October 13, 2026, 08:15:07 am
| | |-+  Bending chromoly tubing
Author Topic: Bending chromoly tubing  (Read 7783 times)
Tekken
www.proturbovw.com
« on: February 18, 2008, 09:56:39 am »
Hi guys.
I need to bend some chromoly tubing for my chute mount,size 1.625" (41mm) with .058" thickness (1.5mm).What should I do to prevent it from going flat and crumple in the bend?Thought maybe heat would help as long as I let the pipe cool down slowly.Fill it with sand combined with heat,or only fill with sand and bend cold?
Anyone..?
Stian
« Reply #1 on: February 18, 2008, 15:18:05 pm »
Fill with sand, bounce aginst the floor, fill with more sand and over untill you have a very tight fit. Wood plug far in to the tube as final push.
Bend only when metal is red and be sure the room temperature is as hot as possible. A room colder than 20C or with winds, will cool the metal too quick and you will likely get brittle Chrome moly.
It might still be tricky to get nice bends.
Same principle as when welding chrome moly, very tricky, but from your comments, I think you are aware. Good luck.
AutoManics
Race car fabricator - 07780 874435.
« Reply #2 on: February 18, 2008, 18:30:25 pm »
Alternatively find someone with a proper tube bender and bung them a tenner to do it properly.
Type 34 Ghia - 8.92@150mph.
www.automanics.com
« Reply #3 on: February 24, 2008, 21:40:07 pm »
If you dont have a tube bender. try sand bending,first weld slug on end of tube,then fill with wet sand,then shake tube with wood paddle and air hammer on low to settle sand,continue till sand doe's not settle then hammer wood cork into tub . when bendind heat tube on inside of rad. and when starting to cool, heat out side of tube, when tub is cooling it is shrinking and when heating it's expanding. cut extra and practice, hope that help's ya out. cut tube's a little long so you can hang onto
