing root cause analysing he found out the rotor had simply shortcircuited to the center axle, in some way which I have not understoood.
What he did was convert it/update to Unilite module and now he loves it again.
« Reply #6 on: February 29, 2008, 21:54:28 pm »
That´s what I do too. Then you can keep the old look and get modern ignition.
They are a little tricky to adjust the advance and advance rate on. But with a few tries you´ll get the hang of it. WRT how to set it. Well that depends on YOUR engine. But for starters you could try and set it to 10/32 and go from there.
« Reply #7 on: February 29, 2008, 22:07:18 pm »
Thanks for the advices.
I buy them some years ago and never use it. I buy from Summit items to rebuild it and plan to use it, for the look.I did not know that there is electronic module available for.
But, now I was wondering how set it correctly. And I have to admit that they look quite complex compared to a 009  Roll Eyes
Svwerker
« Reply #8 on: March 01, 2008, 12:21:27 pm »
Mallory sell springsets and instructions fore these, you can disigne your own curv. The cup is the same as all 4-cylinder diststributors of those.
Pertronix also have Ignitor to go.
