October 13, 2026, 10:19:22 am
EFI?
Topic: EFI? (Read 12141 times)
EFI?
February 22, 2008, 02:55:14 am »
Frank LUX
Back...Soon...hopefully!!!
Re: EFI?
February 22, 2008, 10:05:39 am »
That Golden Thing is missing Something...
Frank
Martin
Cash Converter....
Re: EFI?
February 22, 2008, 20:03:10 pm »
So what you going to use for cam phase?
Martin
www.taylormachine.co.uk
OFF/500
Re: EFI?
February 22, 2008, 20:06:50 pm »
Quote from: volksman on February 22, 2008, 20:03:10 pm
i like to drive it not talk about it
So it only has what is needed
NO BS here
Now get it done
cheers richie,uk
Re: EFI?
February 22, 2008, 20:14:12 pm »
Quote from: richie,uk on February 22, 2008, 02:55:14 am
Please excuse my ignorance but
Re: EFI?
February 22, 2008, 20:17:11 pm »
Quote from: Lee on February 22, 2008, 20:14:12 pm
Which bit?
cheers richie,uk
Re: EFI?
February 22, 2008, 20:19:27 pm »
The shiny gold ring. Is it just a spacer or does it provide some other use?
Re: EFI?
February 22, 2008, 21:04:42 pm »
Quote from: Lee on February 22, 2008, 20:19:27 pm
It was the distributor drive gear but is not needed when you run crank trigger ignition,I machined the teeth of for a reason,its just something that i wanted to try
cheers richie,uk
Re: EFI?
February 22, 2008, 21:47:15 pm »
Hi Richie, what EFI system are you going to run.
Re: EFI?
February 22, 2008, 21:56:12 pm »
Quote from: FDK/Hurry on February 22, 2008, 21:47:15 pm
Same as before, its DTA
cheers richie,uk
Re: EFI?
February 23, 2008, 11:09:13 am »
Quote from: richie,uk on February 22, 2008, 21:04:42 pm
It was the
cheers richie,uk
Of course
Martin
Cash Converter....
Re: EFI?
February 23, 2008, 13:15:00 pm »
Quote from: richie,uk on February 22, 2008, 20:06:50 pm
NO BS here
Now get it done
cheers richie,uk
Working on it now sir.....
Martin
OFF/500
Re: EFI?
February 25, 2008, 11:04:07 am »
Richie, Martin, would it not be easier to make a one piece spacer to eliminate the machined down gear and the spacer below it? Maybe with the sides thinned down and holes drilled through for improved oiling? I'm just thinking of replacing two pieces with one!
Martin
Cash Converter....
Re: EFI?
February 25, 2008, 23:38:54 pm »
Quote from: Neil Davies on February 25, 2008, 11:04:07 am
Yeah thought of that, and making the gear with the spacer already on it. Just not got round to it yet!
I'd also like to make a replacment oil pump cover with the cam phase sensor mounted to it, that way we can just use the cam insted of a Dizzy.
Martin
OFF/500
